My window unit a/c is blowing hot air. the unit is under a year old
    Scholar:
  • 190 Answers
Check your filter and clean it, Check that the high humidity has not iced over your coil, Check that settings are right some air conditioners have a reverse setting that turn them into a heater, make sure fins in condenser is not full of dust vacuum with duster attachment, Make sure that fan opening to outside is not blocked by nest built by birds wasps. If everything is ok call for warranty repair
Posted on Jun 27, 2009
Unit will not blow hot air. It is about two years old and seldom used. Unit comes on the controls work but hot air no longer blows out.
mcdevito75 here, Are you sure your A/C unit is designed to both give heat and A/C ?? I figure the A/C of the unit works well, just doesn't give heat, if so see your local A/C repair shop in your area, they come to the house.
Feb 07, 2010 | Fedders Y Chassis AEY12F7E Air Conditioner
My Amana package system fan only blows cold air
a fuse blows for a reason. dry bearings will increase amp draw, a non rotating fan rotor will blow a fuse. burnt windings will almost instantly blow a fuse. just changing the fuse may not solve your problem. find the problem and fix it THEN replace the fuse.
Oct 20, 2009 | Amana PTH153B50AE Air Conditioner
Whirlpool window unit a/c power comes on but no air comes out
sounds like a bad fan motor or capacitor. mostlikely covered by your warranty
Aug 21, 2009 | Whirlpool ACQ158XP Wall/Window Air...
Our air conditioner unit turns on but just blows hot air
our unit is realy a coleman unit but You did not have that listed.
In any case it started back up again and I was so releaved as it was at least 103 degrees yeasterday. But i haove a feeling this may not be the end of it .
I may need your service at a later date.
Thank you for your quick response.
Jul 29, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Window air cond unit, several years old, doesn't blow as cold
The problem with window units and any service tech will tell you it cost more to repair than you can buy at Walmart or home depot. Unless you know someone who can charge it for you. Window units are a sore subject. A 200 dollar window unit might cost 200 dollars to charge system. SORRy rusty
Jun 13, 2009 | Maytag M6X06F2A Air Conditioner
Fridge Freezer is blowing out hot air, is this fixable and cheap to fix?
is this under warranty? not a year old? thermostat or low refrigierent in compressor.thermo replace price ok.comp refrig can be expensive. hope this helps
May 21, 2009 | Whirlpool Freezers
Fan runs but blowing hot air. Thunderstorm reset some breakers. I did reset the two breakers inside the house and one unit working fine, upstairs unit fan running but blowing warm air only. Box out
Sounds like your Capacitor is bad, or you had a wire burn off compressor terminal or capacitor. Way you can check capacitor is take cover off and see if looks swollen. Make sure to turn off power before taking panel off.
Apr 25, 2009 | Heating & Cooling
A/C unit not blowing enough air.
Do you change the filter regularly? And if you haven't changed it but maybe every year that is the problem. Your a-coil is plugged up and full of the stuff the filter is suppose to catch.
That is one possibility the other is and I have seen this more then once the duct work under the mobile home has come loose and is just pouring the air under there. Let me know what you find. ken
Nov 30, 2008 | Heating & Cooling
20 year old central a/c heater not working
Check your thermostat and mode selector setting, thermostat setting should be set at warmer and mode selector setting should be at low heat or hight this is applicable for manual unit.
If it is a remote control just set the remote to heat mode.
sample only
Jan 02, 2008 | GE Quiet-Aire Ductless Split System Air...
Heating & Cooling Logo
103 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
