Question about Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television
Sharp lc26dv24U has sound but no picture for tv and works fine with dvd
5 Suggested Answers
SOURCE:
SOURCE: Sharp LC32D62U sound problem
I had the same problem with a lc46se94u.
It went away the next day.
Posted on Oct 25, 2008
budmrtn
  • 11361 Answers
SOURCE: 42 sharp lcd tv picture won't come on but the
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Dec 09, 2009
ginko
  • 19396 Answers
SOURCE: I have a Sharp LC26DV24U
Hi.
If the screen is blank with back light on but no picture, then the problem is usually the digital board. There is no other way to test the board than reading voltages and following the schematics. Voltages are detailed in the diagrams in service manual, available here : sharp_lc-26dv24u_[ET].
The digital board starts at page 11.
You can also test on power board the lines 12VDC, 5VDC and 6VDC that supply power to digital board.
For safety reasons testing and repair must be done by a trained person.
Regards.
Ginko
Posted on Apr 30, 2011
spr1949
  • 1182 Answers
SOURCE: Sharp TV - no picture, sound is fine
Hope this is an LCD TV. If it is, show a torch light from a distance and see whether the picture can be seen. If yes, the backlight has gone bad. If no, try changing the input device to something you know works. If nothing works, this is a case for a qualified service technician.
Posted on Jul 29, 2012
My sharp LC-40E67UN will not show picture. The tv turns on but no picture checked wires everything ok. Please help!
Connect the TV to any other video source, ie, from a VCR or DVD player. Check whether the working is perfect both with picture and sound. It's needn't to say, that you have to select proper input selecction. If the TV woks fine now, make sure that the RF stage circuit has the fault.
Jun 04, 2013 | Televison & Video
Sharp lcd problem ; hdtv
Have you tried cable or another source? If so how long have you owned the tv as it sounds like it may require servicing. I can give you the contact info to locate the nearest authorized dealer or local repair shops as well.
Let me know if you need any further assistance and if you have a moment to accept and rate the solution I would greatly appreciate it.
Thanks,
Lee
Aug 10, 2008 | Sharp 32F641 TV
Sharp 32" lcd tv vertical lines on screen
sounds like you have receiver connection problem..
To test it try to play dvd on your TV..if the picture is fine your TV is good..your problem is on the cable box or receiver..
Nov 06, 2012 | Sharp LC-32AV22U 32 in. LCD TV
Jul 28, 2012 | Sharp Televison & Video
No Picture
If your TV is a SHARP LC-45GD5U,
Try using the reset buttons on the back of the TV. It should be below your digital audio output port.
If that doesn't work, ( this is only a guess) the power supply for the LCD screen may have burned out.
Feb 15, 2009 | Sharp LC-45GD5U 45 in. LCD Television
I bought an HDMI wire and it does not work with my tv.
A quick Google search for "IBIAO Technology" on November 2017 had no hits for me. This is not a comment on the quality of their products but might indicate a smaller than usual company or distributor.
I have purchased more than 10 generic HDMI cables from "Mycablemart". All continue to work perfectly on my TVs (LG, Samsung, Sharpe, Viewsonic). These sets were manufactured between 2006 and 2011 and include a 3D plasma unit. Cable prices were typically one half to one third that of big box stores for the purchased lengths of 18 inches to 15 feet.
A Google search using "powered hdmi cables" had a hit for an HDMI.org.learning center with questions and answers to just about every HDMI related issue. One Q/A indicated normal HDMI cables will work up to 10 meters (30+ feet) if the sender/receiver are engineered properly. You might consider buying an active or powered HDMI cable if a cheaper standard cable will not work.
https://www.hdmi.org/learningcenter/kb.aspx?c=13
Oct 17, 2017 | Sharp Televison & Video
I have a 32 inch sharp tv and it has been working fine, but i just went to watch a dvd and got sound from the dvd but a green, disjointed pattern instead of pictures. i switched dvds and it was the same...
there is a possibility that you have switched the RCA cables for the right port, the color patterns happen if your plug the component RCA ( Y Pb Pr) on a diff port. their usually color coded so please double check that to.
e733778.jpg if not, please let us know what is the model number of the TV and we will find what can be done in the TV.
Aug 10, 2008 | Televison & Video
No picture when I turn the tv on only sound
TRY CALLING BEST BUY'S GEEK SQUAD TO COME FOR A IN-HOME REPAIR SERVICE CALL AND THEY WILL FIX YOUR PROBLEM!
Dec 14, 2006 | Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television Logo
119 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
