Question about Texas Instruments TI-89 Calculator
Syntax error hieverytime i use a minus sign before a number on the home calculator screen,for eg 5*(-1) it gives me a syntax error.do i need to change any settings.i think i picked up this problem when i changed some setting unknowingly.please mail me a solution to gosidgetbusy@hotmail.com
Hi. I'm not sure if you are using the correct button for a negative integer. I do this all the time, but the first thing to check is that you use the button that is located next to the decimal point (very bottom row, second button from the right) it looks like (-). If you are using the actual "minus" button thats in the same columns as + and x, etc then you will receive a syntax error.
so try 5*(button next to decimal (-)1) and you should hopefully get the right answer and error free :)
If that is not the case then I'm not quite sure how to help you
Posted on Dec 13, 2007
I have a casio fx-9750 g2.Whenever i try to dra w a graph it always get a syntax error the manual has not helped.kindly assist.
Please give the exact examples you were trying to graph. The syntax error points to an error in the input line, such as using the minus sign instead of the change sign (-).
Aug 08, 2014 | Office Equipment & Supplies
How do I graph a simple equation on my TI-86, without getting an error 07 message? y=-1.5x+3
Error 07 Syntax
Means you made a typing error while entering the equation. Using the minus sign instead of the negation sign (change sign) (-), can produce a syntax error. Maybe you need to explicitly type the multiplication sign
y= (-) 1.5*x +3
Try entering it as 3 - 1.5*x
Jun 11, 2014 | Texas Instruments TI-86 Calculator
How do I graph a simple equation, without getting an error 07 message? y=-1.5x+3
Error 07 Syntax
y= (-) 1.5*x +3
What does error syntax mean
You enter a command. It is like an English sentence with a syntax (correct structure). If the structure of the command is wrong, you have a syntax error. You could use a minus - sign, instead of a change sign (-) that constitutes a syntax error.
May 27, 2014 | Texas Instruments TI-84 Plus Silver...
Err:syntax when I try to graph with ''-'' on ti-84 plus
The calculator has two minus signs
  1. The regular MINUS sign which is used with the subtraction operation. This operation is binary, requiring two operands (two terms). In a-b, a and be are the operands (they very specific names, but I will skip this detail).
  2. The negation or change sign. This operation is called unary, requiring one operand. -a means take the negative of the number a.
These are the technicalities, in which you may not be interested. On calculators, the two operations are implemented differently, with two signs, the regular minus sign -- , and the change sign (-) usually smaller in size than the regular -- sign and raised above the main line.
Examples. Let (-) be the negation and -- the regular minus.
  • If you enter (-) 12 the TI84Plus accepts it and calculates the negative of 12.
  • If you enter 12 (-) 13 the TI protests with a syntax error
  • If you enter 12 ( (-) 13) the calculator interprets it as 12* (-13) and calculates -156.
  • If you enter --12, the calculator displays Ans--12, where Ans is the last result calculated. If Ans happens to be 0, the new result is obviously the one you are expecting. But if Ans holds a non zero value, this is incorrect.
Suppose you have to calculate X^(-2)*X^(-1/3)
You can enter it exactly as it is written above. In this case, you must use the change sign (-) in both factors.
You can also decide to use the power rules and enter the expression as X^( -2 --1/3). In this case the first minus is the negation and the second is the regular minus.
I could go on with a few more examples, but that will take us away from your present concern.
In short.
  1. If the minus sign is the leftmost (first) symbol in your function (after the Y1=) you should use the negation. Any subsequent minus should be the regular minus --
  2. If the minus sign is the first symbol in an exponent, you must use the negation. Any subsequent minus in the expression of an exponent should be the regular minus --
I hope it did not bore you death with details you do not care to know about. I do hope that it will help you prevent this type of syntax errors.
Do not forget to rate the solution
Dec 13, 2009 | Texas Instruments TI-84 Plus Silver...
Every time i punch in 1000 - 500 i keep getting a negative sign in front of my numbers. and the = doesnt work. please help
Calculators usually have two minuses, the regular minus sign and the change sign sometimes labeled (-) or (+/-). The latter is not meant to effect a subtraction, but to take the negative of the number you just entered. Big difference, would you say, but the syntax is different.
Ex: 15 - 7 is a subtraction with result 8
10 (-) displays -10 on the screen.
In some calculators the change sign is smaller than the regular minus, and is raised above the main line.
Hope it helps.
Oct 05, 2009 | Victor 1208 Calculator
How do I stop getting the synthx error
The calculator will stop screaming out SYNTAX ERROR, when you stop ordering it to do things the wrong way.
Take a look at the manual.
For certain calculations you enter the number first and then press the function key.
For others, you press the function key then the number.
If an expression contains a left parenthesis, it must also have a closing right parenthesis.
It you want to enter negative 5, you use the change sign (-) not the regular MINUS sign.
These are exemples of instances where you get a syntax error. For every new type of calculation you have to perform, read the exemple in the manual to find out which must be entered first: the number or the function.
Hope it helps.
Sep 30, 2009 | Texas Instruments TI-30XA Calculator
Error:syntax when I try to graph
I am no seer, nor will I try to guess what may have happened. This error may come from various conditions
1. The most common reason is an omitted right parenthesis. For instance you press the [sin] function key. It shows as sin( , notice the right parenthesis. You enter the variable, say X, and you press [ENTER]. The calculator gives you a syntax error: It does not know what to do as long as you do not insert the closing parenthesis.
2. Another common source of this error message is the use of the regular MINUS sign instead of the (-). The latter appears on the scren as a smaller, raised minus sign. This is especially true when you want to raise a number or a variable to a negative exponent.
Every function has one way it takes in its food (argument). If you don't do it the right way, it gives you an error. The nice thing is that the calculator gives you the opportunity to correct the error. Whenever you see Error 1:quit 2: Go to, choose GO TO because the calculator shows you exactly the symbol that is creating havoc: It will be highlighted.
Hope it helps.
Sep 15, 2009 | Texas Instruments TI-83 Plus Calculator
Casio calculator fc-100v, to the power of?
Hello
To calculate a number to an arbitrary power you use the button labeled ^ .
If you want the cube of 2 your enter
[2][^][3] will give you 8. If your exponent is negative use the sign change key (-) and close the negative exponent between parentheses : for exemple the sequence to compute 2 to power of negative 5 is as follows
2[^] [(] 5 [(-)] [)] which means you enter the value of the exponent before the change sign (-). If you use the big MINUS sign you will get a syntax error.
Hope it helps.
Aug 29, 2008 | Casio FC-200V Scientific Calculator
Texas Instruments TI-89 Calculator Logo
569 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
