Question about Pinnacle PS Sub 150 Subwoofer
Loud Hum in Pinnacle 150 subwoofer
I have had this pinnacle 150 subwoofers since 1998. I came home and heard a load humming in my media room coming our of one of the subwoofers (not both). I disconnected the input cable but it did not stop. I had to unplug the power to stop the noise. I left the input disconnected and plugged the speaker back into power and the humming immediately was back. Any suggestions on what may be the issue would be appreciated.
Thx. Don
  • Anonymous Feb 28, 2008
    I have the same problem with a Yamaha SW160 sub. Upgraded the receiver and after moving everything around and finishing all the settings i now have a contstant hum from the sub. Have tried different connections and rerouting cables all to no avail. The hum is still there when only the power is connected. Our power is 220v
The hum is likely due to either a failed capacitor in the subwoofer power supply or as it was for me, a cold solder joint on the capacitor. The fix is simple, but does require soldering. Unplug the subwoofer and set it on a good working surface. Remove the screws holding the back panel to the cabinet. These screws are the ones near the edge of the panel. Take off the panel by pulling back on it, reach into the subwoofer and carefully unplug the red and black speaker leads noting which one goes to each connector. Orient the panel with the electronics side up and the power cord at the lower right of the panel. Just to the left of where the power cord is soldered to the board is a large cylindrical capacitor. It is by far the largest cylidrical component on the board. This capacitor filters the hum made by the step down transformer in the power supply. If the capacitor is not working the subwoofer hums. The capacitor is soldered to the back of the electronics board. We had to reach in with a modified soldering iron to remove the capacitor. Before removing the capacitor check the orientation, there is a plus and minus, make sure it goes back in the same way. After removing the capacitor inspect the capacitor leads to see if they were both soldered correctly. If one of the leads is not silver the most likely cause is a cold solder and the fix is to simply clean up the capacitor leads by scraping off anything that is not silver, tinning the capacitor leads and re-soldering it to the board. If the leads look like they had a good solder, test the capacitor by using an ohm meter (used to test resistance) between the capacitor leads. The meter should show low resitance and as the capacitor charges the resitance should go up to infinite. If the meter does not behave this way while testing the capacitor, replace the capacitor. Bring the old capacitor with you to the electronics part store to make sure you get one that has the same electrical properties as the one you are replacing. The form of the capacitor might be different but as long as it is has the right electrical properties it will work. - and don't foget to make sure the polarity is correct when you solder it in!
Posted on Sep 14, 2008
Loud buzz in sub woofer, soundbar sounds fine
How to Stop a Subwoofer Hum - HowStuffWorks
Would you like to learn how to stop your subwoofer from making a consistent low-frequent hum or buzz? Read this article to learn how to stop a subwoofer hum.
Aug 03, 2015 | Audio Players & Recorders
KLH HPS 1100 powered subwoofer. as soon as plugged into AC we get a loud hum from spkr. had unit for 8yrs.
Hum usually indicates a power supply problem. If it has an internal supply you will need someone to check it's producing clean DC. Alternatively if you do open it (beware risk of shock!!) initially visually check condition of /replace any bulging electrolytic capacitors.
Jun 27, 2014 | Audio Players & Recorders
Loud hum on mirage omni s8
need to replace the amp assembly...common problem on this model.
Dec 04, 2013 | Mirage OMNI S8 Speaker
I have an Onkyo TX SR 700 receiver, Bose Acoustic Mass 10 speakers, Panasonic Viera 52" flat screen with my computer connected to the receiver. The computer uses a high end sound card. The flat screen...
Hi, what causes hums from speaker is when there is no ground shield from either the power supply or from the cable you plugged into the socket from the power supply.
So you will need to check that out and replace untrusted cables for connection..
If after doing this troubleshooting exercise, you will now need to test the speaker with another set to be sure the humming sound is not coming from there.
I guess that will Do.
Have a nice day...
Feb 18, 2011 | Bose Acoustimass 10 Series IV Home...
After a power outage I have a loud hum.
Hi, The Ground Rules Of all the annoyances that can afflict any audio/video home theater or even a simple stereo installation, the notorious "ground loop" may well be the most difficult and persistent one to track down and eliminate. A "ground loop" is caused by the difference in electrical potential at different grounding points in an audio/video system. (All the grounds in an A/V system should ideally be at "0" potential.) A ground loop typically adds a loud low-frequency hum or buzz as soon as you plug in any of various audio or video components, including subwoofers, cable-TV outboard boxes, satellite-TV feeds, TV displays, amplifiers, A/V receivers or turntables. The buzz/hum is a byproduct of the multiple power supply cables and a ground voltage differential within your system and its network of interconnecting cables.
Here are some methods to help you get rid of ground loops. Try these first and don't waste money on a power "conditioner" which, in most cases, won't help. (There is no need to "condition" the AC power for your system. Your receiver or amplifier already has a power supply with its own filters and transformers. No further filtering is normally required.)
If you get your system up and running and hear an audible buzz or hum, the first culprit to look at is either the powered subwoofer or your cable-TV or satellite-box feed at the entry point to your system.
First, the subwoofer: unplug the coaxial cable that connects to your powered subwoofer to see if the ground-loop hum disappears. If it does, it's likely coming in through your cable/satellite TV feed.
Reconnect your subwoofer's coaxial cable from the subwoofer input to your receiver's subwoofer output and disconnect the cable-TV feed (or satellite feed) from your outboard set-top cable box or satellite tuner. Be sure and disconnect the cable before any splitters. Now see if the hum/buzz from your subwoofer stops.
If that eliminates the hum, you can install one of these inexpensive in-line ground isolators from Parts Express or Bass Home. Note that these transformer-based ground isolators will work fine with analog cable-TV feeds, but depending on their design they may interfere with or block reception of HDTV signals via a digital cable or satellite dish feed.
Install the ground isolator between the cable-TV feed and the input of your outboard cable-TV box or satellite tuner (or the TV display's antenna or cable input if you have a set with a built-in TV tuner or a cable-card ready set). In many cases, the ground isolator will "break" the loop and remove the annoying hum or buzz by isolating the TV-cable ground.
If a hum remains with the TV cable completely disconnected from your system, or you don't want to risk degrading reception of HD signals from a cable or satellite system, then you may have to add a ground isolator like this Radio Shack Model 270-054 between the line-level coaxial subwoofer cable from your A/V receiver and the line-level input jack on your powered subwoofer.
In all cases, if your subwoofer has a ground-lift screw like some of Axiom's subwoofers, try first removing the screw (or replacing it) to see if it increases or eliminates the hum. It may or may not make a difference.
If you do not have easy access to the aforementioned ground isolators, here are a few more tips:
Try plugging the subwoofer into a different AC outlet in the room, one that isn't supplying power to your components (A/V receiver, TV, cable box, etc.). That might fix it.
Try reversing the AC plug for your A/V receiver or the powered subwoofer. If it's a 3-wire plug or a polarized plug, which has one prong wider than the other, you won't be able to reverse the plug. For safety, do not use a "cheater plug" to bypass the 3-wire plug.
With the power OFF, reverse the AC plugs one by one of any other components that have a standard 2-prong AC plug that isn't polarized. Each time you reverse a plug, turn on the system with the attached component and your subwoofer and see if the hum disappears. In some cases, reversing one or more plugs will eliminate the hum.
If you have a turntable, try connecting a separate ground wire to a chassis screw on your preamp or receiver and see if the hum disappears. If you already have a turntable ground wire, try removing it from the preamp. One or the other may eliminate the hum.
Finally, here is another solution that worked well for a member of our message boards who decided to discard his ground-loop isolator on his subwoofer: "I took off the ground-loop isolator I'd been using and connected a plain 14-gauge wire to chassis screws on the sub and the receiver then powered everything on. Although hum was still there, it was far lower than before. Next I unscrewed the ground-loop screw on the back of the sub and that took care of the hum completely."
Almost certainly sounds like an earth loop to me, but can be caused by a poorly made transformer or phase shifts on the mains supply. Visit some power conditioner web-sites like Isotek or Isol-8 (or google "earth loop") where there's plenty of advice on how to reduce/eliminate earth loops and other causes of mains-induced hum (transformer problems etc).
Hum on the speakers usually indicates that there is a DC voltage on the speaker line. DC voltage on the output lines would be caused by a shorted output transistor.
Have a nice day...
Feb 16, 2011 | Cambridge Soundworks BassCube 12 Speaker
I have a Sony subwoofer for the home entertainment theater. There is a loud hum coming from the subwoofer. The hum persisits even if unplugged from the receiver. Also, I've tried a ground loop isolator...
Hi and welcome to fixya.
To answer your question;
From your description of the problem it sounds like your powered subwoofer has a power supply circuit problem.
It would be either with the large capacitors in the first stage of the supply(most likely) or with the regulation system that supplies +-15 volts to the preamp section.
If you are not familiar with electronic circuits you could still ask a repair shop to verify those large capacitors.
Hope this help and happy holidays.
Dec 06, 2010 | Sony Audio Players & Recorders
Loud hHum from Subwoofer
Sounds like the hum might be mains hum caused by the failure of the power supply capacitor(s) in the sub. It/they will be the largest on the pc board. You will find all the details (needed to replace it) on them. If you find more than one replace both.
Dec 10, 2009 | Audio Players & Recorders
Bought a used Martin Logan Dynamo subwoofer a couple days ago and have a very loud hum when the ac cord is plugged in, even if the speaker is not connected to an audio source. The "hum" can be heard in any...
Neither the amp or the sub have grounded power cords.
I have discovered the ML Dynamo takes about 30 minutes to switch to standby in auto mode.
With speaker level inputs connected to the Onkyo A807 amp, both units powered from the same wall outlet, Dynamo sub on Auto, the sub hums for about half an hour after the Onkyo is switched off, then the sub goes quiet. Not so good.
I connected a bonding wire between the two units on 3_7_09. If I smoked some old audio gear I could just look at that as an opportunity, right?
Works fine. Now I have the ML powered from the wall and working normally.
Jun 30, 2009 | Dynamo MartinLogan Subwoofer Speaker
Loud noise from subwoofer on standby or while playing music
Hi There, Please advise us what happens when you turn off the sub woofer is the hum still there....??
Nov 27, 2007 | Teac CD-X8 CD Shelf System
Loud Humming...
hum usually comes from the power side, not necessarily the inputs. try physically moving your amp to another room in the house, or even to a friends house, see if the hum goes away. if it does, get an outlet tester ($15) from home depot and test the outlet, hot and neutral may be reversed. talk to someone who knows home electricity if you are not sure what to do in an outlet. if this does not work, try plugging the amplifier into a decent power bar (apc or such) usually used for computers. this sometimes helps as well. (usually less than 30 bucks)
Aug 11, 2007 | Paradigm PS 1200 Speaker
Pinnacle PS Sub 150 Subwoofer Logo
718 people viewed this question
Top Pinnacle Audio Players & Recorders Experts
Are you a Pinnacle Audio Player and Recorder Expert? Answer questions, earn points and help others
