Question about IBM Lenovo ThinkPad T60
Intel(R)pro/wirless 3945ABG I am totaly new in slax and i want to enable my wifi but the problem is that i tried but i could'nt i will be thantks if you help me
Is this laptop is wifi ready?
Yes it is wifi ready.
click me for more info
Toshiba review unit had the following specifications: Intel Core 2 Duo T8100 2.1GHz processor Intel X3100 Integrated Graphics 2GB RAM DDR2 15.4" WXGA 1280x800 screen Intel PRO/Wireless 3945ABG (802.11a/b/g) 10/100 Ethernet LAN Modem port VGA-15 pin DVD-SuperMulti drive (+/-R double layer) supporting up to 11 formats Headphone and microphone jack webcam Battery: 6-cell (4800mAh) Lithium Ion battery Weight: 5.7lbs
Sep 15, 2011 | Toshiba Satellite Pro L300 Notebook
Need driver for 802.11g WLAN - Intel 3945 ABG for Vista Home. Can anyone send me link please?
Hi
Please click the mention below link and download the Driver for Intel 3945ABG
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Wireless+Networking&ProductLine=Intel%C2%AE+WiFi+Products&ProductProduct=Intel%C2%AE+PRO%2fWireless+3945ABG+Network+Connection
May 13, 2011 | Intel 2915ABG 802.11a, 802.11g/b Wireless...
Do I need two wireless network adapters? I looked in the device manager folder in network adapters and there are 2... Intel (R) Pro/1000 PL Network Connection #2 and Intel (R) Pro/wireless 3945ABG...
You should have only 1 wireless adapter, the other 1 is the ethernet adapter. If you experience low signal strength even after updating the drivers, you need to customize wireless settings on the router.
You need to change the wireless mode to "802.11b and 802.11g" or "802.11g", whatever you have in your router. If this is the same with all wireless networks, wherever you go, then its an issue with the adapter, you should get a replacement.
Feb 05, 2010 | Intel PRO/Wireless 3945ABG Network...
My acer wireless still
you need is installed all the software drivers built in wireless lancard, first you download the installer on this web site> (http://www.acer.com) and find the compatible to windows installer and that download that follows, good luck
Jan 05, 2009 | Acer Aspire 5315 Notebook
Intel PRO/Wireless 3945ABG Network Connection code 10
Code 10 usually means the device driver is not compatible, outdated or corrupt.
Try uninstalling the wireless device again and then reinstall using the latest driver available from:
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2259&OSFullName=Windows+Vista*+Home+Premium%2C+32-bit+version&lang=eng&strOSs=153&submit=Go!
NB If you're running XP, use the second one.
Hope this helps
Chris (ziraffa)
Dec 08, 2008 | Intel PRO/Wireless 3945ABG Network...
Compatibility between linksys WRT54G Router and Intel PRO/Wireless 3945ABG Network Driver
from what you say, it sounds as if you have your wired and wireless card connected at the same time. This will confuse the router as it is trying to give two different ip addresses to the one pc, which it cannot do. If you are using the wireless adapter, make sure you dissable the wired adapter as the router will continually look for the wired ip address while allocating your wireless adapter causing instability. Next ensure you have a good clear signal from router to notebook as this can obviously cause problems. Lastly ensure that the wireless cards TCP/IP properties are set to obtain ip address automatically, especially if your router is DHCP enabled to allocate ip addresses automatically.
May 17, 2007 | Linksys Wireless-G WRT54G Router
IBM Lenovo ThinkPad T60 Logo
117 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
