Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Removing fridge door?
Hi, have a whirlpool 25.6 cu ft. double door fridge. One side is an ice and water dispenser with wires attached, can't remove this side........Need to remove the larger side of door without the ice maker to get out of basement apartment.
Brought it in through landlords stairway to her place and then she closed off this opening! Need to fit it through the only exit to the apartment. Even with the door frames removed the fridge will NOT go through!
Need to remove at least the one large door of fridge within the next day. Moving within 24 hours!
Is this possible?
    Guru:
  • 462 Answers
Try opening the doors and moving it through the doorway with the doors open? If you have the room twisting the fridge around the doorway with the doors open my work.
Posted on Jun 27, 2009
My fridge just started running water from under,not just a Lil drip,I even have to shut the main water line off....what do I do now?.
My refrigerator did this when the fridge temperature control door got stuck open and froze everything in the refrigerator. I tracked down the problem to a connection in my water supply filter. I just removed the filter and spliced the line. I doubt the same thing happened to you but you can probably find the leak by tracing the water supply to the ice maker/water dispenser.
Feb 21, 2015 | Whirlpool 25.6 cu. ft. Side-by-Side...
Double door whirlpool refrigerator with ice and water dispenser on door. The problem is that the ice dispenser seems to freeze up and therefore does not come through door. Everything else works fine. Any...
yep that is a systemic problem with that fridge, you need to pull the ice bucket out about once a month or so, empty and clean. I suggest you do this just before you go to bed that way you have ice the next morning. this is just maint.
Sep 03, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
How do you get the water filter out of refrigerator so you can replace it
Without knowing your particular model number, I checked and most 25 cu.ft. side by sides have the water filter in the grille. You just push a release button and it pops out. There is a cap on the filter, do not through it away as you will need it on a new filter. Also ensure the O-ring protective covers are removed on the new filter prior to installing. You can run the water dispenser without a filter as well. Here is a link to the PDF for one type of 25 cu. ft. Whirlpool side by side.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/GS5VHAXWA_Use%20and%20Care_EN.pdf
Jul 17, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water doesn't come out of the door anymore?
Hi, sounds like water soleniod is not working located in the bottom at rear of fridge. Because it is electrical call a technician
Jul 06, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator not cooling down. can fill air comming in but not cool air.side by side whirpol 25 cu.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
gsg
Dec 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The indoor water of my Whirlpool side by side refridgerator stopped dispensing water. The ice still works. I changed the filter but still no water
More than likly the solinoid is damaged, turn off the water and power and remove it, once removed you can turn the power back on while you go and find a new one. leave the water off until the new one is installed and turn the power off while you fit the new one. Turn on water, check for leaks, turn on power check for leaks again.
Before you pay for a new solinoid ask the parts guy to test your old part. If this is not the problem is has to be a problem with the electric switch attached to the water dispencer handle.
The solinoid is a double one side controls the ice the other cold water to the door, mark the two wire terminals so you can put them back. ( check you didnt loosen one of the wires when changing the filter - stranger things have happened ) solinoid is located at the end of the water line from the wall, just behind the cardboard at the bottom of the fridge, it should have two water lines and two power terminals attached.
Oct 04, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
25 ft side by side fridge which does not dispense ice
use a hair blow dryer to warm up the chute and dry up any moisture then lube the chute with a cooking spray, pam is a good one.
Aug 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ed25rfxfw01 whirlpool fridge water dispenser
HI, I can help you. Is the water leaking from the freezer side?
May 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
645 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
