Hi
The water level in a front loader should always be below the door line so consequently it should not be possible for water to leak out the door unless there is a problem with the actual door seal itself.
However if you are using too much, or incorrect type of detergent, the washer may be producing too much suds. Too much suds can cause door to leak.
Other causes of a leak which appears to be coming from the front but is on fact coming from elsewhere:
Check the water inlet hoses.
Check the drain hose.
Check the standpipe (upright drain pipe used instead of a sink), or the wash sink connections. These will often be the actual source of a leak. When they leak the water can roll under the washing machine and appear at the front.
Also check this link for a good description of how to troubleshoot leaks happening at various stages during the cycle.
http://www.repairclinic.com/Washing-Machine-Troubleshooting#Itleaks
Hope this helps. Thanks for using
FixYa.
