Question about Karcher K2.26 Electric Power Washer
I dont have high pressure on my karcher and I can't turn the wand on the karcher pressure handle or not sure if I am doing it right.
  • 92 Answers
SOURCE: Karcher 520M wont operate at high pressure
The solution is very simple. All you have to do is change the spill valve.
This because the spill valve is not worth servicing. The actual problem is that the spill valve is leaking from its bottom-part seating. When you close the gun, the spill valve goes down, opens from the underside, and switches the electricity off. When you press the gun, the spill valve returns to normal, and if the underside does not close, you have low presure, because the water keeps circulating.
Regards,
MG. (Karcher service engineer).
Posted on Nov 04, 2008
  • 389 Answers
SOURCE: I was using the pressure washer and it stopped
This problem, where the unit continually switches on and off when the handgun is closed, is quite common. Unfortunately it has at least six different possible causes, only two of which are easily checked.
The first thing you can do is look for leaks.  Even the slightest leak will cause this pulsing because the unit gets up to pressure, switches off, loses pressure, switches back on again, comes back up to pressure, switches off... and so on.  This repeated switching is not good for the motor and should not be allowed to continue for longer than necessary to observe what's happening.
So... 1. Does the handgun shut off completely, or does it drip? If it drips, it may simply be because a seal has failed. The handgun can be dismantled, checked, and any defective parts replaced; be sure to lubricate O-rings with silicone grease when reassembling. As a last resort, the whole gun may need to be replaced.
2. Are there any visible leaks at the high-pressure hose screw connections?  If so, most likely an O-ring needs replacing - again lubricate the new one well with silicone grease.
3. If there are no visible leaks, either from the gun or from the connections, all other possible causes are internal within the cylinder head or control head of the pump. New parts will be needed and this normally calls for a professional repair, although it's not beyond the scope of a truly competent amateur.
I hope this helps. Any further questions, just ask! Please remember to rate this response.
Posted on Apr 17, 2009
  • 92 Answers
SOURCE: I have a karcher K3.98 pressure washer. The unit
Dear davedulmage,
To see if the unit is OK....first you must switch it on without water and without high pressure hose and gun. If machinr works smoothly, try by attaching a water supply. Now run the pump with water coming out of the outlet. If also in this case all runs smooth, then attach high pressre hose with gun but without lance. Put on the machine with gun open(to reduce initial resistance) and when you see a clear flow of water coming out...close the gun. The machine should stop. In this case I am suspecting that when you open again the gun the machine will not work. So it seems that when pressure is built in the pump a fault is occuring in the Spill Valve or also called Control Valve. When the gun is closed and pressure built up, this spill valve contracts and switches the pump off. When the gun is opened, the spill valve extends, putting the machine on and closing a valve at the base of the spill valve. So in your case it seems that the spill valve needs to be renewed. A spill valve gets stuck by incorrect using of the pump. For example leaving the pump with pressure in it for a long time. Also it gets stuck by detergents and chemicals. Sometimes I lubricate Spill Valves with high quality silicon grease....but it is much more practical to change it. When a new spill valve is put in....always run the pump with no load. This by usiing the gun without lance or wands, resulting in low pressure. If all OK...add a lance or wand that you are sure it is good. One final thing....to get to this spill valve you must put apart the body and expose the pump. If you are not that good at doing this job...it is better done by a more knowledgeable person. But changing the spill valve is worth it....because it is cheaper than a new machine.
Regards,
Fulltech.
Posted on May 21, 2009
  • 104 Answers
SOURCE: My Karcher high pressure sprayer is delivering intermitant pressure.Every 15 seconds or so it developes high pressure for only about two seconds. Why is it not delivering a constant high pressure stre
Check that the water supply is constant , it sounds like the pump might be pushing out more water than can be delivered , or it could be a dirty inlet filter
Posted on May 23, 2009
  • 104 Answers
SOURCE: Karcher K 3.68M Electric Pressure Washer. Wand trigger Locks Up.
Sounds like the pressure valve is broken thats why you cant depress the trigger , the valve is on the pump , i would suggest taking it to a repair shop as they are fiddly things to fix
Posted on Jun 05, 2009
Karcher K2.36 motor cut out and won't restart
Yes, the water should be turned on first but if it only ran for a minute or two it should be OK. Most late model pressure washers have an automatic shutoff when the trigger on the wand is released. Turn on the water and then the machine and then squeeze the trigger on the handle of the wand and the motor should start as soon as the air is cleared from the line by the flowing water (about 10 seconds). If the unit was put away wet last season you may need to clean the nozzle with a piece of wire too.
Apr 16, 2010 | Karcher Garden
Karcher k1 leaking from inside casing.
The most likely issue, which seems to occur alot with karcher, is a cracked water pump. What happens is that as you release the trigger on the handle, the rise in pressure should cut off the motor, but as it also cuts off the water flow at the wand end and the motor spins a few more revs until it stops, then there is a huge pressure glitch which blows apart the weak plastic pumps that they use. Since the plastic cracks it is very difficult to repair and the only option is to go and buy another. BUT...this time tape up the trigger on the handle so it is always on and then it won't blow itself up. Just use the unit on/off switch to turn the motor on and off.
Apr 11, 2010 | Karcher Garden
Poor pressure and water comes out of the detergent hose
replacing the wand wont solve the pressure problems, its going to be the pump problems, pump create high pressure to the wand. hope that help
Jul 21, 2009 | Karcher 2500 PSI Pressure Washer
Karcher pressure washer trigger problem
The wands that it will not run with would most likley have a little dirt in the tip of the nozzle. This would not allow the water to flow through in turn activating the pressure switch and shutting the machine down
Troy
Jul 05, 2009 | Karcher K2.26 Electric Power Washer
Jun 04, 2009 | Karcher PSI Electric Pressure Washer
Cant change the high pressure hose on a Karcher
On the Kärcher, you have a bayonet mount at the base of the tip end of the pistol grip. This is where you attach different types of nozzles and gadgets after having removed the existing sprayer tube. Just push in and turn a quarter of a turn, then you pull it off the pistol grip. The hose is possible to remove from the machine as well, an ordinary threaded mount but since you need the pistol grip to regulate on/off this is probably not what you want to do. If the telescopic wand is made by Kärcher it should be very easy to snap it into place just like when you removed the sprayer tube/nozzle. If the attachment was made to fit Alto washers there is an inexpensive adapter that works very well. Good luck!
Jun 03, 2009 | Karcher G 2600 VH Gas Pressure Washer
Karcher 520M Pressure washer won't operate at high pressure
I had the same problem - good water inlet pressure, no output pressure, even though the lance and handle seemed to be clear and working find.
I found that the electrical switch wasn't being operated correctly by the spill valve and wasn't turning the motor on/off correctly.
Inside the plastic electrical box there is a small white device that presses against the micro switch assembly. Carefully adjust the allen screw perhaps 1/4 turn out or 1/4 turn in to obtain correct operation of the microswitch - you will hear the micro switch clicking in and out when re-assembled. I'm sure they must have a rig to check correct positioning of this screw in the factory!
Hope it helps - mine is working find now and saved me buying another!
May 05, 2008 | Karcher 2500 PSI Pressure Washer
Got a karcher 410 water pressure passed down to me without directions need help working it
Fairly simple to opperate. Connect water supply hose. Connect wand hose. Plug in, turn on water supply and turn on. Then squeeze the wand handle to spray. With mine, there are times when the unit looses pressure, but if you leave it running, it seems to recover. Also note that you can turn the flare at the end of the wand for a soft stream versus pressure spray. I have had mixed results with the pull out clear tube that is supposed to siphon liquid soap into the mix.
Apr 05, 2008 | Washing Machines
Karcher K2.26 Electric Power Washer Logo
220 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
