Question about HP LaserJet P3005 Printer
I need to install my P3005 without disc - HP LaserJet P3005 Printer
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 127 Answers
The HP website almost certainly has a download which will do this. Go to 'support' and 'downloads', and try to find your printer under the correct Windows version. This usually works with no problems.
Posted on Jun 27, 2009
Hi I have 2 hp p3005 wich wont apear in windows
Hi
I am quite sure the computer's operating system is not detecting the printer when you try to plug it. I suggest you try to repair the operating system and if still the same, you need to install fresh operating system your operating system.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
May 12, 2011 | HP LaserJet P3005n Printer
Print both sides using hp laserjet P3005
I assume that printer is perfectly installed and
for both side printing,
go to
contro panner ->printer and faxes->right click on printer->select properties->at bottom click on preferences -> choose "duplex printing".
if you cannot duplex printing here need to install duplex printing.
Mar 04, 2011 | HP LaserJet P3005 Printer
HP LJ p3005 dn printer will not recogonize hp print cartridge.
you may use a non genuine toner cartridge, check another working cartridge
Mar 30, 2010 | HP LaserJet P3005dn Printer
Got a new laptop and need to connect the hp laser jet p3005
Hi Terry_preyse !!
Thank you for writing to Fixya.com.
To setup a printer you'll require:
  • A Printer
  • An USB cabel or Wireless Card(if want to setup wireless printer)
  • Driver disc & it'll be shipped with the Printer
  • Last but not least, 15-20 minutes.
Unpack the printer carefully, plug the USB cabel in the printer. Don't connect it to the computer & turn on the Printer & here's what you need to do.
  1. Step 1 Set up your computer on your desk so that you are able to plug in your printer and other accessories in an orderly way. The PC is the center of your home office and all things should be setup in relation to this. Consider how you’ll run cables before selecting a location.
  2. Step 2 Assemble your printer. Few printers are ready to go out of the box. Open it up carefully and pull out the quick setup instructions. This usually entails affixing trays and installing toner and drums.
  3. Step 3 Decide on a method. Wired or wireless? Wireless will save you a lot of hassle but if you are on a tight budget wired does the job as well.
  4. Step 4 Install the drivers. Insert the CD that came with your printer into your computer and install the drivers before connecting your printer.
  5. Step 5 Connect with cables. Using a USB cable or a parallel cable, connect your printer to your computer. USB cables have a trapezoid shaped plug on the end that goes into the printer and a rectangle shaped plug that goes into the computer. Parallel cables will have holes on the computer end and pins on the printer end.
Hope this will help !
Regard's
Anurag Shukla
Sep 03, 2009 | HP Hewlett Packard LaserJet P3005 Printer
In HP LJ p3005 DN Printer when i given to selftest continious blank page comes i have checked using change scanner assemblay and formetter but problem not solved pls suggest what to do
try removing the cartridge shutter, maybe is not opening. if after that you continue with the same issue without any errors there's a chance it would be the power supply
Aug 18, 2009 | HP LaserJet P3005 Printer
HP p3005 printer cartridge error but cartridge is ok...how to solw this error..
The cartridge is not ok. Just because you replaced it doesnt mean its a god cartridge. You installed a bad cartridge so replace it and get your money back for the old one. P3005 printers are very intelligent!
Jul 15, 2009 | HP LaserJet P3005 Printer
HP LaserJet P3005 Printer Logo
87 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
