Question about Hitachi Televison & Video
I need a YSUS and a Y Upper and Y lower.\r\n
I found a YSUS - need assistance with finding the other two parts.
    President:
  • 1,197 Answers
Hi u can get the upper and lower boards from the below links....
http://cgi.ebay.com/LJ41-02760A-LJ92-01202A-Upper-Y-Buffer-Board-Plasma-TV_W0QQitemZ280340239386QQcmdZViewItemQQimsxZ20090430?IMSfp=TL090430125004r18157
http://cgi.ebay.com.sg/LG-V6-PDP-Plasma-TV-Repair-Y-Drive-Lower-6871QDH067B_W0QQitemZ270213919928QQcmdZViewItemQQptZUK_AudioTVElectronics_Video_Televisions?hash=item3eea0134b8&_trksid=p4634.c0.m14&_trkparms=|301%3A1|293%3A1|294%3A30
if ur planning to get it as a set so u dont have to worry abt compatibility issues.... try the following link
http://www.kpcomponents.ca/product_info.php?cPath=65&products_id=645&osCsid=e32ce736bca02999a90994bc3a8e0730
personally i wud suggest the last link as the items bought on ebay are not that very reliable....
shud u have any issues feel free contact us.....
kindly rate my service.... good luck and have a nice day
Posted on Jun 27, 2009
Only lines on upper part of the my screen
With the limited information on your issue and no voltage checks from within the TV, the best I can do is suggest the following.
sounds like a Ysus board issue and/or Zbuffer issue.
If it's the Zbuffer, change the Ysus card along with it as it could be the reason why you are having buffer problems.
While a buffer problem alone will not affect the Ysus card, a Ysus card issue will continue to blow Zbuffers if that's all you change.
check to see if it's still under an extended warranty, if not, then find the service manual for your model online and see if this is something you want to DIY.
Nov 23, 2013 | Vizio VW37L 37 in. LCD HDTV
Picture went out on Vizio P50HDM
Check you voltages before just swapping out boards. Although a YSUS is common for no picture, so is your upper and lower Y Buffer boards or the panel itself. Check youe -VSC voltage. Does it look like it is being loaded down? If so then your YSUS is not the problem. You can run the set with just the upper or lower Y Buffer boards untill the load is gone. That will let you know wich board to replace.
Jun 20, 2012 | Vizio Televison & Video
6871QYH953A YSUS MAXENT Plasma. Replaced IPM on YSUS and 2.5 months it went out again. Have any suggestions what is causing this issue?
Hello Greg Y,
The POP came from the part that is under the big heatsink, That part fails due to heat.
I would recommend to add a cooling fan on top of the heatsink to keep the temperature lower and that would extend the life expectancy.
Find a 9 to 12 volts source to connect the fan if you decide to install it.
Let me know if you need further assistance.
Aug 30, 2017 | Maxent MX-42HPM20 42 in. Plasma HDTV
Screen got black lines across it
Across vertically or horizontally... It makes all the dif. It could be 3 boards on the set. The YSUS-main the YBU-upper/YBL-Lower. The Y buffer upper controls the top half of the screen, the Y buffer lower the lower half and the YSUS-main controls those 2 boards. They work in unison, when one goes they all fail. The other possibility is dry solder joints on the the D, G, E, F boards. All you would need to do with that is reheat the solder joints at the ribbon cable conx.
Best Regards and Semper Fi
Aug 06, 2010 | LG 42LC2D 42 in. LCD HDTV
My tv lost its color and has a black spot on the screen, can I do to fix it?
Sounds like you YBU-YBL (Y-Buffer Upper-Lower) and the Y-SUS/Main is out. The Y buffer upper controls the top half and the YBL the lower half. The YSUS control all of this. The YSUS is also connected to of course the Power supply board and the logic board.
Jun 30, 2010 | LG 50PX1D 50 in. Plasma Television
My 5 years old Plasma TV found half of the screen picture view not very clear.. The half colour seen blur..
Your Buffer boards or the YSUS main are bad. THe YBU-Y Buffer upper controls the top half of display, the YBL-Y Buffer lower controls the bottom half and the YSUS Main controls both those boards. They are located to the Far Left on and opened Set.
Jun 21, 2010 | Philips 42PF9966 42 in. HD-Ready Plasma...
LG Tv 50PQ30 the lower half of the screen intermittely stops working
looking into the back of the tv with the cover removed, there is 2 boards on the far left the run down the back of the screen. These are the Ysus buffer boards.They both plug into a larger board (Ysus). Make sure that the bottom buffer board is pushed into the Ysus properly and that the wired lead connecting the upper buffer board to the lower buffer board is pushed in firmly.If this doesnt solve the problem then you will most probably have a faulty lower buffer board.
Feb 20, 2010 | SNK Magnavox 42MF231D 42 in. Plasma TV
The lower 2/3 of screen is black! Help...
Sounds as if the YSUS circuit board may be defective or the panel itself
Dec 15, 2009 | Insignia 50 in. Flat-Panel Plasma HDTV
Philips 42PF9630A/32 Plasma TV RED led blinking 7 times
Are there any blown caps on the PSB-power supply board. Most sets have sammy boards and they used very shotty caps. If there are no visual clues being a poped cap at the top (X) they simply often do vaporize and dry out. The YSUS-Main and the 2 Y buffer boards control the picture OSD-on screen display. Your not getting any of that. So power supply is where you start first. The YBU-upper and the YBL-lower control the upper and lower OSD the Ysus main control both of them. Usually if you have one in the door you have to replace all 3. But not always. If you were to replace any of the boards I would replace the YSUS-Main, or get the board reworked at a pc repair shop that does board level test and repai. Its more cost effective.
Oct 12, 2009 | Philips 42PF7220A 42 in. Plasma Television
50 " Phillips Plasma tv. Screen is black, blinking red light.
Sounds more like blown/exploding capacitors on the PSB-Power Supply board. No OSD-on screen display a blinking led or chatter/relay clikcing at startup is the tv going into fault protection and bypassing the startup pins. The YSUS-Main controls the pic which is attached to 2 buffer boards the YBU-upper YBL-Lower. They control the upper and lower portion of the OSD and the YSUS controls both of them. Since you're getting No OSD you need to check for blown caps on the PSB first. Unplugging the set resets the error again. So you start all over again.
Best Rgards and Semper Fi
Dec 19, 2008 | Philips BDS 4611 46 in. Plasma Television
Televison & Video Logo
42 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
