I've bought the Sumvision SATA net-box NAS enclosure, installed hard drive as described, but I cannot see the web interface for setting up the device. Manual is in very bad english and suggest allocating an IP address to the device, but I cannot see the device on the network. Any ideas how I can get to the web page to configure everything?
Just setting one up here.
Had this problem, I had to set PC IP address to same sub net as NAS box i.e. 192.168.0.x
Then reset NAS address to same as normal network, changing PC back as well.
Can now see NAS web admin from any PC on LAN, but cannot see it to map network drive!
Posted on Jul 23, 2009
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 127 Answers
There's a discussion about some problems relating to this enclosure at http://forums.ebuyer.com/showthread.php?t=24636 and you may be able to get some help from the contributors there.
Posted on Jun 27, 2009
Tip
Troubleshooting WD Passport 320 GB External USB 2.0 Hard Drives
If you plug your Western Digital Passport External USB 2.0 hard drive to a USB socket in your computer system, & the hard drive's light is on but there is no spinning sound, then you might be experiencing a defective interface circuitry.
These devices have a USB-to-SATA interface inside their enclosure. If you can find another enclosure with a similar interface (or buy a new enclosure), disassemble your hard disk enclosure, get the hard drive out & attach it to the interface in the other enclosure & see if it works.
Another possibility is that the interface could be fine, but the hard drive itself died. To test this possibility, try attaching the hard drive itself (after getting it out of its enclosure) directly to a PC. Since the hard drive is a SATA drive, you will be able to do this easily.
on Dec 01, 2009 | Western Digital Passport 320GB External...
I just bought a Dell DHS computer without a harddrive at a yard sale, how do I install a hard drive for it
First you have to make sure you bought the right kind of hard drive (IDE or SATA) to make the installation and connection easier. IDE drives have a set of prongs or pins that stick out. SATA is the later type and does not have prongs or pins sticking out. You just turn the laptop over and remove the cover where the hard drive will be housed. Usually it will have an icon of 3 circular discs on it. Most laptops will also require a Caddy that the drive sits in before it goes into the laptop. And some might require a interface.
I suggest you look on ebay and see if your computer's make and model requires a hard drive caddy or interface.
http://www.ebay.com
In the search box just type your computer's make and model followed by hard drive caddy. Example: Dell Latitude D610 Hard Drive Caddy
In the search box type this is see if it requires an interface: Example: Dell Latitude D610 Hard Drive Interface
May 20, 2012 | Computers & Internet
I'm trying to install a Western Digital Serial ATA Hard Drive into the external hard drive enclosure. There are no instructions as to what cables need to be attached and to where
USB external hard drive cases are supplied with SATA and power connectors attached to the circuit board in the case. If you canot connect it to the SATA hard drive then you may have the wrong drive case, your case may be a IDE or SCSI type.
Jul 07, 2011 | NexxTech 1 Bay USB 2.0 External Drive...
My WD external drive is plugged in, and my computer keeps saying that one of the usb devices has malfunction and is not being recognized. I have very important data on this drive. How can I fix this...
The problem may not be with the hard drive itself but with the interface between the drive and the USB port. The drives in most cases are fine if they have not been dropped or abused. The problem with external drives is usually the small circuit board that contains the sata to usb interface. Try purchasing another external hard drive enclosure and remove the drive from the enclosure you now have. There are guides on youtube to show you how to take one of those WD enclosures apart. Just install the hard drive in the new enclosure and load the driver files that come with the new enclosure. You should have a working external drive....as long as the hard drive has not failed.
Aug 11, 2010 | Western Digital Computers & Internet
I cannot get an external hard drive to work on mac
sounds like the Hard drive is not formatted for the MAC
Mar 23, 2010 | Computers & Internet
I have a 320gb WD hard disk and it was working normally but few days ago when i plug it, it could not work. ( the light is on but there is no spinning sound)
Seems to me a defective interface circuitry.
Another possibility is that the interface could be fine, but the hard drive itself died. To test this possibility, try attaching the hard drive directly to a PC. Since the hard drive is a SATA drive, you will be able to do this easily.
Aug 28, 2009 | Western Digital Passport 320GB External...
Sumvision nas not on my network
do you install new drivers for enabling net work
Jul 17, 2009 | Computers & Internet
Help
An external USB drive consists of tow parts:
a hard drive (usually a standard IDE or SATA drive), and
an enclosure
The enclosure is the box containing the drive. It also includes an interface to convert the data from the IDE or SATA interface on the drive to a USB (2) signal. Some enclosures include and internal power supply. The Freeagent has the power supply externally.
Hope that's what you mean.
Sep 08, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Computers & Internet Logo
430 people viewed this question
Alun Cox
David Payne
David Payne
