Question about Goodman CKL30AR30 Air Conditioner
I have a 16seer ssx16 goodman air conditioner need wiring help.
    Guru:
  • 462 Answers
I dont have long but what exactly do you need to know about wiring?
Posted on Jun 27, 2009
Can i wire a goodman heat pump for straight cool
yes use yellow and blue yellow is the compressor wire 24vollt positive and blue is common 24 volt negative , put wire nuts on the other wires
Aug 11, 2012 | Goodman CKL30AR30 Air Conditioner
I need wiring digram for this unit
Your best bet because of the age of the unit is to contact Goodman technical support, you will need a model # and serial # for the unit, the number for them is 888-593-9988.
They should be able to E- mail it to you or fax it .
this should help.
Jul 27, 2011 | Goodman CKL36AR36 Air Conditioner
Goodman GPM075-3 air conditioning connections
your thermostat powers 'Y' for cooling. That in your case blue wire connects to 'Y' on the control board in the furnace. Then a pair of low-voltage wires connects 'Y' and 'C' on the furnace to the two wires to the coil of the contactor in the a/c condensing unit. So to follow the path, the signal wire from the thermostat sends 24v down the Y wire to the furnace board Y terminal which also connects to one side of the contactor coil in the air conditioner. To complete the control circuit to the air conditioner there has to be a common wire. This is connecting the C wire from the furnace board to the other side of the contactor in the air conditioner. Hope this helps.
Dec 11, 2009 | Goodman Heating & Cooling
New goodman pkg heat pump i wired up 2 brand new
You may have defective tstat wiring, or a bad control fuse. Check both.
Jul 30, 2009 | Goodman CKL24AR24 Air Conditioner
Pressure reading for goodman a/c unit ssx16 5 ton unit
lp-860kpa hp-@2400kpa . For inverter a/c it will vary according to ambient temperature and max to those pressures
Jul 23, 2009 | Heating & Cooling
How do i wire the control panal
Go to the Goodman web site> Goodman bought Amana. Go to Tech support. Download wiring diagram. Rusty
May 16, 2009 | Amana PTC123B50AJ Air Conditioner
Goodman SSX16 split system not working
Defective thermostat wire.
Defective contactor.
With the t-stat set for cool and turned down on a low temperature, check for 24 volts at the contactor low voltage hookup. If you have 24 volts, replace the contactor.
You can manually close the contactor to make sure the high voltage is going through it.
Apr 28, 2009 | Goodman CKL60AR60 Air Conditioner
Put the top back on the unit
use tape or zip ties to hold them up and should be fine as long as the blade doesnt cut the wires your fine
Sep 10, 2008 | Goodman CLQ36AR49 Air Conditioner
Warm Air in Cooiing mode
Warm air in cooling mode usually means that the thermostat needs to be set to energise the reversing valve in cooling. To do this is simple just by opening the stat and moving the selector switch to o. Everything else will wire color to color. r-r, g-g, y-y, o-o, w-w and brown. If you want the heat strips separate wire brown to emergency heat on thermostat. Hope this helps, RepairUSA
Aug 31, 2007 | Goodman CLQ36AR49 Air Conditioner
Goodman CKL30AR30 Air Conditioner Logo
220 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
