Question about Toshiba Satellite A215-S4747 Notebook
Screen goes black but have faint image in background
  • drirish51 Jun 27, 2009
    it boots up normal, sometimes it works for a min or two sometimes 2o min then goes black with a screen in the background if you look sideways. Have to re boot because it dosent shut down right. Had the same problem in Hawaii on the same unit. Inverter???
    It boots up normal, can check e-mail and do what ever the just goes black but the screen I was working on can be seen in the background if you look at it at an angle. mouse moves etc. have to shut down and re boot. get a screen that say comp not shut down normaly or a fix start up message.
    Problem Solver:
  • 8 Answers
Does it boot up as bright as it used to be and then go faint or has it recently only been faint?
If it's the latter it sounds as though the lamp has gone. This can be fixed more often than not, but can be a bit expensive.
Is the laptop still under warrenty? If so go back to the manufacturer or if not you should take it into a computer shop to get a quote on fixing it.
Regards, Chris
Posted on Jun 27, 2009
  • j0llyc
    j0llyc Jun 27, 2009
    It definitely is the screen that goes black, it isn't shutting down by itself? I'll assume it is staying on and that the display becomes faint. It could be the connection or the backlight itself. Either way you would need to take this to your local comptuer technician for them to take a look and give you a quote to repair it. If it's really old, you might even consider buying a new laptop.
    Consider the cost/benefit of repairing this laptop and how many more years or months you expect to get out of it. Then compare the same money invested in a new laptop. This is obviously upto you but think about it. Wouldn't be a bad idea to take it into a computer shop to get a quote first. That might help you with your decision.
    Good luck,
    Chris
  • j0llyc
    j0llyc Jun 27, 2009
    Yeah sounds like you need to replace the screen. Take it into your local computer technician to get a quote, if you want to fix it.
    If you're happy to keep it in one place at home, you could always connect a monitor to it and use that for your display.
2 Suggested Answers
  • 99 Answers
SOURCE: inspiron 1525 screen goes black,
Sounds like the backlight for the screen has died the part isn't that pricey but having it put in will probably cost almost as much as replacing the laptop. You can always plug into an external monitor, however that is not very portable
Posted on Oct 11, 2010
My 2 year old viore led tv model led32vh30 has a grey screen with the image faint in the background. Any home fixes would be great. Thank You Kyle
unfortunately the faint image can not be fixed it is caused by the light burning it into the screen due to the image being static you need to replace it
Nov 03, 2013 | Televison & Video
I have lenovo g550...my screen flickers in every 5minutes...
Failing Inverter An inverter, typically found inside a laptop computer, consists of a small board, which has impregnated electronic circuits stamped on it. Inverters look like thin boards about the of two sticks of chewing gum. The inverter and its bulb control the intensity of the liquid crystal display, which lights the screen monitor. The computer can control the output voltage of the inverter and either lighten or darken the screen. A special type of inverter can adjust the brightness of the screen by using an internal sensor to judge the room brightness, and then adjust the screen accordingly. Failing inverters give off some specific warning signs, which can be recognized by observing different screen characteristics.
Short Intermittent Display Upon turning on the laptop, the screen flashes on in the normal mode for a short period and then blinks to black. A very faint image appears in a dark background, which will be very hard to see almost invisible. After shutting off the laptop and restarting, the same mode occurs, where the screen appears normal for a few seconds then fades to black. This condition points to a failed inverter. To confirm this, plug in an operational external monitor; if the external monitor functions, the inverter has failed. b> Total Blackout with Ghost image b> The laptop turns on, as indicated by the power supply button, but the screen comes up black. The screen comes up black after restart. You might be able to detect a very dim or ghost-like image on the monitor. When you plug in a known functioning external monitor, the external monitor operates normally. This mode of display indicates a failed inverter. b> Long Term Periodic Operation b> With this failure mode, the laptop screen illuminates normally upon start-up and remains that way after several minutes, hours or even days, until it goes very dark again. Brightness controls or restoration attempts do not work. Most often, the screen will function normally with a computer restart, but will eventually return to black. Faint ghost images might appear, as seen in the total blackout mode. b> Dark With Color Variation b> Upon computer start-up, the monitor shows black or dark gray, accompanied by very faint images. The screen might have an intermittent color change, or remain on with a non-standard color variation, like pink or red. b> Auto Control Switch b> If the screen appears black, with no faint or ghost images, look for the lid switch near the back hinge. The switch, when depressed with a closed lid, shuts off the computer and monitor functions. Sometimes the switch becomes stuck in the closed position, disallowing the computer and monitor to turn on when opened. Pushing the switch manually several times can often free it up. If the switch tab has broken or jammed inside the case, it needs replacing. b> Loose Connection In this mode, the display looks normal upon start-up, but tapping the side case of the computer turns the screen black. More tapping results in the screen functioning normally then cutting out again. This condition points to a loose wire connection from the inverter to the LCD backlight lamp, or the video cable. The connectors can be accessed by removing the monitor bezel screws and pulling the plastic retainer off. Both connectors can be cleaned and refitted.
Feb 10, 2013 | Lenovo G550 PC Notebook
No picture but sound
Turn on the set and get a strong light and bring it up to the screen. Do you see a faint image on the screen? If you do, then your backlight has failed. It may be one of the many lamps, or the inverter circuit or the power supply for the lamps.
The colored lines usually indicate a broken screen from an impact...unlikely unless someone hit the screen just before the picture went out.
Apr 22, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Picture goes black but still has sound
Use a strong light next to the screen and look for a faint image on the screen. If you see a faint picture, your backlight has a problem. Service shop time. Not a simple fix.
Mar 25, 2010 | Televison & Video
Image goes to black on Sharp flatscreen.
An LCD unit? Sounds like the backlight is failing. When it goes black next time, use a strong light next to the screen and look for a faint image on the screen....
If it is the backlight, its a service shop issue.
Mar 23, 2010 | Sharp 19 in. LCD HDTV
Faint image in the background.
Hi Nate,
The same thing has happened to me before.
Well, once you drop your laptop a lot of things could go wrong. From a broken driver to a cracked screen. I believe you broke your bulb. And the cells of your laptop are kinda messed up we can say. Yes, this is fixable but will take time. I hope everything goes better!!
Good Luck
**dont forget to rate**
Jul 10, 2009 | HP Pavilion xh555 (F3929H) PC Notebook
The screen went blank while the computer was on, we restarted it, the screen shows the Dell sign & the white bar then it goes blank, it won't go into safe mode, the light is green on the monitor, what...
If there is a faint image in the background it is the coils on the planar if no image it is either the invertor or the backlight
If you have a faint image resolder the coils or replace them
Dec 15, 2008 | Dell Dimension B110 PC Desktop
Two problems vx922 Black screen of Death and vx910 no power
You may want to tey another computer or another cable or update your video card drivers. Otherwise look very closely and see if you are able to see a very faint image of your background picture or icons if you have any.
Really im not kidding it might be a backlight issue.
Nov 18, 2008 | ViewSonic VX922 19" Monitor Flat Panel
Good picture for 30 seconds then screen goes black with a faint ghost of the image
the 12V is for speakers.. the 245bw takes regular 120V AC (same cord as your computer)
the buzzing is annoying, though. i don't know if it's a "feature" or just a side effect.. ie, if i could take the case off and poke around, i would. 4 times out of 5 it's some dumb piece of tin reverberating from a transformer or something..
Dec 03, 2007 | Mag Innovision LT576s 15" Flat Panel LCD...
i hope the problem will be in LOT of the monitor...you need to replace the LOT
Jun 14, 2007 | Mag Innovision LT576s 15" Flat Panel LCD...
Toshiba Satellite A215-S4747 Notebook Logo
290 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
