Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint aquarius 1200 washing machine leaking
Checked inlet hoses, outlet hose, pump and door seal all ok. the concrete block under the drum is wet at the front door side
  • 82 Answers
This could be
1 door seal
2 heater ellement
3 front plate
4 front plate seal
5 outer container split
try looking at these first
Posted on Jun 28, 2009
Hotpoint Aquarius WMA58 (about 16 years old) is leaking, seemingly from under machine (back looks dry), and leaving clothes wet after spin cycle. Door seal seems sound.
no not worth repair at 16 years old
its got issues with aging worn motor
not spinning fast enough
door seal if you can buy one
may not be the water leak fix
time to replace the washing machine
Mar 06, 2017 | Hotpoint Washing Machines
Hotpoint washing machine wdd960 is leaking from underneath.
either tub has a leak or one of the hoses has a leak somewhere? if u remove the cabinet then run machine u can see and locate ur leak more easily? by the way a tub leak can be repaired some times with some water proof selant
Jan 09, 2015 | Hotpoint Washing Machines
Hotpoint Aquarius Extra washer dryer WD64 will not drain water. Spin works ok.
Was it working before? You may have a blocked outlet hose. Try taking it off under the sink to look for a blockage. You could also try getting some water in from that end with another hose to see if it comes out into the machine. If it is not a blocked hose, then the pump may be faulty.
Dec 09, 2010 | Hotpoint Aquarius WD640 Front Load...
What does f-5 mean when flashing at me and won,t let me have my washing out the machine also washing really hot after a fast spin programme
if water is in drum then door wont open,drop drain hose to floor level into bucket to drain manually, then check filter or pump is it running ok if not is it stuck some thing in it , hot wash is cold water inlet ok or is this due to again faulty pump ...
Jun 25, 2010 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aqurious leaking at front underneath,concrete block wet at front towards door,alot of water coming out,any ideas thanks.david
Carefully check the door seal for any sign of a hole or tear in the seal.
Or it could be leaking from the drum front or the drum front seal, this is another seal , not the door seal., you cannot see this without removing the front panel.
Feb 22, 2010 | Hotpoint Aquarius WD63 Front Load...
My hotpoint aquarius washing machine wont pump out the water
HI.
You need to check the pump filter.
Remove lower rear panel of washer.
Remove large black hose fastehed to bottom of drum
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Check drain out let hose is not blocked.
Please rate my solution/.
Thankyou.
Jan 28, 2010 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aqarius mod no wm63x all machine functions fine drum wont spin
check pump/filter/outlet hose is not blocked. if ok check the brushes in the motor.
Oct 21, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Drum keeps filling with water even in dryer mode
Open up the top of the machine. Plug off the wall mains. Turn off the wall faucet. How is the wire connection for the inlet valve, the water inlet. Fine? If not unscrew the inlet valve from the corner of the machine after disconnecting the hoses, & dismantle to clean it up, re-assemble, refit back to machine.
Mar 27, 2009 | Hotpoint Aquarius WD640 Front Load...
Not draining
Check the inlet hose to the pump from the drum, make sure it is not blocked, remove outlet hose and run water through it.
If these are clear and the filter is clear, you need to establish that the pump itself is o/k.
Select drain and see if you can hear the pump running, if you can't, then you need to check that is getting a mains feed to it.
If feed is there, then the pump is faulty. Replace
If no feed ,then you need to look further.
Plz rate my solution.
Thanks.
Dec 30, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint Aquarius 1200 Washer Dryer not drying.
Hi, I think the problem you have is with the cold water inlet valve? When your machine dries it uses a small amount of water at high pressure through a restricter fitted in the water inlet valve. These break down letting in to much water which cannot evaporate quick enough for it to pump out causing the washing to become wetter than after the wash/spin cycle. The only way of solving this is to replace th tree way water inlet valve. But make sure that the pump is working ok first and that there is nothing in the sump hose trap which is located underneath the washing machine out the bottom of the tub.
Good luck.................
Dec 28, 2008 | Hotpoint Washing Machines
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
543 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
