Question about Masterbuilt 20070411 30" Electric Smoker with Window
Why am I getting an EAA1 error after 5 minutes of first use?
I am getting a EAA1 error when trying to pre-season my smoker for the first time. It heats for 5 minutes then displays the error code on the control panel.
  • Greg Cohen
    Greg Cohen Nov 22, 2018
    DJstuff. Thank you your post was dead on. I took my pillow dryer to the heating sensor for like 2 minutes it worked thanks
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
READ FIRST!
Before trying any of the lengthy suggestions regarding repairs on Masterbuilt electric smokers, consider this. It APPEARS (based on testing, not reverse engineering) that Masterbuilt designed the controller on my unit (140S) to error out below a certain minimum temperature. If you are like me and have your smoker outside (as you should), but in sub freezing temperatures, you too may get this error. Just shoot the short temperature probe (on the back wall of the cabinet) with a hair dryer for a minute or two. Then plug back in for no error (assuming you do not have an actual wiring or probe failure). Just make sure to immediately start it heating before it drops too low again...
If this was by design, shame on Masterbuilt! If this was by error, shame on their engineers! If this behaviour is due to an intermittent problem with my unit, shame on me for not fully testing all possibilities once I found an easy fix...
Posted on Jan 01, 2018
    New Friend:
  • 4 Answers
I have the same model and drew this schematic after taking it apart to fix another problem. An EAA1 means that the control display unit is getting a bizarre reading from the temperature sensor on the box. Could be a connector problem or a faulty temp sensor. The temperature sensor has a long path through the relay power supply board in the bottom then up to the control display unit. Unfortunately the only place you can easily check is the 5 pin connector directly under the control display unit. Try reseating this connector. The box can be opened up to check everything else but it's a real bear.
Why am I getting an EAA1 error after 5 minutes of  - am-getting-eaa1-error-after-5-minutes-ikij0vfbnwdrr1cqpqsto5nc-4-0.jpg
Posted on Aug 02, 2016
5 Suggested Answers
SOURCE: Masterbuilt Smoker Model 20070108 Digitial Controller not working. Worked the first time, then no power. I hear a beep when I plug it in, but no display.
I had the same problem this morning. I seasoned it two days agao with an outside temp. of 50. This morning it was 8 degrees and when I pluged it in there was no readout. I removed the digital unit from the top and heated it with a hair drier and it worked when I reinstalled it. I think it had some moisture in it although the unit has been covered the whole time. I am going to call Masterbuilt tomarrow and see what their answer is to this problem.
Posted on Jan 25, 2009
  • 7 Answers
SOURCE: used the masterbuilt smoker only 5 times???
I just bought a new Masterbuilt Smoker by default two weeks ago I borrowed a friend’s to smoke about 30lb. of Salmon to then can. Ran the smoker every day for three day. ON my last batch the heating element would not work. Talk about Frustrated! The Smoker was only 2 yrs. old.
Knowing I borrowed I felt I had to replace. So online to Cabelas and I ordered my buddy a new smoker and had it shipped. I then found this website... GOT TO LOVE the internet. I saw many other people had the same problem. Found an Answer...
The Problem was one of the connector to the heating element was poor quality and if you don't clean your smoker on a regular basis. The heat and moister caused the small copper connector to corrode and the wire to come loose. I took a wood chisel and cut off all the rivets on the back. I was then able to pull the back off with no damage and access the small box in the lower back. I found the connector. Went to the hardware store and bought a replacement for .75 cents. A pair of wire crimpers and the problem was fixed. I also bought ½ inch Sheet metal screws to secure the back it was good as new. So I returned the smoker to my buddy and kept the new one. When it arrived I saw Masterbuilt has since fixed the problem and provided an access panel to the element and connectors.
Mike in Alaska
PSU313@yahoo.com
Posted on Jul 03, 2010
SOURCE: masterbuilt electric smoker is brandnew
Had the exact same problems. I took off the electronic control unit and made sure the probe was still connected (unplugged and checked the pins for damage). After reassembling the unit everything worked fine. My guess is that the probe was not properly connected, therefore it was showing 32 deg all the time. Once it was properly connected, the actual temperature showed on the display. Hope that helps.
Posted on Mar 26, 2011
SOURCE: masterbuilt eletric smoker: the control panel
I have one that is 3 yrs old and just had the same problem. After reading other posts this is what I did. I removed the wood chip holder. This is accomplished by removing two phillips head screws from the holder on the right where it attaches to the inside wall. Then the are to small bolts that have to be removed where it attaches to the frame in the center. Now you should all of the heating element. Remove the two outer screws where it attaches to the back wall. Don't take out the center one, it attaches the ground wire on the other side. Tip the heating element up and gently pull it out, it won't come far and you should be able to see if one of the wires has burned through. The wire had burned off the right hand portion of the element in mine. To repair it you need to access it from the back. Take out the screws that hold the time/temp control on top. Drill out all the rivets from the back outside panel, remove the bottom screws from the drip pan holder, and pull the panel off. Towards the bottom you will see the back side of a small metal box that covers the heating element connections. Pull that box out. Get some blue or red rtv sealant from your local auto parts store Clean the area around where the element mounts on the inside, put some sealant on the mounting plate and remount it. This serves to make it water tight to help prevent corrosion inthe future. I chose the leave the connection cover off the backside. If you do that as well you might need to use small bolts to remount the element since the screws screw into that box. In order to remoun the element wire you will need a yellow male spade clip available at the auto parts store, home depot, etc. Strip about 3/8 in of the insulation of the burned wire, place it in the center of the spade clip and crimp the yellow part. Slide the clip onto the element end. Reattach the time/temp control, plug in the smoker and turn it on to see if it heats. You can lightly and quickly touch the element inside the smoker to check for heat, carefully of course so you don't get burned. Assuming it works, unplug everything, return to the back and use rtv sealant to completely cover the connections to the element. Wait for it to set up and recoat a 2nd time. Plug everything back in and do a 2 or 3 hour test run. If that goes well, apply rtv sealant to the back of the smoker and use #10 1/2in sheet metal screws to reattach the back. Good luck!
Posted on Oct 13, 2011
We started the grill for the first time to season it. Put it on smoke only with lid open until it began smoking, then closed the lid and turned it up for an hour. We are getting an error codeL.E.R.
See the link. In future, full make and model name is useful. Google seems to think it is a Traeger Pellet Smoker?
What is LEr? - BBQ with Drewbbqwithdrew.com/what-is-ler/Feb 28, 2016 - According to Traeger technical support, "LEr" is an error code that appears on the control display when your grill operates for 10 consecutive minutes without reaching 125°F (regardless the set temperature). ... It will likely occur if you've left your grill open, or have run out of pellets.
I am guessing that you left the gas tap on the bottle open all winter? When that happens the gas pressure drops, so you aren't getting enough heat. Also having the lid open will cause this because the heat was lost.
grill error code LER Google Search
Jun 23, 2018 | Grilling
We bought a new masterbuilt electric smoker. When we power it on, we get the message EAA1 and it shuts off.
Take off the electronic control unit and make sure the probe is still connected (unplugged and check the pins for damage). After reassembling the unit everything should work fine. My guess is that the probe is not properly connected, Once it was properly connected, the actual temperature showed on the display. Hope that helps.
Dec 23, 2017 | Masterbuilt Grilling
First time using masterbuilt 30" electric smoker, trying to season. Has been on set to 275 for 45 minutes and temp finally hit 100. What's wrong? Why is it heating up so slowly?
Unless you are in a VERY cold climate, you should be at 100+ degrees within a few minutes- even with all vents open. I know it should go without saying, but make sure the door is closed and latched/ with a good seal around the frame. I would reach out to Masterbuilt for a replacement thermostat/controller module.
Aug 27, 2017 | Masterbuilt Grilling
How long do i need to smoke ribbs
Depends on how many pounds you're smoking, as well as are they pork or beef? Country style or Baby Back? And how much smokey flavor to you want?
Baby Back Pork Ribs require the least amount of time, as they don't have as much beat on the bones as Country Style Beef ribs Never-the-less, my own personal theory of smoking meats is "Low and Slow." "Low" meaning no more than 225 to 250 degrees. "Slow" meaning at least 2 to 3 hours for Pork Baby Back Ribs. 4 to 6 hours for Beef Country Style Ribs.
The first 30 minutes to an hour time the crucial for smoking. That's when the fibers or the meat are most open and will absorb the most smoke. After that, you're basically slow cooking for tenderness.
Always wait until the last 30 minues to brush or mop on any BBQ sauce.
Seasoning the ribs prior to smoking is very important. Whether you use a dry or wet rub. The choice is yours. Once the rub is applied, warp it tightly in plastic wrap and refrigerate for at least 2 hours. Over night is better. Take the ribs out of the frig, unwrap them and allow them to come to room temperature before placing on the smoker. That way, the meat fibers will open some.
Once on the smoker, DON'T PEEK! Every time you open the lid, you loose smoke and heat. You want to try to maintain that 225 - 250 degrees without loosing it and having to bring the smoker back up to temperature.
Once you remove the ribs or any kind of meat, for that matter, let it rest for at least 5 minutes before cutting it. That way, you won't loose all those delicious juices.
The weekend is not that far off, so start planning now and enjoy the fruits of your labors, this weekend.
Hope this helps to get you started. Please let me know how they truned out. Or better yet, send me a sample to taste. :-)
Mar 01, 2011 | Brinkmann Smoke 'n Grill Double-Grill...
Masterbuilt electric smoker is brandnew plugged it in runs for about 5 minutes then flashes EAA1 and showing the temp is 32??
Feb 25, 2011 | Masterbuilt 20070106 Electric Smoker
I am getting the EAAF code. What does it mean?
The manual said to unplug the smoker and wait 10 secs and then plug it back in. I tried that and it did not solve the problem. However, I did leave it plugged in with that error code while I was searching the web for an answer. Over the next 5 min or so, the error code went away and my smoker started heating up as if it had no issues.
The solution may be to just let it sit for a few min and then it will begin on its own. The only variable I can think of is that I am smoking in cold conditions for the first time. It may be the case that since the smoker was outside in single digit temperatures, that may have triggered the error code. Who knows, in any case, I am back to smoking for Thanksgiving. Crisis averted.
Nov 25, 2010 | Masterbuilt 20070106 Electric Smoker
I would like to know if I need to pre season smoker and how to do that
I like to season my smoker before actually cooking in them. Here is how I would treat yours. I would wipe down all the grills and inside the cooking area with a vegetable oil. You can do this with a bottle of oil and a rag or do what what many do and just spray the whole inside down with PAM. Once this is done I would light the burner and bring the temperature up about as high as it will go for about 10 minutes and then turn it off. Once the heat is gone down to a point it is safe to touch, re-spray the insides. It should be ready to cook. Re-spray grills before each use.
Jun 21, 2010 | The Great Outdoors 3405BG
Need instruction on how to season masterbuilt electric smoker
soak some hickory/ oak / mesquite chips any one of these will do, soak them in water for a couple of hours then put them in the pan and turn it on this will burn out any coating on the metal and flavor the grill for smoking leave it on for a good 2-3 hrs on med then on high mke sure you keep the chips replenished
Aug 23, 2009 | Grilling
Masterbuilt 20070411 30" Electric Smoker with Window Logo
4,811 people viewed this question
Top Masterbuilt Grilling Experts
Ted-L
Level 1 Expert
Paul Carew
Simon Flummox
Simon Flummox
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
