Question about Cuisinart TOB-165 1500 Watts Toaster Oven with Convection Cooking
Cuisinart tob-165 dead OVEN
THIS UNIT WAS ACCIDENTLY CONNECTED TO 240VAC POWER. I REPLACED THE FUSE-LINK ON THE CIRCUIT BOARD AND REMOVED THE ZENER THAT BLEW THE FUSE. I NEED TO KNOW WHAT THE ZENER SPECS ARE SO I CAN REPLACE IT. I NEED THE ZENER VOLTAGE AND WATTAGE. THE CIRCUIT BOARD LETTERING FOR THE COMPONET IS "ZNR1". THE OVEN WORKS FINE WITHOUT THE ZENER BUT NO PROTECTION!
HELP!!!
PHIL BENSON
bodbenson@gmail.com
  • 5 more comments
  • bodbenson Jun 28, 2009
    HELLO!
    AGAIN, WHAT IS THE "ZNR1" CIRCUIT BOARD COMPONENT AND WHAT ARE THE SPECS FOR THAT COMPONENT? WHEN YOU PROVIDE ME WITH THAT INFO I CAN ORDER IT FROM MOUSER ELECTRONICS.
    THANKS
  • bodbenson Jun 29, 2009
    HELLO!
    YES! IT IS A PROTECTION DEVICE, BUT HOW DO I FIND A REPLACEMENT?
    THANKS
    PHIL
  • bodbenson Jul 01, 2009
    HELLO!
    DID YOU GET THE P/N "10N471K" FROM THE COMPONENT LOCATED ON CIRCUIT BOARD DESIGNATED AS "ZNR1" FOR THE CUISINART MODEL "TOB-165" TOASTER/OVEN? THE "10N471K" IS A 300VAC-RMS VARISTOR WHICH SEEMS HIGH FOR 120VAC OVEN. A VARISTOR P/N "10N241K" 150VAC-RMS SEEMS MORE APPROPRIATE. WHAT DO YOU THINK?
    THANKS
    PHIL
    BENSON
    TO: FAME-GURU (ONLY)
    HELLO!
    DID YOU RECEIVE MY LAST RESPONSE??????
  • bodbenson Jul 02, 2009
    HELLO!
    YES!, PLEASE SEND ME THE SCHEMATIC ON THE OVEN.
    THANKS
    PHIL BENSON
  • bodbenson Jul 05, 2009
    THE COMPONENT IS "VARISTOR" NOT A ZENER.........
    I GIVE YOU A 75% RATING.
    THANKS
    PHIL BENSON
    THANKS
    PHIL BENSON
  • 483 Answers
It is labeled on the
:board as ZNR1 the symbol is a Z on its side. It is has two legs and
:is orange, kind of shaped like a capacitor. On it is written 10N471K
:under that is 66+. It is some kind of protection device. If I test
:it on a Huntron it shows a capacitor like signature.
Fame !
Posted on Jun 28, 2009
    President:
  • 942 Answers
Hi yous just try to visit this site below ther are many steps to follow
http://www.repairclinic.com/0088_13_1.asp
Goodluck!!!
Regards
PCmania
Posted on Jul 02, 2009
  • 58 Answers
A varisitor rated 150vac rms will work for this application. It may be more likely to premature failure then a higher rated varisitor though. Check over completely to make sure that is all that is damaged after that bad connection. If you need schematics on this unit, let me know.
  • 50 Answers
The amount of watts are 400mhz
Posted on Jul 01, 2009
  • 294 Answers
Phil,
firstly the component u asking is a generally not found so easily in the market, i was consulting with other expert in Fixya about it only to help U. and more over o dnt have any clue about the Model or item no. so below i am providing a link wiz do have a catalog of all the kinds of model and Zener specs. so as to stop UR querry and not to waste ur time..in reposing ur question again and again. http://stevenengineering.com/Tech_Support/PDFs/32IZENER.pdf (pdf formate) please have a look on it
As Zener Diode is an electronic component which can be used to make a very simple voltage regulator circuit. This circuit enables a fixed stable voltage to be taken from an unstable voltage source such as the battery bank of a renewable energy system which will fluctuate depending on the state of charge of the bank.and regarding the voltage 1.3 to 3 watt should be perfect. now i have certain known locations where u can find the kind of product u looking for.
USA Headquarters
Pepperl+Fuchs Inc. · 1600 Enterprise Parkway
Twinsburg, Ohio 44087 · USA
Tel. +1 330 4253555 · Fax +1 330 4254607
e-mail: sales@us.pepperl-fuchs.com
South and East Europe Headquarters
Pepperl+Fuchs Elcon Srl
via delle Arti e Mestieri, 4
20050 Sulbiate (Mi) · Italy
Tel. ++39 039 6292 1 · Fax ++39 039 6292 240
e-mail: pa@it.pepperl-fuchs.com
www.pfelcon.it
Coutnry/Regioin: Korea (South)
Address: Rm 211, No.2 Gonggusangga, Imsu-Dong, Gumi-Si, Kyungsangbuk-Do, Korea (South) 730-720
Contact: Mr. Ju Hyung Lee
Phone: 82-54-474-2446
Fax: 82-54-474-2447
>>>>>>>>>>>>Tc......... cheers!!
Posted on Jun 30, 2009
    President:
  • 1,383 Answers
How can I get a copy of instructions for Cuisnart convection oven TOB 165?
Cuisinart has the manual for the TOB-165 on the Product page; it's a discontinued model. See https://www.cuisinart.com/discontinued/toaster_ovens/tob-165.html . The direct link to the instruction book is https://www.cuisinart.com/share/pdf/manuals/tob-165.pdf . (Note: you will need Adobe Reader or a similar program to read or print the manual.)
I hope this helps.
Aug 09, 2015 | Toaster Ovens
Door spring broke on Cruisinart CTO 350 series Toaster Oven
I had same problem with my cuisinar 350 series broken door spring. After disassembly found a broken extension spring measuring about 3/16 dia.,by 6.5 inches long.Spring was broken about a third down. I lifted ,or bended a loop and a halve up from each broken section and joined the two sections together. lifting each loop of the spring is tricky at first, requires a small screwdriver to be inserted between loop to be lifted and then gently bent the loop with needlenose pliers.
Not knowing how to disassemble the unit I had a hard time assembling the unit back.
I would start by taking off the screws holding the front black backlite first, then the main cover.
The main stainless steel cover does not have to be removed completely, by just gently unbending
the cover I was able to access the spring for removal.
Lots of luck
Jan 29, 2010 | Cuisinart TOB-175 1500 Watts Toaster Oven...
How do I clean the drip tray and broiler pan?
The drip tray pulls out the back of the oven. It can be soaked in hot soapy water.
Jun 19, 2009 | Cuisinart TOB-165 1500 Watts Toaster Oven...
Cuisinart TOB-30 toaster oven
I have the identical problem. Where can I find a replacement foot?
Mar 14, 2009 | Cuisinart TOB-30 Toaster Oven with...
Cuisnart Toaster Oven Broiler TOB-165 Element
there not replaceable . metal straps are welded to the ends to make the electral connections . thats why there are no elements for this oven , sorry factory-store-home-dump AS FAST AS WE CAN
Jan 20, 2009 | Cuisinart TOB-165 1500 Watts Toaster Oven...
Cuisinart TOB-175
It is roughly 17 inches across from left handle to right handle, but slightly less. About 15.25 inches from front to back.
-Tha Mp3 Doctor
Dec 30, 2008 | Cuisinart TOB-175 1500 Watts Toaster Oven...
CUISINART TOB 175 CONVECTION OVEN MANUAL
Cuisinart has the manual on their website:
http://www.cuisinart.com/manuals/index.php?cat_id=15
Scroll down to the link for the TOB-175.
Nov 19, 2008 | Cuisinart TOB-175 1500 Watts Toaster Oven...
Warning tone?
Have you tried turning the function button to off? This has worked for mine.
Aug 18, 2008 | Cuisinart TOB-30 Toaster Oven with...
Cuisinart toaster oven modele no.TOB-30BWC, serial no.50421.
The contacts for these toasters fail. The plasic cam that depresses the contacts also can melt. The design is poor and no replacement parts are available. When selecting a setting, if the selection is not exactly perfect, the contacts arc and eventually fail. Unless cuisinart changes the selection cam to a solid state or relay, this failure will continue to happen during normal use. If your unit works properly do not switch the function setting while heating, this will cause the contacts to arc and erode the contact surface. This posting is applicable to the TOB-30BC, TOB-30BCC and probably all TOB-30XXX models.
Dec 26, 2007 | Cuisinart TOB-30 Toaster Oven with...
Cuisinart TOB-165 1500 Watts Toaster Oven with Convection Cooking Logo
211 people viewed this question
Top Cuisinart Toaster Ovens Experts
D. E. Hev
Lawrence Oravetz
ray gallant
Are you a Cuisinart Toaster Oven Expert? Answer questions, earn points and help others
