Question about Blanco ELAN II 1 Handle Pull-out Spray Biscuit Kitchen Faucet 157-075R-BT
Low water pressure/slow flow Blanco Elan faucet 2.2 gpm
May need cleaning. how do I clean it?
  • 117 Answers
Pull the sprayer out, get some plyers or a wrench and losen up the connection. between the hose and the sprayer there is usually a screen take it out and walla it should take care of you, it also helps to leave the sprayer in some lime away or vinegar for a few hrs to get the hard water losened up in it
Posted on Aug 01, 2009
Heater takes more than 1 minute to get water to kit faucet , then temp fluctuates
1) Guesses: Sounds like a bad single-handled faucet cartridge, or low water flow at faucet, or clogged water filter.
Replace faucet cartridge, clean the aerator, and/or clean sediment out of pipes below sink, and clean water filter at tankless unit each month.
2) For exact measure of problem:
Typical faucet can have 2 gallon per minute flow rate.
2 gpm flow rate means faucet fills 1 gallon container in 30 seconds. Test faucet using 1 gallon container and a cooking timer to get flow rate.
Clean aerator to improve flow rate. Compare kitchen flow rate with other faucets in home.
http://waterheatertimer.org/Low-hot-water-pressure.html
Most homes have 1/2" diameter pipe running to kitchen faucet.
100 feet of 1/2" diameter pipe holds 1.2 gallons of water. This assumes no sediment build-up inside pipes.
http://waterheatertimer.org/Water-heater-recirculation-system.html
Assuming only hot is turned on: If faucet is 100 feet away from water heater, and pipe diameter is unobstructed 1/2" diameter, and faucet has 2 gallon per minute water flow, then hot water should arrive in 36 seconds.
50 feet away, and hot water should arrive in 18 seconds.
If kitchen has single handled faucet, and the handle is raised in the middle, then equal amounts of hot and cold water are drawn at same time. This doubles amount of time for hot water to arrive.
If single handle faucet has a bad cartridge, then faucet can have crossover.
Crossover means that cold water can enter the faucet even if faucet is turned to hot.
Bad single-handled faucet cartridge can delay or stop the arrival of hot water.
http://waterheatertimer.org/Crossover.html
Tankless require maintenance including cleaning combustion parts yearly, de-lime heat exchanger frequently, and clean water filter each month.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
http://waterheatertimer.org/pdf/Bosch_Overcoming_fluctuating_temps.pdf
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 15, 2011 | Rheem Direct Vent Natural Gas Tankless...
Blanco 2.2 GPM Faucet/Side Spray#157-013ST Via Google NO PRESSUR
Try unscrewing the aerator and cleaning the screen that you'll find there. If that doesn't work then you should check the pressure under the sink by removing the cold water hose from the cutoff valve (turn it off 1st!). If the pressure there is good then try removing and cleaning the cartridge by soaking it overnight in white vinegar or consider replacing the whole faucet if it's old. You can also call Blanco and see what they'll do for you as it has a "Limited Lifetime Warranty." If the pressure at the cutoff is low it's time to call a plumber!
Jul 14, 2010 | Blanco Classic Single Handle Faucet with...
Just installed a new Blanco Torino, model 157183, and inadvertantly got saw dust in the waterline during installation. It is restricting the pressure on the faucet. What is best way to clean it out?
I would try to unscrew the spray head from the hose and turn the water on to see if you get good flow from the hose. If so you need to clean the head, if not you will have to start taking the faucet apart and cleaning or possibly replacing the cartridge
Jun 26, 2010 | Blanco Classic Single Handle Faucet with...
Remove water saver device from Blanco Grace kitchen faucet
Remove the aerator at the end of the spout. It will unscrew and once off it will have a dime sized restricter in it that can be removed this restrict's the water down to about 1.6 gpm to save water.
It will either be plastic or metal and about the size of a dime with a small holw in it to let water pass by maybe 1/8" hole just remove it and put aerator back together.
Clean aerator screen out before you put it back together.
http://www.plumbersurplus.com/pdf/07163.pdf This link has a breakdown of parts. Look at parts 8b-10 for aerator breakdown.
Jun 12, 2010 | Blanco 157-052-ST Grace Single Handle...
Looking for tank psi trying to get better water psi out of the shower and taps
Every faucet and shower have a water saving restricter in them. Remove them from the shower head and end of the faucets.
They are about the size of a dime and with about 1/8" hole in them in which water flows out. So the flow is getting restricted from 1/2' flow to this giving you a water saving about a 1.5 gpm.
Below is some more information for the web site please check it out for further help.
http://www.inspectapedia.com/water/Poor-Water-Pressure-Diagnosis.htm
Poor water pressure just at certain plumbing fixtures? poor cold water pressure, hot water pressure, or both hot and cold water pressure or flow that is observed just at some plumbing fixtures in a building while flow and quantity are good at others suggests that the water flow or pressure problems are local to certain runs of supply piping or to the specific fixtures. Check the following first:
  1. Clogged aerator or strainer on sink faucets - clogging by dirt, debris, corrosion, can significantly reduce both hot and cold water flow at a sink where the strainer needs cleaning or replacement. Unscrew the strainer from the faucet and turn on the water - if the fixture pressure or flow is much better you've probably found the problem.
    Look at the aerator/strainer: inspect it, clean it, perhaps soaking it overnight in vinegar to remove corrosion and mineral build-up, or just install a new aerator/strainer.
Jun 04, 2010 | Plumbing
Low stream
these faucets have a single handel, and have a cartage that can be taken out and cleaned. Low water pressure is caused by minerals in the water to build up in the cartage and slow down water flow.
Mar 28, 2010 | Kohler K-10416-BN Fort½ Single Control...
Low water flow from my Blanco classic #157-074R-ST
1st make sure the valves are on all the way. The valves may be old also. Make sure there are no kinks in the supply line. Once that is verified and still a flow issue remove supply lines (turn valves off prior) to check for debris in the line. With the supply lines off then turn the faucet on to the warm position and blow it out as there may be debris in the faucet. You also may have a calcium build up in the head. Clean it with some diluted CLR.
Dec 14, 2009 | Blanco Classic Single Handle Faucet with...
Low flow rate
Replacement heads are cheep and can be found at home depot or ace hardware, it is sand in the system that is causing your slow flow leeve the tip off the airater off and see if the water flows ok if it does then it's the small screens and you must clean with a needle to get all the sand out in each of the disks. Or replace it. are you on well water or city water?
Sep 13, 2009 | Blanco Classic Single Handle Faucet with...
Blanco purus II poor water pressure
If the pressure is the same for both hot and cold. Then most of the time it could be just a blocked Screen/Aerator. Unscrew it and see if the pressure has improved. If so the replace it! Lowe's or Home Depot have them.
Jan 30, 2009 | Blanco Plumbing
Blanco ELAN II 1 Handle Pull-out Spray Biscuit Kitchen Faucet 157-075R-BT Logo
1,152 people viewed this question
Top Blanco Plumbing Experts
Mack Baxter
Andrew Bugbee
Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
