Question about Siemens Gigaset 8825 Cordless Phone
My gigaset a1000 keeps flashing register hs, I have followed the instrustions on the handset but it doesnt work, what is wrong?
SOURCE:
  • 518 Answers
SOURCE: Phones will not register
Try this:
Pick a handheld, press Menu - H/set settings - Reg Handset - Select Base 1, enter 0000 as password. Now on the bottom of the base station press and hold the Register button in for about 10 seconds or until the h/set beeps.
Geno
Posted on Jan 23, 2008
SOURCE: Problem Siemens Gigaset 4000 and 4200
when someone trys to call the phone says please dial the desired number
Posted on Jul 26, 2008
  • 107 Answers
SOURCE: Registering a Gigaset AL185 handset
i couldnt find a link to your owners manual, but, if you go into the menu in your phone and scroll down to "register handset" that should work
Posted on Jun 21, 2009
RixsFixes
  • 2200 Answers
SOURCE: my handset is displaying register HS. kindly
Please follow this procedure to register your handset
1. On the base station: press and hold the registration/paging key for min. 3 sec.
2. On the handset: within 60 sec. of pressing the registration/paging key;
Select MENU then Settings then OK then Handset then OK - Register HS then OK -
Enter the system PIN of the base station (the default PIN is 0000). Then press OK.
Registering now flashes in the display.
Registration takes approx. 1 minute to complete.
Thanks for using FixYa. Please do leave a vote for the help.
Posted on Nov 25, 2010
  • 6004 Answers
SOURCE: My Siemens gigaset A 490
To register the Gigaset handset, you need to have the handset near the base. Press and hold the Register/Paging button on the base for 3+ seconds (it's hidden by the handset when on the base). A shorter press of the button will activate the Paging feature. Then within 60 seconds of pressing the Register button on the base, press Menu and select Settings. Press OK and go to Handset. Press OK and then select Register HS. Enter the base PIN (default is 0000) and then press OK. (Use the up/down arrows to navigate the menus.) You will see Registering flash on the display of the handset for approximately 1 minute while the registration is processed.
The manual for the Gigaset A490 is available here: http://gigaset.com/medias/sys_master/A31008-M2200-R301-2-3S19_en-fr-es_USA_CAN.pdf . If you need it in another language (or country), start here: http://gigaset.com/hq/en/product/GIGASETA490.html?tab=manuals .
I hope this helps.
Posted on May 27, 2011
Gigaset coardless phone {A490} THE PHONE DISPLAYED REGISTER HS , CAN'T CALL
Your handset doesn't yet 'belong" to a base so look in the manual and see how you do it. Each brand is different. You will need to enter a code which is typically 0000 or 1234
Sep 29, 2013 | Siemens GIGASETA49H GIGASET-A49H GIGASET...
Gigaset a495 showing Register HS, and i cant making call.. plz give me a solution
gigaser A495 Handset ,
Actualy one problem may Handset Disply not work,Pls reply how to work in incoming and disply screen number.
Aug 18, 2012 | Siemens Gigaset A495 Cordless Phone
My Siemens gigaset A 490 cordless phone is showing Register HS what i have to do pl advise
I hope this helps.
May 26, 2011 | Siemens Gigaset A490 Twin Cordless Phone
My handset is displaying register HS. kindly provide me the required support to reslove the problem.
Nov 25, 2010 | Siemens Gigaset A490 Twin Cordless Phone
Our Siemens gigaset A2 keeps flashing at us and doesn't work.
First pull the battery fron the handset, pres the register button (Page) for a long time, eg 10 sec, then register the handset through the menu, setings, handset, register
Aug 07, 2010 | Siemens Gigaset 8825 Cordless Phone
I want to register my Siemens Gigaset AL145 Phones but there are looking for a pin code which I do not have
(¢ page 1) for min. 3 sec.
2. On the handset:
paging key
MENU ¢ Settings ¢ OK ¢ Handset ¢ OK ¢ Register HS ¢ OK ¢ Enter the
system PIN of the base station (default is 0000) ¢ OK.
Registering flashes in the display.
Registration takes approx. 1 minute.
Jul 11, 2010 | Siemens Gigaset 4000 Phone
Keeps going back to Register HS
Thats because there are too many handsets registered to base OR it can't find the base. Did you set it to register then pressed the little tab in on the bottom of the base? You have to hold tab down and keep phone close to base (a foot or so). If handset goes out of reg mode, you have to put it back in, then quickly press base tab down again before it stops.
Dec 17, 2009 | Siemens Gigaset A140 Cordless Phone
Handset won't work
I went through this exercise with a Siemens Gigaset 8800. The solution is to DE-register the handset first. Then register it with your base. This function can likely be accessed in the handset menu. The phone you purchased is apparently still registered to the previous user's base.
May 23, 2009 | Siemens Gigaset 4200 Cordless Expansion...
If you had a storm, and the only handset that works shows line in use, then your base has gone bad and needs repair. The reason the phones are flashing base 1 or something to that effect is because they don't see the base anymore, which typically means no phones will see your base, so its odd that one phone is actually seeing the base. Either way, you can try re-registering the phones to the base, but if you get the line in use after they register (if they will register), then your base is bad. If they won't register, your base is bad. For additional assistance you can go to www.cordlessrepair.com
Jun 15, 2008 | Lands Phones
Getting a new mobile in the registration mode with my Gigaset 8825 base station.
You need to register the handset to your base. Its easy, but first you need to clear the setting on the handset. Do this by pushing Menu, scroll to base system settings, push OK, then scroll to Base station 1, push OK, then scroll down to deregister, push OK twice, then press End. The handset should now say "please register", of which you can press OK, enter your pin or 0000 and the display should be flashing "registering base station 1". Now quickly, at your base push Menu, scroll forward to system settings, push select, enter your pin or 0000, then select. Push select again and the display should say "registering HS". Now, both displays (base and handset should say registering), keep your eyes on your handset display, once it "shakes hands" with the base it will prompt you to select an intercom number, you can just push OK. If you have problems, repeat the steps or you can download a manual for free at www.cordlessrepair.com
Oct 18, 2007 | Siemens Gigaset 8825 Cordless Phone
Siemens Gigaset 8825 Cordless Phone Logo
123 people viewed this question
Top Siemens Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
