Question about Dewalt DW744S 10" Portable Table Saw with Stand
The saw has stopped I know the circut it is plugged into is live is there a reset button or built in breaker located on the saw? Dw744 10 inch table saw
It may be a worn brush in the motor, Binding of the blade while using the saw, may cause brush wear and failure, within a few minutes the motor fails to run.Remove the covering over the back end of the motor, The brushes will be right there and easily removed , just look.
Posted on Apr 06, 2012
  • 3 Answers
I have a similar issues with mine, the brushes were gone so I replaced them. worked like a charm for the first 10 cuts then the brushes went again. what would cause the brushes to go that fast? is this an indication that something else is wrong?
thanks
Posted on Jul 06, 2009
  • 2,176 Answers
NO reset or circuit. You can try and unplug tool and blowing into all the exposed areas of the bottom of the saw. WEAR safety goggles. Then what I would do is check the brushes and if you have a volt ohms meter check the continuity to the brush tubes. Start at the cord looking for a break in wiring and go from there. Let me know if you need more help, but I am going to thing brushes or switch
Posted on Jun 27, 2009
Craftsman model 137.415030 10 in portable table saw won't turn on. It is getting power the switch sounds like it is working ok but it won't turn on. The reset button ,does not appear to do anything.
My table saw motor just stopped.. What do I do? - The WoodenBoat ...
forum.woodenboat.com/showthread.php?...table-saw...I...
WoodenBoat
Apr 6, 2013 - 23 posts - ‎20 authors
Does the motor have an internal thermal cutoff switch? ... Auto reset on a table saw, now that would be scary. ... A Craftsman, I think. ... The saw is a Grizzly 1022Z contractor-style saw about 10 years old. .... After the motor cools down the switchneeds to be pressed to restart the motor, it won't start suddenly ...
My table saw stopped, the reset button won't reset. What ...
www.shopyourway.com > Manage My Life > Questions
It is a Craftsman Table Saw Model 137.248880. ... I pressed the reset button and the saw restarted. I continued ... My table saw stopped, the reset button won't reset. ... One was just the switch the other the rocker switch, identical except in cost.
Craftsman 10 table saw motor stalled - Yesterday's Tractors
www.yesterdaystractors.com > Discussion Forums > Tool Talk
Dec 25, 2015 | Craftsman 21802 10-inch 13-amp Portable...
WHEN I USED OLD TABLE SAW WITH UNGROUNDED POWER CORD. I ALSO HAD JIG SAW PLUGGED INTO SAME OUTLET. wHEN I LAID THE JIG SAW ON THE TABLE SAW IT SPARKED AND THE MOTOR ON THE POWER SAW DOESNT WORK. NEX
If you're lucky, there's a circuit breaker built into the table saw motor and a little red button somewhere on the motor to reset it.
When you re-wire it. know that the cord should have a black wire (hot), a white wire (neutral), and a green wire (ground).
When you wire the power cord to the switch, the black wire should be the one that goes directly to the switch contacts and gets disconnected when you turn off the switch. The white wire goes through the rest of the system up to the motor. The green wire grounds out the metal parts that you might touch.
If you have to replace the motor, get a 3450 rpm to 3600 rpm motor. Harbor Freight has one for about $140 before any discount.
I recommend at least 1.5 HP
Sep 16, 2014 | Saws
Ryobi 10 inch table saw trips breaker when he turns onRyobi 10 inch table saw trips breaker when you can it on
First of all the saw needs to be plugged in directly to a outlet . NO Extension CORD !!! If it is Right , then Check on the motor label and see how many AMPS the motor is ? You need to then check the Breaker box and make sure the breaker is big enough to handle the load of the motor on the saw . You may have to make sure that the saw is the only thing on that breaker . NO Refrigerator , A/C , ECT.
Also make sure that the motor is clean and not packed full of saw dust . This can over heat the motor and kick off circuit breaker fast .
Good Luck , Hope This Helps !!!!!!!!!!!!!!
Aug 22, 2014 | Saws
14 in. saw with leeson motor
To start with what size circut are you trying to run the saw on? What ever the amperage is on the saw will draw almost 3 Xs the amperage rating of the saw on start up. If the circut is a 20 amp the breaker should hold long enough to start the saw. Also the saw should be the only thing running on the circut at the time. A 1-1/2 hp motor is a good size one aproximately 15.2 amps If you circut breaker is twenty amps and you still pop the breaker you may want to convert the motor to run on 220 volts as that will drop the load to approx. 7.6 amps Youcan run the saw on a 20 amp. 220 volt circut with no problem unless there is a problem with the motor. If the outlet is the only outlet on the circut it is an easy change to convert the circut.
Mar 02, 2013 | Target Portable Masonry Saw PS1411S...
I have a 10" Delta Table saw Model 34-670. I was
Check nameplate on motor for amp draw, and then check that against your breaker and wire size.
http://waterheatertimer.org/Color-codewire2.html
If table saw worked on the breakers before and suddenly stopped working, then see if you can lubricate motor bearings >> look for oil cap on each end of motor and use 3-in-1 oil.
Clean the saw and make sure there's nothing rubbing against drive belt and that saw blade rolls easily when saw is turned off.
Mar 02, 2011 | Delta Saws
I have been using my Craftsman 10" Table Saw to
First things first, check the outlet that the saw is plugged into. Does it have power? If so then progress to the saw itself and check the reset button which is usually located on the front panel but sometimes on the back or sides. Press the button firmly to make sure it is not tripped and if it is this will reset it. Make sure the power is turned off and attempt to turn the blade manually ( caution,
the blade is sharp so a pair of gloves is recommended ). If the blade turns with very little resistance then turn the power back on and try the on/off switch. If the saw starts it may very well have been the circuit breaker that had tripped.
Mar 02, 2011 | Craftsman 10" Table Saw
My table saw stopped suddenly -- what could be the problem?
Things to check:
  • Is it plugged in all the way? I've had a plug come slightly loose and lost power, though it was not immediately obvious.
  • Is there power from the outlet? Can you plug something else in and it works? If no, check breaker or fuse box.
  • Do you have a reset button on the front of your saw? If so, hit it and try turning the saw on.
  • There's typically a troubleshooting guide in the back of your manual as well. If you can't find your manual, try checking Sear's web site for manuals using your model number.
If this answer was useful, please give it a thumbs up.
Jun 08, 2010 | Craftsman 10" Table Saw
Plug the saw in switch it on and won't run
many models have a 'breaker' on them somewhere if the motor overheats, pulls too much current, etc. You may need to crawl under your saw, depending on the model, and reset it (typically a red button to press in). Otherwise, make sure the receptacle you have plugged it into is not tripped by plugging something into it that you know works.
Sep 10, 2009 | Wmh Tool Group 10" 1 - 1/2 Hp Workshop...
Table saw won't turn on.
Check that a breaker has not been thrown, and there is power to the plug that you are using.
Reply your findings if this isn't it, and I will give you additional help.
Jan 19, 2009 | Saws
Dewalt DW744S 10" Portable Table Saw with Stand Logo
711 people viewed this question
Top Dewalt Saws Experts
JOHN LAPIER
Craig Butler
Craig Butler
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
