Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Intex pool chlorinator trouble with unlocking mechanism
My chlorinator is brand new. When I plug it in and turn it on, I get the 88 code. I hold the left button down, and get the first beep, then hold the right button down, and it beeps multiple times, and stays at 88 does not go to a flashing 00. It took about 15-20 minutes of trying this sequence before we got the flashing 00. I think the lock mechanism is broken, as I can't get it locked either after I set the hours, so I finally let the system lock itself after 1 minute. It started the chlorination procedure, green light came one. We unplugged the unit and tried it again, and still after multple times of holding for one beep, the second hold on the right button would give multiple beeps and we eventually got it to go to change from 88 to 00. I really think the unlocking mechanism is broken. I tried calling the company, but stayed online for too long, and eventually hung up.
  • 297 Answers
Do not get frustrated with the long phone call.
Get your receipt ready and you could have a new filter in a week
CALL THEM BACK
They are good about these things
Mine arrived in 5 days no questions asked. I didnt even have to send the old one back
Keep as many parts from the old as you can especially the electro cell that is 200 bucks by itself
Posted on Jul 09, 2009
24' X 52" intex pool, I am having trouble with my cholinator not producing chlorine in the water. there are no signals or lights flashing. but when I test for the free chlorine on the strips is do
If you can remove your generator try and bench test it. Fill with pool water and do a chlorine test. Run the generator for a few minutes, unit should produce bubbles when the cells are turned on. Run another chlorine test and make sure it is higher than original test. You should also test your combined chlorines to make sure you don't have excess chloramines in the water. Also check for any buildup on the generator plates which should be acid washed, and verify salt concentration.
Apr 01, 2013 | Intex Automatic Salt Water System for ...
Ok i have the intex 1600gph sand filter saltwater combo system and my pool hold 8000 gallons i can run the chlorinator 24 hrs a day and it will not get the chlorine and free chlorine above 1 the ph is 7.5...
Yes, what is your stabilizer level? It should be between 30 and 50 ppm. If the stabilizer is too low then the sun will cause the chlorine to dissipate faster than the chlorinator can produce it. Some salt chlorinator manufactures recommend 80ppm but that reduces the chlorine efffect. If you can't get the chlorinator working then using a floating tablet chlorinator is a good option to keep the pool open. I hope this helps.
Aug 12, 2011 | Intex Automatic Salt Water System for ...
Code 88 stays on it hasnt gone off since i plugged it in
This is normal... From here, you must set your cycle time.....Follow these steps... Note: on the 8110 model, you must start your pump and set your pump timer first, then wait 15 minutes to sync your chlorinator to between the pump hrs. If the pump turns off before the chlorinator, you will get a low flow alarm...
If you can't read this, it's from your manual.. If you need help setting the timer, post asking for help setting timer... Good luck...
Aug 08, 2011 | Intex Automatic Salt Water System for ...
My led lights up 88 but when i push the buttons to unlock pad and set timer it wont do anything
are you holding down the pads long enough to hear a beep? hold down arrow till it beeps then hold up arrow till it beeps then set your hours with the up arrow
now let it lock itself and turn on.
This will take 2-10 minutes keep looking for the second green indicator this lets you know it is gen erating chlorine
Jun 12, 2010 | Intex Automatic Salt Water System for ...
Forgot how to set the timer getting 88 dont know where to go from here
88 is filtering
When you want to generate chlorine hold down arrow till it beeps hold up arrow till it beeps now with up arrow set desired hours no repeat the steps listed above that will lock it in now wait for 2-10 minutes until second green light comes on
Jun 09, 2010 | Intex Automatic Salt Water System for ...
I have an intex salt water filter, what is code 88
It is the Setup/Start up Code. it is displayed until you set the timer. which you do so by holding down the down arrow till you hear a beep, then hold down the up arrow till you here a beep. from there you can set the time and then to lock it in repeat the process
Jun 03, 2010 | Intex 2000 GPH Salt Water Filtration Pump...
This is my 3rd year using intex 8110 sytem. I
That code means the unit is in standby. It should start working if you set the opperational hours that you want in the program. Use the program guide in the manual.
Please Vote !!
Jun 01, 2010 | Intex Automatic Salt Water System for ...
88 flashes on display screen
Hold the down arrow till it beeps then hold the up arrow till it beeps When you see double zero then set the # of hours you want it to run with the up and down arrows.
Then you will need to lock it in use the down arrow again and wait for a longer beep then the up again till a long beep.
You are set remeber that it will take about 5 minutes for the chlorine light to come on
you can also go to intex.comm and watch the video or read the manual
Jul 03, 2009 | Intex Automatic Salt Water System for ...
My intex saltwater chlorine generator & filter beeping forever!!!
hello our pool chlorinator keeps comming up low salt 91 no matter how much salt we put in this is frustrating why is this happening ,,,please help
Jun 06, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
492 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
