How to set up 6.1 divinci home theatre system to 42inch HHD LCD T
How to set up 6.1 divinci home theatre system signiture series to 42inch HHD LCD Sharp TV.
  • DJORTIZ1982 Sep 22, 2009
    I HAVE A DIVINCI 6.1 SOURROUND SOUND SYSTEM GIVEN TO ME FROM MY FATHER, BUT I DONT KNOW HOW TO INSTALL THE WOOFER AND I DIDNT FIND THE MANUAL INSTRUCTIONS...??? HELP? ANYBODY
Davinci DA-6.1 home theatre tokk it out of box their is only speaker wires that connect on to another no power source or wires to tv I need help
Posted on Mar 19, 2011
  • 2,071 Answers
Set won't turn on. Was working fine last evening. Now nothing.
Reciever RCA RT2500 ' Techlore
www.techlore.com/forum/thread/11889/reciever-rca-rt2500
Aug 20, 2005 - 31 posts - ‎23 authors
hey ive got the rca RT2500 home theater system. .... won't power up) regardless of number of times I try to simulate a 120 V power flash (pulling plug .... My RCA receiverturns on but there is no sound...what can this mean?
Trouble getting sound from home theatre system with my ...
www.tomsguide.com/.../trouble-sound-home-theatre-system-appreciated....
Mar 27, 2013 - TV: Sony Bravia KDL-60EX645 Home Theatre System:RCA RT2906 ...-I've set the television, per the manual's instruction, to "Audio System" and "Audio Out: Fixed." This should allow the TV to turn off its internal speakers and switch .... SolvedI have F & D home theatre system, my rear speakers won't work.
Problems connecting surround sound to LCD TV... - Forums - CNET
www.cnet.com > Forums > TVs & Home Theaters
CNETJul 30, 2006 - Hey I have a 26" LCD TV from Polaroid and a Philips DVD home theatersystem. ... the Audio setup on the tv and TELL it to output the sound via the RCAcables ... However, you would normally turn off the TV speakers with a menu ... I just can't figure out why the TV audio won't play on the surround sound. Anynet+ - Home theater won't turn on with tv
Jun 11, 2015
TV won't turn on
Jun 10, 2015
Audio Return Channel Problem
Aug 23, 2011
rca tv no sound?????
Jan 1, 2006
More results from www.cnet.com
Jan 19, 2016 | RCA Audio Players & Recorders
Do not know how to connect my new HB954TB LG home theatre system to my LG 42inch plasma TV.
Connect speakers to amp
connect bluray player etc via HDMI in
Then single HDMI (labelled HDMI out) to the tv. The LG will automatically switch to the correct input
Aug 10, 2009 | Audio Players & Recorders
I have an eMachines and when i hook up my 42in LG HD LCDTV says
You resolution on the eMachine is higher than what the 42inch LCD can support .. reduce is to size by check the LCD manual and make change in window display settings
Jul 18, 2009 | Computers & Internet
I lost my remote for the divinci d-6 surround sound, can i use a
i have the same problem but mines a d-7... i threw it at my brother ;)
Jul 17, 2009 | Audio Players & Recorders
Panaonic Home Theatre DVD system only plays movies inblack white
Check the region and picture settings on the home theatre's dvd player, it could be set to put out a component signal, or it could be set to a PAL region rather than NTSC
Jul 06, 2009 | Audio Players & Recorders
Connect home theatre to ps3 to 32" lcd tv
if your tv and home theatre system as all hdmi or component hook ups then follow these steps but only use all one or the other cables.
1. hook the cable from the ps3 to the home theatre "imput slot" (you choose which one you want to use)
2. hook a cable to the output slot on the home theatre system to your imput slot on your tv.
3. turn on all three systems, put your home theatre system on the correct function (which ever slots you decided to put the cables in to the input slots) then turn your tv to the correct AV channel
Apr 05, 2009 | Vizio L32 32 in. LCD HDTV
Connect home theatre to 32" lcd to ps3
Depending on the year of your model of VIZIO your digital optical output may be tied to the DTV input only. Meaning the only time you will have audio coming out of the digital optical output is when your using the tuner and your on a digital channel. If your television is newer and the digital optical output is in white on the back of the television than it is tied to HDMI and the DTV Tuner and you will pass audio through the digital optical output when using HDMI or the Digital Tuner.
Now to get connect the HT: Normally you would run a digital optical cable from the source device to the home theatre system. Meaning if it was a PS3 you would run a optical cable from the Digital Out on the back of the PS3 to the Digital In on the Home Theatre receiver. If it was a DVD player than you would run the optical cable from the DVD player to the HT receiver. If you have a newer VIZIO and the optical output is in white and not black than you can run HDMI from the PS3 to the VIZIO and then run a optical cable from the VIZIO to the Home theater receiver.
You will have to adjust the audio setting in the PS3 to run audio out of the HDMI port if it is set to run audio out of the Digital Out or AV out. Also, if your going to run audio from the PS3 to the HT receiver through the Digital Out then you need to change the audio setting in the PS3 to Digital Out.
1. Select (Sound Settings) under (Settings) in the home menu.
2. Select [Audio Output Settings].
3. Select the input connector on the audio device.
Channel numbers and audio formats that are supported vary depending on the connector in use. AV is 2 ch. only, Digital Out is 2 ch. & 5.1 ch, and HDMI is upto 7.1.
Samsung series 6 tv & Samsung 2:1 home theatre problems
if you got all the lead you should have fibre optics which connects from dvd to tv and then set your dvd to digi in. you should get the sound. i have same cinema system and i have done the same
Jan 13, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Phillips LX3600 Home Theatre
Power up the set and open tray in DVD mode.
Press <9999> follow by <X> buttons on the Remote control.
where x = numeric 1 to 6 denoting the regions below:
Then show your region on TV
1 = USA
2 = Europe
3 = Asia Pacific
4 = Australia, New Zealand, Latam
5 = Russia, India
6 = China
0 = Code Free
This is taken from the original service manual for the reciever
Jan 27, 2008 | Philips LX3600D System
How to redirect the sound of my new LG 52" HDTV LCD to my LG home theatre?
There sould be audio outputs on the back of it, and the manual should clearly show how to set up a home theatre with an external sound system and all.
I don't know what kind of sound system you have, but I think it might be best to connect your video source (typically DVD player) to your sound system, as it usually can be done better that way. No need to introduce another link in the chain (your TV) that could degrade sound. Also any external tuner could (should) be connected to your sound system directly.
If you use the internal tuner in your TV to watch TV the audio out is your option. Best way to get this right is to consult the manual. They usually have some diagrams that shows a few options of how to do it.
Dec 05, 2007 | LG 42LC2D 42 in. LCD HDTV
2,788 people viewed this question
 Grubhead
Grubhead
