Question about Dell Latitude D600 Notebook
I need to connect to the internet
Please i cant connect to the internet no local network icon on my computer
  • 1 more comment
  • ehiboy2die4 Jun 27, 2009
    cables and i am using window xp there is no local connection cables and i have reformatted the system and install drivers from the inter net i dont know what to do again i using it for the first time please help me
    same prob too
  • pinguu May 11, 2010
    What method are you using to connect (i.e wifi or cable) and what operating system are u using
    Problem Solver:
  • 9 Answers
Can you see if the network card has the correct drivers?
Click Start; Right Click on "My Computer" Select Manage
A new application will launch - Computer Management
From this application, click on "Device Manager"
There may be some devices with ? listed - make sure that there is at least a device under network adapter. If there isn't, then the driver is not set for the network adapter - you'll need to take the original pc system disk to get the driver; or download it from dell.
Posted on Jun 28, 2009
Not acses to the internet
wats ur internet type of connection. wats ur system specs. please give a brief details. then it may give idea wats the problem is.
If XP, check whether the network icon (2 monitos blinking icon near clock in task bar @ bottom right corner) is blinking or marked with RED. If yes then the network cable is unplugged. or the icon is not present there, go CONTROL PANEL, NETWORK CONNECTION, see for LOCAL AREA CONNECTION. that might be highlighted (else if its grey shaded, right click & select enable). If the icon is not present there, go to control panel, SYSTEM - HARDWARE tab - DEVICE MANAGER. on the lower edge you should see NETWORK ADAPTERS, expand it there the network cards should be there. If you cant find the drivers there, try to look it with YELLOW QUESTIONED marked devices. if this is present, then you should try to re install the driver.
hope all this may help you to solve the issue. else give a clear feedback.
Jan 21, 2013 | Computers & Internet
Tip
Setting up a Router
Chapter 1: Connecting the Wireless-G Broadband Router
Hardware Installation
1. Locate an optimum location for the Broadband Router. The best place for the Broadband Router is usually at
the center of your wireless network, with line of sight to all of your mobile stations.
2. Fix the direction of the antenna. Try to place it in a position that will best cover your wireless network.
Normally, the higher you place the antenna, the better the performance will be. The antenna's position
enhances the receiving sensitivity.
3. Connect a standard Ethernet network cable to the Broadband Router’s Internet port. Then, connect the other
end of the Ethernet cable to your Cable or DSL Broadband modem.
4. Connect your network PCs or Ethernet devices to one of the Broadband Router’s numbered ports with a
standard Ethernet network cable.
5. Connect the AC Power Adapter to the Broadband Router's Power Socket and the other end into an electrical
outlet. Only use the power adapter supplied with the Broadband Router. Use of a different adapter may result
in product damage.
Chapter 2: Configuring the PCs
Overview
The instructions in this chapter will help you configure each of your computers to be able to communicate with
the Router.
To do this, you need to configure your PC’s network settings to obtain an IP (or TCP/IP) address automatically, so
your PC can function as a DHCP client. Computers use IP addresses to communicate with the Router and each
other across a network, such as the Internet.
First, find out which Windows operating system your computer is running. You can find out by clicking the Start
button. Read the side panel of the Start menu to find out which operating system your PC is running.
You may need to do this for each computer you are connecting to the Router.
The next few pages tell you, step by step, how to configure your network settings based on the type of Windows
operating system you are using. Make sure that an Ethernet or wireless adapter (also known as a network
adapter) has been successfully installed in each PC you will configure.
Configuring Windows 98 and Millennium PCs
1. Click the Start button. Select Settings and click the Control Panel icon. Double-click the Network icon.
2. On the Configuration tab, select the TCP/IP line for the applicable Ethernet adapter.9641e30.jpg
Do not choose a TCP/IP entry whose name mentions DUN, PPPoE, VPN, or AOL. If the word TCP/IP appears by
itself, select that line. Click the Properties button.
3. Click the IP Address tab. Select Obtain an IP address automatically.a443500.jpg
4. Now click the Gateway tab, and verify that the Installed Gateway field is blank. Click the OK button.
5. Click the OK button again. Windows may ask you for the original Windows installation disk or additional files.
Check for the files at c:windowsoptionscabs, or insert your Windows CD-ROM into your CD-ROM drive and
check the correct file location, e.g., D:win98, D:win9x, etc. (if “D” is the letter of your CD-ROM drive).
6. Windows may ask you to restart your PC. Click the Yes button. If Windows does not ask you to restart, restart
your computer anyway.
Configuring Windows 2000 PCs
1. Click the Start button. Select Settings and click the Control Panel icon. Double-click the Network and Dialup
Connections icon.
2. Select the Local Area Connection icon for the applicable Ethernet adapter (usually it is the first Local Area
Connection listed). Double-click the Local Area Connection. Click the Properties button.ea4fa3a.jpg
3. Make sure the box next to Internet Protocol (TCP/IP) is checked. Highlight Internet Protocol (TCP/IP), and click
4. Select Obtain an IP address automatically. Once the new window appears, click the OK button. Click the
5. Restart your computer.
Configuring Windows XP PCs
The following instructions assume you are running Windows XP with the default interface. If you are using the
Classic interface (where the icons and menus look like previous Windows versions), please follow the
instructions for Windows 2000.
1. Click the Start button and then the Control Panel icon. Click the Network and Internet Connections icon.
Then click the Network Connections icon.
Connection listed). Double-click the Local Area Connection. Click the Properties button.f2e300e.jpg
button. Click the OK button again to complete the PC configuration.
If you would like more information on setting up your connection, please ask me a question.....
Cheers.
on Jan 03, 2010 | Computers & Internet
My computer crashed so i put in emachines recovery disc and re-did my other computer and it wont let me connect to the internet because i cant find the Local Area Connection Icon (LAN) under my network...
right click the my computer icon and go to manage. then go to device manager. try to see if you have correctly installed the driver of your LAN. If you can see a yellow exclamation point, that means you need to install the driver for your LAN
Jun 09, 2011 | Computers & Internet
2004 Emachine- when desktop comes up on lower right there's a flashing icon when clicked on says "Network Connections", Local Area Connection, Network Cable Unplugged, Intel{R} PRO/100 VE...
If the local area connection icon specifies as network cable unplugged, then the computer has not sensed the connection between the computer to the cable modem / DSL modem, please reseat the cable behind the cable / dsl modem to the computer. If the icon still shows unplugged, then change the network cable between the two.
If the issue still persists, please revert with more details lik the kind of internet connection used and the reason for reinstalling.
Jan 04, 2011 | E-Machines eMachines Desktop PC
Multiple network adapters found
Go to Start->Control Panel->Network and Internet->Network and Sharing center->Manage network connections
You will find icons like local area connection, wireless connection and lot more. Just have one local area connection enabled and disable all other icons. Then run the setup
Nov 01, 2009 | Belkin (F5D5231-4) Router
Local area connection icon disappeared after formatting?
Please see this link. You will need to download and install the drivers for your network adapter. You can download these from either the manufacturer's website or the motherboard or network card mfr's site. Please see this tutorial on how to do this.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 25, 2009 | Computers & Internet
My router is detecting the internet but i cant get the internet on my computer. I cant connect to my router but it says that im connected with limited access. I have it hooked up through the router with a...
Limited or no connectivity indicates that the computer cannot acquire a valid IP address. This is due to incorrect network key you have entered. We need to check the correct WEP key in your router's setup page. Here are the troubleshooting steps we recommend you try:
Note: You need to use a computer hardwired to the router to check the wireless settings.
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field. Please click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. Click on Wireless Settings under Setup page.
5. Take note of the SSID.
6. Scroll down, look for the Security Options and check whether WEP (Wired Equivalent Privacy) or WPA (Wi-fi Protected Access) is selected.
7. If its WEP is enabled, copy the value of the selected Key number. If WPA is selected, take note of the Passphrase.
8. To configure the computer with wireless adapter, please consider the following:
Configuring the NETGEAR adapter and Saving the Profile
a. Open the NETGEAR Smart Wireless Settings Utility icon located at the lower right portion of your computer screen. It will then open the Settings tab.
b. Change the Network Name SSID to match the one on your router.
Tip: As an alternative to typing in the SSID, you can use the Network tab to view the available wireless networks. Double click on the desired network.
c. Click the Apply button to activate the connection.
d. Enter a name for your profile (e.g. NETGEAR to Home Network) and click the Save Profile button to store the current settings.
Note: The above procedure applies only if you are trying to connect to a wireless network with no wireless security.
If the computer is using Windows built-in wireless program to manage the wireless adapter, please follow the steps below:
For Windows XP Service Pack 1
a. Please right click on the Wireless icon on the right lower end portion of your computer. Then click on to View Available Wireless Networks.
b. Click on the Advanced tab.
c. Please delete all the preferred networks then click on OK.
d. Right click on the Wireless icon again and click on View Available Wireless Network.
e. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. The network key will be the Key or Passphrase you have copied from the router setup (refer to step 7). Please type in the Network Key and then confirm it.
f. Make sure not to enable IEEE and then click on Connect.
For Windows XP Service Pack 2:
2. Click on the Change Advanced Settings.
3. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
4. Right click on the Wireless icon then click on View Available Wireless Network.
5. Select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. The network key will be the Key or Passphrase you have copied from the router setup (refer to step 7). Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use windows to configure my wireless networks" on the Wireless Networks tab. Please ask assistance from the wireless adapter vendor for configuration if using a proprietary wireless utility (non-NETGEAR wireless adapters).
Apr 12, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
My computer (Dell) unknow Network Card
i) Click on Start button ---->Select option Control Panel------>Select Network Connections----->
  a new window appears showing the "internet connections icon " Such as:
  Local Area Connection 1 or 2 or 3 and since you are not connected it will show this icon as:
eg1: Local Area Connection 1 or 2 or 3
  Network Cable Unplugged, Firewalled
  VIA compatible Fast Ethernet
  in this case u can download VIA network drivers....from internet..
  or
  eg2: Local Area Connection 1 or 2 or 3
  Realtek RTL8139 Family Fast Ethernet NIC
  in this u can download "Realtek RTL8139" network drivers.... from internet(which is showing model     no: RTL8139 through google search engine )
        (OR)
ii) Click Start button ---->Select RUN option ----> type in the text box devmgmt.msc --->Select               Network Adapters....
    but this will show wheter ur network adapter or NIC is VIA or Realtek or......but doesnt show the           correct Model NO: of VIA or Realtek....
    so i would suggest to follow the step (i)
Thanking you
M.Sridhar
Dec 25, 2008 | Dell Ethernet Card Network Adapter
Netgear MR314
in product damage.
Overview
the Router.
Check for the files at c:\windows\options\cabs, or insert your Windows CD-ROM into your CD-ROM drive and
check the correct file location, e.g., D:\win98, D:\win9x, etc. (if “D” is the letter of your CD-ROM drive).
Connections icon.
click the Properties button.
Jul 05, 2008 | NetGear MR314 802.11b
Help mi out plzzzz(wireless problem)
what you can see on your network connections? If you can see some icon of internet connection or local network connection you can right click and then point to properties after that you can see the local area connections properties. double click the Internet protocol (TCP/IP) click it and then click obtain automatically ip address. Some wireless network, you can see the network provider which you can see on your network locations. Sometimes you can put specific ip adress of your provider. If not? you can make your own network connection, right click the internet connection and then click properties follow the instruction and go to network connection and sign up your username and password so that you can access through internet connections.
Jun 25, 2008 | HP Pavilion dv6000z Notebook
Dell Latitude D600 Notebook Logo
81 people viewed this question
Alun Cox
