Question about Toshiba 42H81 42" Rear Projection Television
My toshiba 50L 1350UC LED tv keeps blurring in and out of focus, How can i fix this?
I have a Toshiba 50l-3400U LED TV There is a large bar across bottom of screen which is getting worse. audio is OK which part should I replace?
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Sep 04, 2017 | Toshiba Televison & Video
Toshiba LED tv 50L 1400U lower half of screen dark shading and increasing day by day.
According to the service manual this set has 2 separate power supply voltages for the LED's and it sounds like there is at least one bad lamp in the panel, if you have a volt meter test the 2 and see if one is at a lower voltage than the other...one other possibility would be if you have Tcon board issues
May 10, 2017 | Toshiba Televison & Video
Blurred picture
the problem of you tv is the CRT socket ,replace the socket.
Jan 07, 2009 | Toshiba 32HF73 32" TV
Toshiba TP55E51 blurred picture
You must be more specific with your description. Blurred? Like double images; or poor focus; etc.
Nov 21, 2007 | Toshiba 57H81 57" Rear Projection...
Blurry Pictures
There are several factors that can contribute to getting better focus and improved results. 1. Auto Focus / Auto Exposure lock. Press the shutter button down HALF WAY. The camera will attempt to adjust exposure to the current lighting environment for maximum benefit. Then the camera will automatically correct the focus based on objects in the center of the display. If the camera can automatically set the focus and exposure, the LED by the viewfinder will turn GREEN. If the camera can not adjust the settings automatically, the LED will turn RED. This process usually takes about two to three seconds. 2. Be sure not to cover the sensor on the front of the camera with your finger. This will disable the automatic focus and exposure controls. 3. Rely on the Rear LCD Display. When in doubt, trust the LCD. The LCD will display the subject more accurately than the viewfinder. This will help with "framing" the subject, or determining if you have enough light for proper exposure. 4. Motion can cause a "blur" effect. Either motion of the subject, or motion by the photographer. This phenomenon is just like traditional photography. Moving objects may appear to blur, and this will be even more evident in lower lighting situations as the shutter speed slows down to allow for more light. The shutter will react faster in bright light, and motion will not be as apparent.
Sep 15, 2005 | Toshiba PDR-M11 Digital Camera
Blurry Pictures
Sep 15, 2005 | Toshiba PDR-M21 Digital Camera
Better Focus
There are several factors that can contribute to getting better focus and improved results. 1. Auto Focus / Auto Exposure lock. Press the shutter button down HALF WAY. The camera will attempt to adjust exposure to the current lighting environment for maximum benefit. Then the camera will automatically correct the focus based on objects in the center of the display. If the camera can automatically set the focus and exposure, the LED by the viewfinder will turn GREEN. If the camera can not adjust the settings automatically, the LED will turn RED. This process usually takes about two to three seconds. 2. Be sure not to cover the sensor on the front of the camera with your finger. This will disable the automatic focus and exposure controls. 3. Only us the MACRO MODE (Flower Icon) for CLOSE-UP photography. Be sure to use MACRO MODE if you are taking pictures of an object at less than six inches away. Using MACRO MODE improperly will result in poor focus. 4. Rely on the Rear LCD Display. When in doubt, trust the LCD. The LCD will display the subject more accurately than the viewfinder. This will help with "framing" the subject, or determining if you have enough light for proper exposure. 5. Motion can cause a "blur" effect. Either motion of the subject, or motion by the photographer. This phenomenon is just like traditional photography. Moving objects may appear to blur, and this will be even more evident in lower lighting situations as the shutter speed slows down to allow for more light. The shutter will react faster in bright light, and motion will not be as apparent.
Sep 15, 2005 | Toshiba PDR-M71 Digital Camera
Better Focus
Sep 15, 2005 | Toshiba PDR-M81 Digital Camera
Blurry Pictures
Sep 15, 2005 | Toshiba PDR-M25 Digital Camera
Toshiba 42H81 42" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
