Question about Clarion Car Audio & Video
1995 Ford Explorer CD changer - how to manually release cartridge
1995 Ford Explorer CD changer - I removed it from the car and console and have it opened up, but I cannot find the manual release for the cartridge. It is a Clarion part no. F7FF-18C830-AB.
Thanx
JAF
5 Suggested Answers
Eagleeyes
  • 199 Answers
SOURCE: clarion cdc634
yeah as far as i know they will work fine.
Posted on Sep 29, 2008
ronaldo_ross
  • 1056 Answers
SOURCE: 1995 Explorer 6 cd changer - how to manually eject cartridge
No there is none you have to hook up power to it then press eject.
Posted on Jun 27, 2009
  • 9 Answers
SOURCE: is it posible connect a Clarion cdc635 in the same
no every maker has their own plugs...you cant take a pioneer and hook up to a alpine using the same plugs,,,unless you splice into the wirse on the plug and find wich one is hot..ground..etc........
Posted on Feb 17, 2010
kenw392
  • 2226 Answers
SOURCE: I have a 1997 Ford Explorer purchased new with te
is there a coin holder in front of the changer? if so, there may be a coin lodged inside the changer preventing the carrier mechanism from moving. look on the bottom of the changer to see if a coin might be stuck.
Posted on Mar 11, 2010
I have CDs jammed in side 6 disc changer (factory)> I have tried resetting the system by removing and replacing the fuse, but still get CD Error> If I need to remove the unti, is there an easy way...
Press and hold eject button,insert a credit card under cartridge
Push card fully in and move left /right right/left
This will locate micro switch to release cartridge
May 30, 2011 | 1992 Ford Explorer
My in-car cdc will not eject the cartridge?.
Press the eject button several times non stop.Like 10 to 15 times non stop and see,if the cartridge is getting ejected out.If its still stuck,then disconnect the car battery negative terminal for 15 minutes then reconnect the negative terminal and heck.If still the cartridge is stuck,then its problem with internal mechanism.You will have to disassemble the unit and manually eject the cartridge out and lubricate internal mechanism.-------------- Unplug the changer and use a flat metal ruler.And slide it alongside the cartridge. try sliding on both sides. You'll eventually trigger the manual switch and it'll pop out.Bif that is also not helping then:--- solution is to disassemble the CD changer and lubricating the mechanisms inside. This is the most common problem with CD changers. Take the unit out of car and try to release disc manually.Take the screws out on both sides of player then remove case . You will be able to manually push the big gear so that the disc goes back into the cartridge. And then it slides out. After that you lube all moving parts with a teflon grease and some parts with silicon spray. This will help.Thanks.Helpmech.
Feb 17, 2011 | Car Audio & Video
What fm station do I set my radio on?
i have a ford explorer, 1995 it came with a 10disc cd changer only trouble is we dont know what radion station we need to use for it can you help?
Apr 15, 2010 | Xtreme Sound WMS6100RW 10-Disc CD Changer
I have a 1999 Ford Explorer Eddie Bauer. The multiple cd changer is stuck. Won't load or eject. I can hear and see one of the cd trays going in and out. It cycles every time I start the car. Mike
does it have the change holder in front of the changer? if so, there may be a coin lodged inside the changer. if you have a flat piece if metal, such as a piece of backstrap, you can slip it beneath the cartridge and remove the magazine. once the magazine is out, check to see if there may be a coin logded in the bottom of the changer.
Mar 19, 2010 | Car Audio & Video
Mar 11, 2010 | Clarion DC625 6-Disc CD Changer
The cd changer won't eject any cd's - shows "CD error". How can I get it to eject? Also - the cigarette lighter in the center console does not work so I can't use my charger. I know there is another on the...
If you have a stacker /changer
PRESS AND HOLD EJECT BUTTON
Insert credit card or similar firmly under cartridge
Push fully in and move left/ right.
This will locate micro switch and release cartridge
Dec 26, 2009 | 2003 Ford Expedition
Jun 27, 2009 | Panasonic CQ-DPX33 CD Changer
Purchased a 1995 ford explorer with a 6 disc cd changer and it now will not eject the cd cartridge and when the cd player button in pushed a message comes up ''no dj''. have read the owner's manual and it...
If there is a cartridge in the unit, you need to take the player out. pull the housing and do a manual release. do not force it. Possible problem could be 2 discs in the same slot or 2 discs trying to enter tray, either way, if the cartridge is present, it's jammed and needs to be pulled apart. If my memory is correct the factory unit was either Alpine or Clarion. The cartridges are still available at most car audio shops. 20-30 bucks. If you don't feel comfortable pulling the unit, most custom shops can check it on the spot, and let you know if it needs to be sent out for repair. Stay away from Best Buy, etc... go to a custom shop that's been around for a while and you'll get honest service.
May 17, 2009 | Car Audio & Video
Stock 1997 Ford Explorer 6 CD changer stopped playing CDs
We finally realized that all of the "advisers" on the internet want to charge for their advice, and their advice in this case is univerally that the unit should just be replaced. Ya think?! Could of figured that one out on our own.....what a joke...
Mar 31, 2009 | Car Audio & Video
6 cd changer
try to reset the cars computer. i had the same problem and it fixed it. all you need to do is unplug the battery for about 10 minutes and it may work. Good luck!
Oct 26, 2007 | Car Audio & Video
Car Audio & Video Logo
207 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
