Question about Epson STYLUS R230 InkJet Photo Printer
My problem is vertical line on my photo print out tiny but visible i try nozzel check all good, i clean it many time i think more than 10 times,and give me the same result.i also try to alignment check the first one is bad. then i realigned it then later i have Good result on it ten times also. But my photo print out in Photo mode have this tiny vertical lines.I try also try to print in best photo mode it gives me improvement but the print speed is low. Pls help me.. thank u in advance how should i know which one of my cartage is leaking?i do nozzel check again all lines are good. but i saw magenta its diagonal line in its both side have slight miss alignment.
  • 152 Answers
You need to replace the printhead...
Posted on Jun 27, 2009
SOURCE:
When I print a photo, vertical lines appear throughout the photo. The ink cartridges are new. No error message appears on screen.
Please state the model of your printer.
Vertical lines appears on prints because the nozzles on your print head are blocked, it doesn't means all nozzles but some of your nozzles are blocked. A print head of an inkjet consists of many tiny little pores or nozzles, through which jets of inks are sprayed on the photo paper to create an image, if some of this tiny pores are blocked print outs deteriorates, so cleaning the print head is an option if your printer has print head inside the printer you can first clean it through the head cleaning option present in the maintainence tab of your printer software, for printers that have print head on the cartridges, you can add a few drops of isopropryl alcohol on the print head and leave it for a minute and put it back on the printer and run the head cleaning utility of your printer software.
Hope this helps you.
Apr 28, 2011 | Office Equipment & Supplies
Epson Stylus r220 prints with white lines... i installed a CIS and it worked fine for about 6 months, now i'm getting prints with white lines (or fine spots) i tried nozzle check, which comes out good......
Nozzle check must perfect for perfect output. There are tranversal lines at vertical straight lines that represent same point of head micro piezo. If tranversal lines no clog at all, but vertical straight lines not perfectly straight, the result not good (like horizontal white banding). Check it? Head aligment is for vertical banding. If your result is horizontal banding, you don't need to realign head. It's caused by some residual at the output of head sprayer. So, the spray of ink not straight to paper. Try to print with photo/best photo.
Jul 18, 2009 | Epson Stylus Photo R220 InkJet Printer
I have the same problem vertical line epsonr230
get your printer service and get new INK jets mean Cartage for your printer thank you it will get no vertical lines then .. it is caused when cartages are leaking..
Jun 25, 2009 | Epson STYLUS R230 InkJet Photo Printer
Not printing - just replaced ink cartridges
Reseat the cartridges.
Do 3 consecutive head cleanings.
May 02, 2009 | Epson Stylus C84 InkJet Printer
Dark vertical lines on printed photos 18cm apart
Remove the cartridge and put it back in. If same issue persists, try to do head cleaning and nozzle checks simultaneously from the computer.
Start -> Control Panel -> Printers & Faxes (Windows XP) / Printers (Windows Vista) -> Printer Icon (right click) -> Printing Preferences -> Maintenance
You should be able to see nozzle check, click it and follow the prompt. Line patterns that corresponds to the colors of the ink cartridges would be printed. If breaks on those patterns appears, continue with head cleaning. Try to do this about 3 times until all patterns are complete.
Dec 24, 2008 | Epson Stylus Multifunction Inkjet Printer/...
I have a canon pixma mp 470 printer/scanner that i am using for the first time to print pictures. The first one printed out beautifully, but every picture since then has visible vertical lines in it. I...
rrenor,
You will find that the ink in the cartridge is low or almost out. If you haven't printed pictures for some time than the unit has still purged, which means to have sucked ink through the head, everytime you have turned it on. The long and short of this is that over time it has been emptying your cartridges. Nothing you can do about it, it is just the wayy these machines operate. Try checking the ink levels and if they are all full, leave the print head in park overnight and try again tomorrow, see what happens. If it is still giving you lines than it may need to have the print head replaced.
Don't do any more cleans now, you are just wasting your ink. Allow it to sit and you may find it will fix itself.
Gremlin11
Dec 11, 2008 | Office Equipment & Supplies
Green tint on photos
perform deep cleaning and nozzel cleaning from the printer properties
May 16, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Photos they come with a yellow line through it
This kind of thing happens to me a lot when my cartridge is running out of ink, and if it has been doing it since you first used the cartridge it may just be a dodgy cartridge.
However, this printer doesn't print the clearest of pictures even at the best of times. If when you do the alignment check you find that in the selection with the least obvious lines, the lines are still pretty obvious, then your printer's just not very good.
Mar 20, 2008 | Canon PIXMA MP170 All-In-One InkJet...
Printing light colors does not work
You RINSED the printhead???
I wouldn't do that again.
Try taking a damp cloth and dabbing it against the printhead nozzels until you get lines forming on the rage from the ink (the nozzels you're having trouble with specifically).
Erice
Oct 29, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Epson STYLUS R230 InkJet Photo Printer Logo
445 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
