WHAT IS A DOOR PLUNGER
RUBBER INSET ON FRONT LOAD DOOR TORE, NEEDS TO BE REPLACED WHAT IS IT CALLED
  • 126 Answers
Tub boot or bellows either or.held in place with inner and outer clamps must remove front panel price range 50-100.hope this helps please rate my response :)
Posted on Jun 27, 2009
Why does he3t leak after being overfilled
you need to remove the panel so you can see where it is leaking. if this is a front loading washer then check the below seal between the door and the tub. my son overloaded ours and the rubber seal tore and I had to replace it.
May 26, 2014 | Washing Machines
A piece of the rubber circling the door opening tore off
that rubber is part of the bellow that seals the opening to the drum. if it is just a small piece that tore then u might be ok. if it is leaking from the door or underthe washer then u will need to replace it. I have whrillpool and the bellow for mine was $85
Apr 07, 2014 | Miele Novotronic W1918A Front Load Washer
There is a piece of rubber that tore off from the seal
yes new seal needed..go to espares.cu.uk if you live here...or utube on how to do
Apr 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I cant get the power sliding door alarm to stop dinging.
I have a 2006 SV6 with the power sliding doors. The problem that I found was with the contacts on the door ( They are called plungers) the movable pins were losing connection with the fixed part The plunger is very easy to replace if you can find one. The plungers are covered with a rubber cover and is held in place with 2 plastic pins. My Pontiac dealer could not even find one in his books or even a picture of one, and claimed that he had never had anyone come with a door problem. My Chevy dealer said that it came with a wiring harness that is not needed for $154. The cure that I came up with was to take the plunger block apart (it snaps together)and replace the rusted out springs then solder 3" wires to the end of the plunger pins (they solder easy) to the tabs that go to the plug(pop out the tabs or you will melt the plastic. It took about 45 min. now the doors work like new and will never loose contact again
Mar 21, 2010 | 2005 Pontiac Montana
AWM 8143 front loader- rubber door needs to be replaced
Yes,it is called a bellow.If the tear is small enough and just on the front rim of the seal try gluing it with super glue,it will get you by till you can get it replaced.
Sep 07, 2009 | Whirlpool AWM8143 Front Load Washer
I have a Frigidaire front load washer model FTF2140ES2 that will
The rubber around the door tore and the washer leaks bad.where do i find that part.
Jan 20, 2009 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
Washing Machines Logo
378 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
