Question about Panasonic CQ-DPX33 CD Changer
1995 Explorer 6 cd changer - how to manually eject cartridge
1995 Explorere cd changer. Have the unit out of the car and opened but cannot figure out how to eject cartridge. It is Clarion. Is there a manual eject?
  • jafune Jun 27, 2009
    I do thank you, but there was power to it before and it would not eject. I have a library book on cd stuck in the cartridge,(no cd is out of the cartridge into the player) and need to get the cartridge out.
    Thanks
    J
  • jafune Jun 28, 2009
    Great idea. I will try that. Many thanks. JAF
  • 1,056 Answers
No there is none you have to hook up power to it then press eject.
Posted on Jun 27, 2009
  • Ronado Panaligan
    Ronado Panaligan Jun 28, 2009
    If you coud somehow turn the motor that free up the carthrige you can free it without damage. Look carefully at the mechanism. If the motor becomes hard to turn you may have reached the end of its travel. You may have to turn the other direction. look carefully at the mechnism to see if there is any latch you may have to push to free up a sliding mechanism.
CD Changer does not eject and I can not remove the cartridge.
IVE HAD SUCCESS WITH REPLACING/REPAIRING THE DRIVE GEAR/BAND WHICH OPENS/CLOSES UNIT..?
Dec 31, 2014 | M&S Systems MCD-6 6-Disc CD Changer
Clarion caa 397 not ejecting the cartridge
Try here: Recommend contacting a local car audio professional or Clarion customer support directly here:
https://clarion.com/xe/en/user-support/inquiry/contactus
Aug 27, 2014 | Clarion Digital Audio/6-disc Car Cd...
Appear to have cd jammed in cartridge,mislaid
Owners manual here
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Mar 17, 2010 | Alpine CHAS-634 6-Disc CD Changer
My BMW X5 6 CD Alpine changer is jammed and will not work. How do I fix it and remove the disk?
If the issue is you cannot eject the cartridge this would be simple.
Slide the changer door open as if ejecting the cartridge. Take a credit card/driver license and insert about 2 to 3 inches between cartridge and chassis. You should hear a click and the cartridge should eject.
Once the cartridge is out check to make sure there isnt a stuck CD in the changer. If there is remove the loose CD. If the CD is stuck in the player itself insert the empty cartridge the changer will cycle through the process. Once it stops you can press eject button and the CD should be in the cartridge.
Feb 25, 2010 | Alpine Car Audio & Video
I have a 1996 ford explorer and the 6 disc cd changer is stuck and will not eject, I can hear it trying when I press eject button, any ideas???
good day. well if some kinda stuck you should open it manually. you can find a little hole on the cd changer just use a paperclip then insert it to the hole it will be open manually. and hope that it will not trip right after you put the cds again. hope this helps
Feb 04, 2010 | Car Audio & Video
I have a Sony 6 CD in a SMAX. A CD is blocked inside. I suppose 2 CDs are on the same position. (the first).Ejecting CD is impossible. Other CD positions (2 to 6) work properly
You need to pull the unit and disassemble the unit. Pop the top with 4 or 6 phillips head screws, pull off the top and you will see the problem immediately. Gently slide the jammed disc out of the cartridge and pull out of the unit if possible. If not slide it back to the tray. Plug the unit back in with the top still off and eject the cartridge. Inspect the cartridge for warps or bends, if there are any, replace the cartridge. Hope this helps
Jan 02, 2010 | Sony CDX-602 10-Disc CD Changer
6 CD Changer Stuck (Lexus LX 470)
Open the eject door and at the lower right side of the cartridge their should be a small indent that looks like you could poke it with a medium point pen. That's a reset for the changer. If that does not work, you will need to remove the changer from the car, pull off the top, plug the cable back in and hit eject. look for the arm on the backside of the cartridge and give it a nudge. It may just be stuck. Loading mechanisms usually do not fail before the optics or other!. If you need further help, post a comment with any model #'s on the changer and I'll look for info and help some more. Hope this helps.
Sep 29, 2009 | Car Audio & Video
Purchased a 1995 ford explorer with a 6 disc cd changer and it now will not eject the cd cartridge and when the cd player button in pushed a message comes up ''no dj''. have read the owner's manual and it...
If there is a cartridge in the unit, you need to take the player out. pull the housing and do a manual release. do not force it. Possible problem could be 2 discs in the same slot or 2 discs trying to enter tray, either way, if the cartridge is present, it's jammed and needs to be pulled apart. If my memory is correct the factory unit was either Alpine or Clarion. The cartridges are still available at most car audio shops. 20-30 bucks. If you don't feel comfortable pulling the unit, most custom shops can check it on the spot, and let you know if it needs to be sent out for repair. Stay away from Best Buy, etc... go to a custom shop that's been around for a while and you'll get honest service.
May 17, 2009 | Car Audio & Video
CD WILL NOT COME OUT OF THE SINGLE DRIVE IN A MULTIPLE UNIT CD CHANGER AUDI A6 AFTER PRESSING THE EJECT KEY
You should get the 6 case out by inserting manually a credit card sized card to it's side.
Once the case is out manually, take out all the cd's and insert the charger again. Open the radio...it should fix it.
Nov 29, 2008 | 1995 Audi A6
Ejecting magazine on Pioneer CDX-fm1257
I have very gently taken a pair of needle nose pliers and grasping the edge of the cartridge that holds the disk carefully work it back into the magazine.
Nov 07, 2007 | Pioneer CDX-FM1279 12-Disc CD Changer
Panasonic CQ-DPX33 CD Changer Logo
683 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
