Question about Tefal UltraGlide Easycord FV4256 Iron
How do you clean glide plate
How do you clean the glide plate on my iron
  • Anonymous Mar 28, 2014
    Cotton pants stuck to iron, need to clean off without damaging the plate
  • 328 Answers
IF its a ceramic non stick plate then the best way is to just to apply washing up liquid on a soft sponge to get dirt off. If the dirt is heavier try bicarbonate of soda and some lemon juice.
This works both with ceramic/non stick plates and stainless steel plates.
Posted on Jun 27, 2009
3 Suggested Answers
SOURCE: how do i clean the plate of the bernina pro glide
I have owned a Pro Glide Plus for years and use a product called Iron-off by Dritz to clean the sole. It is a tube of cleaner that you heat your iron and use a soft cloth to apply the cleaner. Make sure you have the cloth well padded so you do not get burned by steam. It can smell a little so be in a well vented area. This product has worked for me for years and I highly recommend it.
Posted on Dec 01, 2010
  • 4 Answers
SOURCE: Iron Cleaning
If steam iron clogs from minerals in water, follow use-guide directions for cleaning, or use a commercial iron cleaner. A fine needle in the nozzle hole may open it again. Sometimes "steaming" will remove lint clogging the iron; fill with at least 1/4 cup water, set it to "steam", and hold in the air or set flat on wire rack over heat and moisture resistant surface like counter protective mat. Let steam until empty. Using only distilled water in steam irons helps avoid mineral buildup. Or if you have burned stains or darkness on the bottom you can Heat equal parts of vinegar and salt in small pan rub solution on cooled iron surface to remove dark or burned stains
Posted on Feb 18, 2008
How can I clean the ceramic sole plate of my iron
Follow These Steps
  1. Mix water and baking soda. Make a paste of 1 tablespoon water and 2 tablespoons baking soda.
  2. Apply the paste to the iron. ...
  3. Wipe iron clean. ...
  4. Clean steam holes. ...
  5. Re-fill the reservoir. ...
  6. Turn on the steam. ...
  7. Pour out the liquid.
How to Clean an Iron Video and Steps - Real Simple
https://www.realsimple.com/home-organizing/cleaning/laundry/clean-iron How can clean the ceramic sole plate of my iron Google Search
Oct 26, 2017 | Irons
I have lost my instructions on how to "self clean"
Straight from the manual:
http://www.applianceinsider.com/storage/user-manuals/rowenta/user-manual/DX8000.pdf
Fill the iron with tap water to the max mark on the water tank.
Be sure that variable steam lever is set to minimum.
Stand iron on heel and plug in. • Set thermostat to ••• setting.
Once heated, unplug iron.
Hold iron horizontally over the sink with the soleplate pointing away from body.
Move the variable steam lever completely to the right and hold in the self clean position for one minute.
Warning: Doing this will cause steam and hot water to be ejected from the soleplate. Take all proper precautions and hold iron away from body.
• Move the iron gently back and forth and side to side until all water has run through plate.
• Carefully wipe all water and material from the soleplate with an old towel, as the water and minerals can stain the soleplate (although this has no effect on glide or performance.)
Warning: Iron and soleplate may still be very hot. Exercise care while wiping.
• Place iron on heel and leave to cool. Before using iron after self cleaning, test steam and burst
of steam on an old towel or cloth than can be discarded.
May 04, 2011 | Rowenta Professional DX8800 Iron
How to repair aan electrical iron
If the iron doesn't heat, make sure power is on to the outlet, check the electrical chord, and check the thermostat and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical chord . Also test and, if needed, adjust calibration of the thermostat.
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the sole plate. If the iron stains fabric, clean the sole plate, clean the tank with a commercial cleaner, and use distilled or filtered water.
The tools you will need are
  • Screwdrivers
  • Toothpicks or pipe cleaners
  • Sewing needle
  • Commercial electric iron cleaning solution or vinegar and water
  • Commercial sole plate cleaner or baking soda and water
  • Steel wool
  • Emery cloth
Please rate my solution.
Jun 25, 2010 | Rowenta Professional Luxe DM880 Iron
Iron leaking and plate dirty
If you have hard water, there will be a buildup of minerals where the rubber gasket on the water tank meets the steam chamber that is built into the sole plate. This will make the rubber gasket surface become hard and no longer seak to the team chamber, resulting in water leaking from the tank onto the outside of the iron.
If you are reasonably skilled with tools and have a Torx T20 driver, you can disassemble the iron and remove the rubber gasket between the tank and the steam chamber and soak it in vinegar to remove the mineral scale. First remove the three Torx screws visible at the rear of the iron and gently pry off the gray rear cover plate. This will expose two screws holding the rear end of the sole plate. Remove those two screws. Then gently pry off the stainless steel nose piece on the front of the iron; this is the curved piece that says "high precision" on it. This will then expose the screw that holds the front of the sole plate on the handle. Remove thqt screw. Pull the black connector at the rear of the iron off the two rods to which it is attached, and you can move the sole plate away from the handle. The rubber piece in the handle that is sort of oval shaped and about 2 inches long is the gasket that is probably causing the leak. Gently remove it and soak it in vinegar to remove the scale, and remove the scle from the round hole where it meets the steam chamber in the sole plate. .When they are clean, reassemble the gasket onto the handle and the sole plate onto the handle, connecting the electrical connections, and replace the screws, It is not simple, but it is doable.
Apr 14, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
I have a rowenta iron, and began to iron a tablecloth with gold embossing. Now it is stuck on the plate. How do I clean it?
Turn the iron back on, get a sheet of wax paper, iron back and forth on the wax paper it cleans all of the gold and grime off. Then take a Magic Eraser and clean the plate after it has cooled. Won't scratch your plate. Hope this works for you. I have done it often.
Dec 31, 2009 | Rowenta Power Duo Iron
Removing deposits on iron plate
Try adding some CLR to the iron, fill it up with water, and run self clean. Then wipe bottom of iron with an old towel. Repeat with clean water in the iron, to rinse out the CLR and minerals.
Jun 21, 2009 | Rowenta Power Duo Iron
How do i clean the plate of the bernina pro glide iron, it sticks when i am ironing.   my mistake, called Bernette ProGlide Plus  Model #1660 (an older iron, was my mothers, but still works)...
I have used the cleaner that is used for the corning cook tops (smooth cook top range cleaners).. It has worked great on mine...Hope this helps.
May 18, 2009 | Irons
Tefal UltraGlide Easycord FV4256 Iron Logo
1,068 people viewed this question
Top Tefal Irons Experts
Billy Detlefsen
Are you a Tefal Iron Expert? Answer questions, earn points and help others
