Question about Dometic Rooftop RV Air Conditioner
Black flakes spewing from my A/C vents
I have an 18000 BTU Frigidaire Gallery room air conditioner. We've had it for 6 years but last year it started spewing black flakes at the beginning of the season. The flakes seem to turn to dust if you touch them so we carefully vacuum them or they smear into our furniture and carpet.
No matter how hard we tried to clean it we could not stop it. After a month or more the flakes seemed to diminish. I just started it for the first time this year and the problem is back - black flakes all over our living room.
SOURCE: heat strip installation
It was quite simple, just installing the heat strip and my model only required removing the grill cover and mounting the element. The other optional installations didn't apply to my model.
thanks,
Don
Posted on May 27, 2008
22yooper
  • 828 Answers
SOURCE: Circuit Breaker and Dometic Rooftop RV Air
Since your RV A/C works O.K. when plugged in to the land line and the trip happens when you run it on your generator the problem may be related to the generator output. It is possible that the power being supplied by the generator is not handling the surge when the A/C starts. Starting Amperage on start up is about 5 times the running Amperage for about 3 seconds until the compressor comes up to its rated speed.
Posted on Jul 24, 2008
22yooper
  • 828 Answers
SOURCE: PROBLEM WITH DOMETIC RV ROOFTOP AIR conditioner
Check at the compressor terminals between the Red and the terminal for the overload protector to see if you are getting power to the compressor on startup.
skrbin
  • 121 Answers
SOURCE: what startup surge Watts required for 5000btu Air Conditioner
1.5kW
Posted on Feb 17, 2009
motor1258
  • 6674 Answers
SOURCE: Duo Therm RV air conditioner inadequate cooling
The rule of thumb is 20F difference (lower) than ambient temperature. Most manufacturers will tell you 20 F degress is about normal. In your case it does sound a little warm, but I need to ask, sorry. Was it working o.k. before in same basic temperatures? Have you cleaned coils & fins good on Evaporator & condenser recently? Have you removed filter inside & cleaned it as well, and looked to see if coils are frosting up by chance? Is this a ducted or non ducted system? I'm guessing on a 5th wheel, it is ducted, so make sure you have good discharge on all of those as well. Any blockage or restriction on the discharge side will also cause the problem. Keep me posted on what you find.
Posted on Sep 01, 2009
I have a Crosley 220 volt 18,500 btu window unit air conditioner with a heat pump. The cool air works fine when set on cold, but when set on heat, it doesn't blow warm air. What should I check first?
18000 BTU Air Conditioner ' The Air Conditioner Guide
www.theairconditionerguide.com > BTUs
An 18000 BTU air conditioner is your best bet if you are looking to cool a room ... 2) Frigidaire 18,500 BTU Window-Mounted Median Air Conditioner with ...Troubleshooting Guide. Lost your Everstar air conditioner manual? Fix it tips are here!
Nov 26, 2015 | Crosley CAHE18ER Air Conditioner
What is the btu
18000 btu or 1-1/2 ton
If you need further help, I’m available over the phone at https://www.6ya.com/expert/mike_9693b5ad75773352
Aug 07, 2014 | Goldstar LG LUCKY WG1800R Room Air...
The power on my N120E - DeLonghi 12,000 BTU Portable Air turns itself off
The DeLonghi Pinguino Air Conditioner is such a smart choice for people in need of a little extra cooling in their homes! My better half purchased our a couple of years ago when he realized his office was getting much warmer in the Summer than the rest of the house. Being hot natured, he thought a portable air conditioner would be a smart choice. We've loved it! It's on wheels, so you can move it from room to room quite easily (even my 10-year-old has been known to move it.) It's outside vents attach to an adjucstable plate that fits right in any size window in seconds. Just select what temp you want it and... done! Super easy.Right now we're currently using it instead of our central unit while the temps aren't too very high.
Jul 28, 2012 | Intertherm Heating & Cooling
An air conditioner spit sys inverter, I need the main control circuit board
Hi, here is the information you need to get any part you may need for this unit.
Quality Matters, Amcor
Toll-Free 866-725-9980
530-946-5869
This is all you will need. Parts for this unit are under warranty for 3 years, compressor, 1 year, with 1 year labor. Please rate me for my help to you. Thank you,
Shastalaker7
A/C, & Heating Contractor
Feb 24, 2011 | Amcor AMS180HR 18000 BTU Split System Air...
Replacement of window unit
Yes,you can,they are basically the same,you can get a 18000 btu to go in it.The more the btu`s,the higher they are anyhow.
Jul 22, 2010 | Heating & Cooling
Anybody there?
It depends on the room varables, If it has an attic, tile ceiling, what type of walls, where in the building is the room and so on? The biggest problems is all ways the power. Get a free estaimate from an A/C company. Everyone and myself needs to see the room before they give you an recomndation that can truly be applyed to your situation. But to give you some ideas, I would put a 2.5 ton - 3 ton unit just for over kill. Go with a straight cool package unit. If your company tight on cash just get a mini split system with a 30,000 BTU to 36,000 BTU cooling capacity. Cost for something thats going to last 20 years, avg. is $4,500- for the package unit and as low as $3,000 for the mini split.
Oct 17, 2009 | Frigidaire FAA055N7A 5200 BTU Room Air...
Sears Plasmaire spits water into room
It's probably just holding water somewhere and getting thrown out. I've seen people drill holes on the bottoms to drain water quicker.
Sep 03, 2009 | Kenmore 75085 Air Conditioner
Black particles coming out of the room air conditioner
dirt, dust, or mold. could also be the tubing insulation flaking off. either way, open it up and clean it out. the dirt, dust, and flaking insulation can restrict air flow through the coils and cause the ac to not function properly. if it is mold, it's can cause sickness (legionaire's disease). do not use chemicals on the coils. it might be best to replace the ac alltogether. to prevent mold: when installing the ac, make sure the unit is slightly tipped towards the outside. any condensation that collects on the coils will drain out. failure to do so will result in water pooling inside, and this can cause mold.
Jul 30, 2009 | Kenmore 73259 Air Conditioner
The unit is a 12000 BTU energy efficient model purchased from Lowes 3 years ago. It is not cooling. The fan runs fine but it just isn't cooling. The filter doesn't need cleaning. What could it be?...
The compressor is probably not running.
The Main reasons that this will happen
1 - A bad run capacitor (silver or metal capacitor)
It’s either shorted, grounded or open.
If it’s shorted a lot of times it will bulge out, (sometimes slightly)
2 - A bad start kit ( plastic capacitor and Relay connected to it )
The capacitor is either shorted or open
The relay either has an open coil between terminals #1 and #5
Or the relay is stuck.
Any time you change the capacitor or relay you should change
the other, especially if they are over a year old.
3 - A loose, burnt or disconnected wire
4 - Wired wrong
5 Compressor is open (windings burnt open)
6 Low on charge not getting enough cooling back to compressor, (Feel top of compressor to see if it’s hot it shouldn‘t be)
7 Some compressors have a black plastic overload under the compressor cap which could be bad.
Jul 30, 2009 | Frigidaire 12,000 BTU Compact II Room Air...
Dometic Rooftop RV Air Conditioner Logo
193 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
