Question about Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius 1100 WM63. fills with water...I dont think it is heating water...rarely rotates and spins (saw it once in early stage of J prog only) seems to fill and empty but no rotate or spin. Controller rotates ok..No burning smell...
  • 82 Answers
If it fill with water then stops it is the ellement the machine first fills turns the drum then heats up the thermostat cuts in and the it emptys rinses and spins so if it does not get to temp it will stop or continue to wash forever
Posted on Jun 28, 2009
Hotpoint Aquarius 1100 WM63 Not Spinning Clicking Programmer
I would suggest you check the brushes in the motor, as it sounds like they are worn out.
Replace them if they are less than 3 or 4 mm long
This would give you the symptoms you are describing.
Please rate my solution.
Thankyou.
Feb 09, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Aquarius 1100 wm63 very noisy spinning
Remove rear cover of washer.
Remove drive belt.
From inside the drum, spin the drum by hand, if it is noisy or feels rough, then main drum bearings have failed.
If no noise, then possibly motor bearings noisy.
Hope this helps Thankyou.
Nov 27, 2009 | Hotpoint Washing Machines
Hot point aquarius 1100 - does this have a heating element for cold water feed ? or does is need direct hot water feed ? (there is a inlet at back for both hot and cold so presume no heating element ?)
All Hotpoint washers have heater element regardless of whether they are cold fill only, or hot and cold fill.
if 2 connections at rear, then it is hot and cold fill, if only 1 connection, then it is cold fill only.
Thanks.
Jul 24, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washing m/c water not heating up.
Make sure the economy button is not selected if it has one, as this bypasses the heater..
you say you have had element checked and seems o/k, to be certain it is o/k then test with a meter when it is on heat stage in the prog, and make sure you have a 240V reading across the heater terminals, if you have and it does not heat, then the element is faulty.
Plz rate my solution.
Thanks.
Dec 23, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint wd440 aquarius
Not all programes fill with hot water.Try on 95 degree wash if it takes hot water ,you are dialing a prog,that does not take HOT.
Oct 31, 2008 | Hotpoint Aquarius WD63 Front Load...
Drum not turning
My problem is the same as colins my hotpoint wm63 is starting okay i.e. water fills up but drum is not turning. I can hear it clicking through the cycle but drum doing nothing. i to have just put in new carbon brushes but still no joy please help
steve
Apr 08, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius wm63
The heating element for this paticular model is located on the front casing of the drum.. you have to remove the front panel complet with the door and you will see it at the bottom behind a black protective cover.
Nov 27, 2007 | Hotpoint Aquarius WF000 Front Load Washer
hi in the powder tray is the conditioner tray there is usually a plastic part that the water runs up into so it can pass to the machine this plastic part gets blocked,pull it out and give it a good clean,if ther are two small plastic pipes make sure water goes up one side and down the other
Oct 19, 2007 | Hotpoint Aquarius WD63 Front Load...
Aquarius 1100 WM63
some times when there is no motor action people think the machine has stuck try a set of brushes you must diconnect from the electrical mains first if unsure call an expert you can not put a price on safety
Oct 08, 2006 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WMA42 Front Load Washer Logo
673 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
