Question about Danby 7,000 BTU Portable Air Conditioner - Euro Gray
Aircon mode just stopped working after 3 years
My airconditioning mode stopped working today after working fine for 3 years. When I switch it on in aircon mode, the green light (Just above where it lists the modes on the left of the machine) comes on, flashes a few times then goes off. The aircon mode just works like the fan mode now.
  • 3 more comments
  • kansablankie Jun 27, 2009
    Ok, I will open it up. I have no idea what to look for...loose wires somewhere inside?
    Can you please be more specific as in which wires would be for the aircon mode as there is also a heat, fan and dehumidifier mode? I have it open and I do not see anything loose.
    I opened it, cleaned it and checked for loose wires even though not really sure what to look for. I plugged it in just now and it is still doing the same thing after it has been cleaned.
    how would I know for sure? I fit is the compressor, is it worth replacing it and where would I find one?
    Thank you for the detailed explanation. That is exactly what I needed.
  • 2,071 Answers
This symptom is in control panel circuit.The common causes circuit problem is cold solder or loose connection that why the machine funtion abnormally and it cause the machine to overheat and shutdown automatically. The switch and control chip are the usual suspects because the switch experiences lots of electrical and thermal stress and the control chip is a complex IC. Also possible is a defect in the circuit board such as a cold solder joint. A cold solder joint is where a lead of a component is not soldered at a high enough temperature and results in a bad electrical connection which can respond to physical shock and thermal stress.Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected . When the aircon unit turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. A solder joint may also be broken or cracked because the was tug or hit. Look on the front and back of the board along the defective circuit to see any components that look like they are not soldered effectively or the solder connection is cracked or broken. A cold solder joint looks dull and/or bulging unlike the smooth and shiny normal solder joints. Its better you resolder all components parts joints of control panel circuit board.Thats is the best solution for this kind of problem . Good luck; Regards: VOTIT
Posted on Jun 27, 2009
    Sergeant:
    Champion:
  • 216 Answers
Sounds like the compressor dead ,that's why it will is run it the fan mode and not in the A/C mode.
    President:
  • 828 Answers
Check inside the aircondition if have some disconnected wires for aircon mode... have some clean every month.
TELEVISION IS IN STANDBY WONT SWITCH ON TO PICTURE
First is the set should have a 1 year parts and or labor warranty--second: in order to offer advice or give help I need to know brand and model number.
Dec 06, 2012 | Televison & Video
Aircondition
You don't ever have to touch the refrigerant system under the hood as long as the A/C is blowing cold and working good. Don't ever listen to those ploys saying they'll service your A/C system, there is no such thing as a A/C service. The only thing you can actually do is remove all the refrigerant and put it right back in. If there was a leak in the system, you would know it because the A/C would eventually stop working.
I hope this info helps!
~subyguru~
Sep 21, 2012 | 2006 Hyundai Tucson
I have a GrandAire and the aircon works fine; when I turned the heat on, it seems to work fine (warms the house), but the fan in the outside unit is not spinning when the heat is on...is this a problem?...
I think your unit is working in good condition. If you keep in cool mode the out door fan runs to condensate the heat in condenser by taking fresh air from the ambient. And when you keep heat mode, definitely the ambient temp will be too less.I fit takes from their then compressor will get frozting and it couldn't work properly. Depending on pressure increase, the fan will automatically run and stop. Don't worry. Thanks.
Dec 16, 2010 | Heating & Cooling
We have central heating and airconditioning both using the floor duct but the airconditioning has not worked since we have moved into the house but the previous owners said it did had trademen to look at...
make sure you don't have a flexible duct from the a/c to the vent. it can fill with water if drain is clogged ,check to see where drain runs too tape a wet dry shop vac to it and **** it out good and check for water built up in ducts and drain
Nov 09, 2009 | Heating & Cooling
2006 Impala message "Hot Engine A/C Off"
it means you need to turn off you aircondition coz the engine has high temperature. but if your not using aircon you have a defective thermostat replace it at once.
Apr 16, 2009 | 2006 Chevrolet Impala
Aircon and radio not working!
i would check through the fuse box first to see if there were any blown fuses hope this helps regards Jim
Apr 02, 2009 | Ford Fairmont Cars & Trucks
Transfer error 0X8004C01A--Just started--What to do?
Some audiobook services have fixed-term licenses of 1-year - at the end of the time period, you have to resynchronize the audiobook files to the audiobook service itself.
Here is an interesting clip from the Sandisk forums on this exact issue:
Overdrive library books have DRM-encryption to make them stop working at the end of the loan-out period unless you renew them. This means your player must be set to MTP mode.
If your player intentionally or un-intentionally got switched to MSC mode, that would prevent the DRM content from being loaded onto your player and account for the error message.
Check it in SETTINGS > USB MODE on your player."
-Tha Mp3 Doctor
Feb 03, 2009 | SanDisk Sansa e270 MP3 Player
Air condition blower
After researching abit I opened the cover under the glove box and saw that a wire to the blower wasn't connected. I plugged it in and taped it and now it works fine......
Jul 03, 2008 | 2002 Chrysler Sebring
Danby 7,000 BTU Portable Air Conditioner - Euro Gray Logo
154 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
1STHVACMAN
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
