Question about THQ The Lawnmower Man
Mountfield SP534 Lawnmower - Blade Spindel Bent?
I hit a small tree stump whilst mowing and suspect I have bent the main blade spindel as it feels as if the blade is catching on something when you turn it around by hand. It will turn part way round then seize as if it's rubbing/jamming. With a little presssure, it will free and then turn half way round again. The balde isn't catching so I wonder if I have bent the main spindel slightly. Just the owners manual give you no instructions to fully dismantle the mower and I'm struggling to identify the problem. Probably not worth the money to take it to a repair shop. Any ideas? Any suggestions would be most welcome.
  • 410 Answers
That spindle shaft looks bent to me. Yes sir you've already proved that it is. Now your job is to take it apart and pound it straight (ha) or replace it (better).
Posted on Jun 27, 2009
5-h-push mower has bad veberation blade is on tight
bent blade, bent crankshaft, blade not balanced are all possible causes for vibration.
If you sharpened the blade recently try rebalancing it.
You could have struck something while mowing and bent the blade or bent the crankshaft on the engine.
If blade is bent replace it. If out of balance, rebalance it.
If crankshaft is bent replace it, have it straightened or replace the engine.
To replace or straighten the crankshaft it will require engine tear down which requires knowledge and tools for small engines.
Apr 22, 2016 | Garden
Honda HR215 hits stump - still runs and cuts but engine vibrates when running IF the BLADE IS NOT TURNING.
you could have bent the blade or the crank look at the blade then remove the blade mount and spark plug turn on its side and turn the engine over and look for crankshaft runout
Apr 07, 2012 | Garden
Lawnmower blade hit a stump now can't pull starter cord
sheared timing flywheel key replace it check to see if crankshft bent if throw it away or replace motor
Apr 01, 2012 | Briggs & Stratton Briggs Stratton...
I ran over a small tree stump while mowing and this stald the enginr instantly and now it will not start. and is back firing when trying to. Need help with diagnosis and a manuel to show prseadure for...
I have had that happen when my wife and kids ran over stuff...
One time it was just the blade that got bent and the other time it was the motor shaft...
Changing the blade is easy...straightening out the motor shaft is near impossible with major repair tools...
Check and see what is bent, but my thought is that something got bent which throughs everything out of balance and then the motor will not run...
heatman101
Jul 30, 2010 | Craftsman Professional 775 Torque 175 cc...
I have a troybilt self propelled model series 830. Yesterday we hit a stump and the blade bent and shut the lawnmower off. I recranked it and tried to recut when i noticed the blade was bent so i took it...
the blade is bent,replace it or you will ruin the engine,a new blade is much cheaper than a re-built engine and bearings,you bent it soooooo bad you can no longer even balance it, and if you continue it will destroy the engine if you have not done so already,this is the vibration you feel NOW
Jul 29, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Cub cadet rzt 50, hit stump, blades wont engage but not bent
The blades on this cub cadet are activated with air pressure. Chances are that when you hit that stump, you either blew a fuse or the control module that allows the blades to spin. Begin by checking the fuses. J.
May 28, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
After hitting a low bearing tree stump with my troy bilt 6.75 push mower it bent the blade and now refuses to start. How do i fix it?
You will need to replace the key under the flywheel because it probably sheared when you hit the stump and you will need to replace the bent blade before starting the mower again.
I hope this helped
Please Rate Me
May 22, 2010 | Garden
I hit a rock with my push lawnmower. The
Oooh boy, I know you bent the shaft, but why it is blowing oil out the carb, I don't know if I would even bother with the blade, you could go buy the same mower, then you would have some parts. Unless you just bumped it hard enough to throw oil around in there, it might settle down, but it is a long shot. I hit a stump once and bent the crank, it was lights out for that mower. Hope this helps.
May 07, 2010 | Mtd 22" Yard Machine Push Mower
My Cub Cadet i1042 tractor shuts off when the blade is engaged. This happened after I ran over a ***** and/or stump. Every time I try to engage the blade the engine shuts off.
Check for bent blade against deck housing.Possible you bent something on mowing deck,check all spindles and pulleys.You could have something hung on blade and making contact with deck. Rarely will the motor be hurt from hitting object on rider.
Apr 24, 2010 | Cub Cadet Street Sign- tractor lawn riding...
New mower hit small stump, cuts too low now/ can't adjust height
It is a bend blade. I feel your pain...I had a riding lawnmover that took a good two-hours to take apart and chage blades and 3/4 of an acre with old ornamental garden root balls popping up all the time. That was a long summer...
You may want to get the blade ahead of time so whomever can help you look under the mower can change the blade once they confirm it is bent. Even if they can fix the old one it is a blade you will need sooner or later and they are not very expensive.
Dec 17, 2009 | Garden
THQ The Lawnmower Man Logo
607 people viewed this question
Top THQ Video Game Consoles & Games Experts
James Wishart
Sandeep Kumar
Edward Talavera
Edward Talavera
Are you a THQ Video Game Console and Game Expert? Answer questions, earn points and help others
