Question about Sony DCR-HC26 Mini DV Digital Camcorder
Buttons on LCD do not work, cam sony hc16e
For some reason i cannot press the buttons on the LCD. When i try hitting the commands, they dont work. Calibration is not working as well.
2 Suggested Answers
  • 169 Answers
SOURCE: Touchscreen buttons not working
the flexwire is the problem of your camera, the touch screen connection is already cut..go to a service center for replacing or repairing the flexwire...is not easy for repairing that if you are not a technician that wiring is like a strand of hair that why is difficult to fix but in our shop we modified that and become more durable than the original...
Posted on Oct 19, 2007
Tip
How to program your RM-V310 Sony Universal
Step 1: Entering the Code Number
1 See the supplied "Component code numbers", and find the threedigit
code number for the desired component.
If more than one code number is listed, use the number that's
listed first to complete the steps below.
For example, if you're setting up a Philips' VCR, you would use
the code number 035.
If your component isn't listed, see "Searching for the Correct
Code."
2 While pressing the SET button, press the
POWER button.
3 Press the button of the component that
you want to set up.
Note
On the VCR, CBL, SAT, AMP, CD, and DVD buttons, "video cassette
recorder", "analog cable box", "digital satellite receiver", "receiver",
"CD player", and "DVD player" are assigned respectively at the
factory. But you can also assign other components on these buttons.
For details, see "Changing the Component Type on the VCR, CBL,
SAT, AMP, CD, and DVD buttons."
4 Enter the component's code number.
For example, if you're entering the code
for a Philips VCR, you would press
5 Press and release the ENT button to store
the code number in the Commander's
memory.
6 Go to "Step 2: Checking if the Code Number Works" to finish
setting up.
1 Power on the component you want to set up.
2 Aim the Remote Commander at the component and press a button
to check if that button works.
For example, press the POWER button to see if it works on your
component .
3 Check that the other buttons of the Commander is operating the
corresponding functions of the component.
You can write down the code number on the label inside the
battery compartment lid.
If the Commander Doesn't Seem to Be Working...
• First, try repeating these setup procedures using the other codes
listed for your component (see the supplied "Component code
numbers").
• If - after trying all the codes listed for your component - you still
cannot get the Commander to work properly, try the search
method described in "Searching for the Correct Code."
These instructions came from the Sony RM-V310 Operating Instructions Manual. To Download the Full manual for FREE click HERE>
on Oct 07, 2010 | Sony RM-V310 Remote Control
How can I get my onkyo remote control (RC-693M) to control my Sony LCD tv?
Manual says: 1. While holding down the REMOTE MODE button for the mode in which you want to use the command, press the [ON] button. *** Hold both buttons down for 3-4 seconds *** 2. Press the button you want to learn the new command 3. Point the remote controllers at each other, about 2-6 inches apart, and then press and hold the button whose command you want to learn until the Remote indicator flashes. *** Hold them level with each other, 2-3 inches apart, and don't move them at ALL while you press the button on the old remote *** 4. To learn more commands, repeat steps 2 and 3. Press any REMOTE MODE button when you've finished. *** If the command was learned correctly, the remote indicator will flash *SLOWLY* twice - about a 1 second blink, and the red light will remain on. If the command was NOT learned correctly, it will blink twice *QUICKLY* - about .5 seconds, and the red light will go off. *** If the red light stays on, you're golden - keep going until you get to a button that flashes red quick and the light goes off. Some of the buttons I programmed took 6-7 tries in exactly the same position to learn.
Oct 09, 2012 | Onkyo TX-SR705 Receiver
I entered,in error, Command mode 3 on the set up and now the remote control won't operate the machine.The display keeps showing DVD 1,how do I restore things?
Try this (works for Panasonic) - remove the batteries from the remote (as if to replace them with new ones), press any button on it to clear its buffer, then re-insert them (if they are reasonably fresh). Point remote at unit, press 1 and ENTER/OK buttons together - hold for 10 seconds, then release. This should restrore the command back from remote to the unit, and it should now fully operate. Just something to try, it may work.
Many Panasonic DVD recorders operate on the same principle; there are 3 remote command mode settings (default is DVD1) - so it's very easy to make errors in setup, but just as easy to correct.
Apr 18, 2011 | Sony RDR-VX420 DVD Recorder/VCR
Volume buttons have to be pressed hard to work
Try mapping the Volume buttons to the LCD screen in each Activity you use them in. To do this, see below.
1. Launch the Logitech Harmony Remote software and login to your account
2. From the Harmony homepage, click on the Customize Buttons button for the Activity you wish to customize.
Additional Buttons:
To modify commands on the LCD screen, click on the Additional Buttons tab at the top of the page.
a. In the Button column, select the button you wish to customize, from 1 to 4 for each page. The illustration of the remote below shows where each button is placed on the display.
b. In the text box in the Button column Type in the name of the button.
c. In the Device column, select the device you wish to send the command to.
e. In the Command column, select the command you want from the dropdown list
f. You can delete a command by clicking the trash can icon beside it
g. You can move commands to different button positions by using the arrows
h. Click on the Add new Page button to add another page
i. Click on the Learn Command button if the command you need is not in the drop-down box. You will be able to capture the button from your original remote.
j. Click on the Add Sequence button to create a custom sequence of 5 commands for a single button.
k. After making any changes, ensure that you click on the Done button to save the button customizations. The last step is to update your remote.
l. Connect the Harmony to your computer’s USB cable and click on the Update Remote button on the Harmony homepage
Test the commands on the LCD. if they do work id advise you to contact logitech.
Jan 14, 2010 | Logitech Harmony 880 LCD Remote Control
Sony PCS-1 dont remember admin password
1. Access the Setup menu as follows:
Press and hold the MENU button on the remote commander.
2. Select Dial using the �� button on the remote commander.
3. Access the Service menu as follows:
Press 7 then 2 on the remote commander (without pressing the
PUSH ENTER button).
The Service menu appears. (See Figure 1.)
NOTE: To cancel Service mode and return to the Setup menu,
select Cancel using the arrow buttons, and press RETURN
Clear setup and FINISH
Bye Zamani Ali
azamani@iooc.co.ir
Nov 24, 2008 | Sony PCS-1 (PCS1) Video Conference
Dvd recorder rdr-hxd860
press stop button then the power button together the player will go off. put it on again the remote should work.
Mar 15, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Lcd screen don't work after I remove cam from dock
As your buttons are working when you press buttons on LCD panel ,The LCD strip which connects LCD Panel to main circuit board (called main board or mother board) is partially dammaged.The symptom changes as per the actual cutting of that strip. after replacing the strip FP-*** will solve the problem. FP-is the part No. If you want correct part code I can give you later as I have to chk in service manual Thanks
Mar 09, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony DCR-HC26 Mini DV Digital Camcorder Logo
144 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
