Question about Fedders AED24E7F Wall/Window Air Conditioner
The fan is coming on but the compressor is not.Even after the unit has been off all night (long enough to cool down or ice to melt) the compressor does not come on.
  • 1,056 Answers
All window unit compressor have a thermal breaker mounted on it. It is to protect it from overload. On a hot summer compressor work harder to keep us cool. Sometimes this thermal breaker fails for good. Unplug the ac. Open it, on the compressor there is a bulging thing sometimes cover with rubber. Thats the thermal breaker. Check its continuity. If you don't have an ohmeter, just byspass the two terminal of the thermal breaker with wire. Plug it in, but be carefull, turn on your ac. The compressor should come on.
Posted on Jun 27, 2009
Front grill
Check the air filter and if it is dirty, replace..
Turn equipment off and let the ice melt.
After ice melts, place a/c in cooling mode and set the thermostat to 3 degrees below room temp display.
The indoor unit fan should start blowing cold air immediately and then turn off once the room temp drops one degree below the cooling temp setting.
If the indoor unit does cycle off, check the outdoor unit and make sure it turns off at the same time.
If the outdoor unit continues to run and the indoor fan is not running, the indoor unit will ice up.
A defective compressor relay that is stuck in a closed position will cause icing of the indoor unit because it keeps the compressor running when it should turn off with the indoor fan.
Do you have an error code being displayed on the controller?
Is there an led light that is flashing on the indoor unit?
Another possibility causing the indoor unit to ice up is if the freon in the system starts to get low.
Make sure the ice has all melted for this next check.
Pretty easy to check without special tools.
If the air filter is clean and there is no dust/ dirt blocking the fins on the indoor unit, turn a/c back on to cool and check that the indoor unit fan comes on and is blowing air good.
Once everything seems to running good go to the outdoor unit.
There will be two lines with black rubber insulation covering them.
Peel back the insulation three inches on each line and observe the copper lines.
If either line starts to frost up the a/c system is most likely low on refrigerant.
Another cause of indoor unit icing could be that the aluminum fins behind the air filter are clogged with dust or other foreign material.
This would block the air that must be pulled in causing the indoor unit coil to become too cold due to lack of air flow and it will ice up.
Operating the cooling system when the outdoor temperature is below 60 degrees can cause the indoor unit to ice up also.
I'm Robert.
Florida certified a/c contractor. 30 years experience.
Hope this helps.
Mar 18, 2014 | Fujitsu Heating & Cooling
Subzero 611 freezer not cooling
Could be but before that check if settings are working. Set the freezer settings to coolest and see if cools. If ok, set to desired temp.
Dec 30, 2013 | Refrigerators
Split AC whole unit turnig off at each compressor start up!
Dirty coil wash outside unit with water and change indoor unit filter
Jun 08, 2017 | Heating & Cooling
LG 8008R compressor runs one minute then fan blows 3 minutes
You need to have an AC tech come out and do some preliminary testing on this.
May 12, 2017 | LG Heat cool Window Air Conditioner
Ice formation in the indoor unit
you need to have the unit checked for the amount of freon in the system this must be done with a gauge set the freon amount is obviously incorrect
also the a-frame evaporator must be sealed in the furnace cabinet
May 28, 2009 | LG Heat cool Window Air Conditioner
Fridgedaire Elite frost proof fridge part not cooling, Freezer sems fine
If the frozen side is colder than normal and some extra frost is forming where the fan blows,and there is ice in the bottom of freezer compartment, and the cool side is not cool enough, their is a good possability the defrosting unit is not removing all the frost and ice . the defrosting unit has a timer (usually near thermostat) that turns off the cooling fan and compressor and turns on a small heater around the evaporator ( about 20 minutes every 2 days) (evaporaror is cold heat exchanger coil inside the back wall behind a cover near the recirculating fan0, the fan circulates air to both compartments through two small openings, if these openeing are closed by ice buildup cool air can not circulate to the cool side. cure 1. remove all food and leave fridge off for 24 hours with doors open (take precautions to ensure children can't get locked in side and suffocate, if you get a qt of water in bottom of unit (may leak on floor) ice buildup that the defrost heater can not remove melted and was your problem . turn frig on replace food on unit. cure 2. turn frig off, remove food from both sides, remove shelves that block access to evaporator, remove cover over evaporator if you see the evaporator coils free of ice look at openings (2) to other side, one may be blocked with ice the other with frost, carefully melt ice with hair dryer.
If the evaporator coil is solid ice heater or timer or fan has failed. good luck
Aug 09, 2008 | Zanussi Z57 / 3 Bottom Freezer...
My AC unit keeps freezing up on the copper lines going into the house from the outside unit. It also freezes up on the inside lines and the air is not cooling my home down.
Operate your air conditioner with the fan in the on position. But first turn the fan on, turn the temp up or shut the cooling off. Your coil is more than likely frozen over. At night when outside temperature drops the refrigerant pressure and temperature in the system also drops. This action can cause icing of the cooling coil, with the fan in automatic everything shuts down at the end of a cooling cycle. Thus no air movement to melt ice on previous cooling cycle.
May 09, 2008 | Heating & Cooling
The unit is nolonger cold and ice is melting
i have the same problem as above. the lights are on in both the refrigarator and freezer. I do hear the motor (fan) running but there is nothing cooling coming out.
Feb 15, 2008 | Whirlpool ED5GTNXMQ Side by Side...
I have a ed5fhgxkq00 side by side Whirlpool refridgerator that stopped cooling. It worked fine up until last night when we noticed that the ice was melting. Now it gets a little cool but not cool enough....
If the compressor has a fan next to it, be sure it is running. if the relay is clicking every few minutes it may need to be replced. contact local parts distributor.
Nov 04, 2007 | Whirlpool ED2FHSS Side by Side...
Hot point side by side
Could be stuck in "defrost" mode. Happens a lot. See if you can hear if the compressor is running or the compressor cooling fan is running (in back underneath the unit). Worse case is the refrigerant leaked out and you have a sealed system problem.
Sep 28, 2006 | Hotpoint FFU00 Side by Side Refrigerator
Fedders AED24E7F Wall/Window Air Conditioner Logo
706 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
