Question about KitchenAid 24 in. KUDP01DL Built-in Dishwasher
KitchenAid KUDP01DLWH6 dishwasher filter clog
My KitchenAid KUDP01DLWH6 dishwasher is making more noise than usual. This happened a few years ago until it finally stopped working. It was under warranty and the repairman replaced the pump; the filter had clogged up due to the silt in my water (passes through a 1 micron house water filter). From above I watched him fix it, but now I'm not sure where that part is? I figured before taking things apart until I find it, I'd ask for help. Advice or a schematic would help. Thanks in advance.
    Problem Solver:
  • 6 Answers
Follow the main water supply line. It goes to a solenoid valve which is normally located front left side under the dishwasher.
1. Turn off the main circuit breaker for the dishwasher.
2. Turn off Water supply to the dishwasher.
3. Remove lower front panel.
4. Remove Water supply line from solenoid.
5. remover wire connections from solenoid.
6. Remove 2 mounting screws from solenoid.
7. Take solenoid valve out.
8. Look inside the valve where the water supply line was connect to, You will be able to see the filter. it is just a screen and you can easily clean it.
Good Luck
Posted on Jun 29, 2009
DISHWASHER IS NOT DRAINING COMPLETELY, LEAVING ABOUT 2 IN OF WATER
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 30, 2011 | KitchenAid KUDS301V 24 in. Built-in...
Wont drain
Hi
Daniel
Aug 01, 2011 | KitchenAid KUDS24SE Built-in Dishwasher
My dishwasher is filled with water and won't drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Daniel
May 07, 2011 | KitchenAid 24 in. KUDS02FRSS Stainless...
Water in dishwasher, will not pump out. Noise when machine is turned on
Hi
Daniel
Mar 25, 2011 | Tricity Bendix 24 in. BDW53 Free-standing...
Kitchenaid dishwasher KUDI01TJWHO will not drain. Where do I check for a clog?
Hi
Feb 09, 2011 | KitchenAid KUDR01TJ Dishwasher
My KitchenAid KUDM25SH has been operating fine for 9 years, but will not drain now.
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose or the drain pump not working. First try to clean the drain hose and drain pump filter for any clogs, then check drain pump operation. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 26, 2010 | KitchenAid 24 in. KUDM25SH Built-in...
Not draining and making noise
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump. The noise you are hearing is from the drain pump.
Please note that dishwashers don’t drain out the complete water such that heating element doesn’t overheat.
Daniel
Aug 20, 2010 | Dishwashers
Kitchenaid Whisper Quiet + dishwasher making loud humming noise
Very likely pump motor shaft seal leaks water into bearing casing buildup of rust and consequently noise. I just replaced $112 worth of pump assy and it's back to normal. I would also buy repair manual for $10 on-line to be sure how to disassemble the sump to get to the pump.
Jul 14, 2009 | KitchenAid Dishwashers
Top rack remains dirty
spin the top rotary arm to make sure it spins freely also take it off to see if its blocked (run it under tap) check all other filters too and when you load dishes make sure they do not obstuct top rotary arm if none of this works then it's time for an engineer im affraid good luck
Jan 26, 2008 | KitchenAid 24 in. KUDK02CR Built-in...
KitchenAid 24 in. KUDP01DL Built-in Dishwasher Logo
1,191 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
