Question about Hitachi Performa CP-RS55 Multimedia Projector
Hitachi Performa CP-RS55 Multimedia... Problem
Hi i accidently jogged the mains input on the projector which then caused the internal fuse to blow i replaced it but it keeps blowing everytime i put the main plug back in now and i have retryed this over 5 times now and it still fuses please please help me!
  • Scott Burns Feb 05, 2009
    What do i do now then ?
  • 55 Answers
Ok " sounds like you have a short, thats why it's blowing fuses
Posted on Jan 21, 2008
How to reset the filter timer of HITACHI CP-RS55 ?
(1) While the projector running, press the MENU button to open the menu.
(2) Choose "OPTION" , then press ENTER button.
(3) Choose "FILTER TIME", then press and hold the RESET button for 3 seconds.
(4) Choose "RESET" .
Feb 25, 2011 | Hitachi Performa CP-RS55 Multimedia...
There is blue shadows in the picture, my hitachi cp-rs55 just got a new lamp, but the problem is still there???? How do i solve this problem??
Hi
The problem could be caused by the connection or configuration of your video equipment. Check the following:
  • Make sure your component-to-VGA video cable is properly connected.
  • Select Component Video as the Computer Input setting in the Signal menu.
  • Make sure the connected video equipment is set up to output video to component video.
Hope this helps
Apr 01, 2010 | Hitachi Performa CP-RS55 Multimedia...
Hi i have a bluish tinge on screen?
clean the entire optics of your projector.
Oct 09, 2009 | Hitachi Performa CP-RS55 Multimedia...
Problem with hitachi cp-RS55 multimedia projector sir
There is a menu item which has both the lamp hour reset and check air flow, etc. You must go into the menu and reset the air flow item. MAKE SURE YOU CLEAN THE DUST FILTER!! Heat is the number one killer of projectors and Hitachi's run "hot". I clean my projector once a week--Hey, I'm not rich. lol! Also, excessive heat will cause the lcd panels to fail prematurely and cause lots of other components to do the same.--Rick
Mar 16, 2009 | Hitachi Performa CP-RS55 Multimedia...
Hitachi cp-rs55 not working,tic.tic.... noise coming from project
make sure you reset the lamp timer. Manual has the steps. Hitachi Performa CP RS55 3 LCD Projector
if the timer is reset, try cleaning the color wheel. Optoma HD20 Projector Cleaning this video is for an optoma but the color wheel is cleaned the same way in most DLP projectors. Dirty or dusty color wheel sensors cause the projector to shut down and act like its the lamp.
Feb 02, 2018 | Hitachi Performa CP-RS55 Multimedia...
Instruction Manual
Pls try here. You would need Adobe Acrobat Reader to open, view and print this type if file.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 15, 2008 | Hitachi Performa CP-RS55 Multimedia...
My CP-RS55 Projector Doesn't Work??? No Light?
Hi there
If the unit is brand new , they should replace it under warranty.
This is most probably a faulty Powersupply / Fanboard !
Apr 15, 2008 | Hitachi Performa CP-RS55 Multimedia...
Hitachi CP R555 Multimedia LCD Projector
Hi there
In your Menu options there is a subfolder where it either reads lamp or lamp timer.
Scroll down to it and hold down you right or left arrow key on the Projector for a couple of seconds.
Mar 23, 2008 | Hitachi Performa CP-RS55 Multimedia...
No power lights
ok " could be a internal fuse, or bad transformer
Id check for a fuse first
Nov 16, 2007 | Hitachi Performa CP-RS55 Multimedia...
Internal fuse
HI
Check that you use another power outlet,see that the power cord pins are clean,and not burnt or use a new cord,the connection at the projector makes a GOOD connection with the new cord.
You will need a multimeter to check if there is voltage at the inside of the projector cord connection.You will have to remove the internal fuse before you check the the voltage inside.If all looks good then you will have a fault on the circuit board-shorted component on power supply side or further in on the circuit(need an electronic tech for this).Hope this helps--Jay
SAFTEY FIRST ALL TIMES--NOT SURE DO NOT DO IT
Oct 16, 2007 | Hitachi Performa CP-RS55 Multimedia...
Hitachi Performa CP-RS55 Multimedia Projector Logo
210 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
