Question about Kenmore 63942 Dryer
My Son's dryer shuts down about 20 minutes into the drying cycle
My son has a Kenmore 90 series; model number 67902790. When he goes to dry clothes, the dryer works about 20 minutes and then it shuts down. The curcits have all been checked and are ok. What is he suppose to do? Under products you do not list the model or model number for the kenmore he is having problems with, so I listed the next best thing.
  • 5,911 Answers
Most dryer heat related problems can be attributed to poorly installed, kinked or clogged dryer ventilation ducting. It sounds like the Thermal Fuse may be beginning to fail. I have experienced this problem on only one other occasion. Normally the Thermal Fuse will blow (like a fuse is supposed to) and has to be replaced. However, I did have a problem similar to yours where the fuse would trip when it was hot, but when it cooled, the dryer worked fine. Now if you are having problems with the Thermal Fuse tripping, its generally for a reason. If the dryer exhaust vent ducting, or dryer interior has not been checked or cleaned recently, I would recommend doing so now.
A simple test that you can try is to remove the dryer vent hose from the back of the dryer and dry a load of clothes as you normally would. The air coming out of the exhaust vent should be forceful and warm (about 140 degrees F). If your clothes dry normally, with no problems, I would recommend checking the ducting at the point where it leaves the dryer to where it exits your home. Locate and fix any sags, kinks or choke points that can lint to accumulate and clog.
If you have weak air flow, or if the dyrer shuts down like you been experiencing, I would begin by checking the dryer interior for clogs. In most cases, the dryer blower fan housing becomes built of with lint and can cause the dryer malfunction.
Cleaning the lint screens on these dryers is not always enough. Routine inspections of the dryer ducting and cabinet interior should be done about every 3 months. A dryer that remains in a clogged condition will actually run hotter, but dry less efficiently. This causes the heating circuits to run at higher temperatures. Sometimes to the point of failure. The also can cause a fire hazard.
The Thermal fuse is a small plastic looking component mounted on the blower fan housing with 2 wires attached to it. The other component that you may have on the blower fan housing is the operating (or bias) thermostat. It usually has 4 wires attached to it. With the dryer UNPLUGGED, you can disconnect the wires on the Thermal Fuse and take a resistance reading. It should read a short (0 ohms) if good. If bad, this reading will change when the component gets hot. The way I isolated my fault was to run the dryer until it failed, then took a quick resistance reading.
Let me know if you have any questions. I hope you find this information helpful.
Posted on Jun 27, 2009
Kenmore elite dryer will not work on manual cycles which consist of three options; timed dry, express dry, and touch up. Dryer will work on auto cycles only
most likely the board is bad,the board is big money,just keep using it on auto,that's what you should be using anyway the dryer automatically stops when the clothes are dry,say you set your clothes for 60 minutes and they dry in 40,you're drying the clothes 20 more minutes that you didn't need,if you set it on auto the dryer sensor knows the clothes are dry and shuts it down when they are dry,this doesn't have a timer this has a computer board or it could be the touch pad not working correctly if it doesn't take commands but either part is expensive the board is like 200 and the touch pad is close to 300 bucks,i would use it on auto,one more thing to check is sometimes the ribbon or plug that connects the touch pad to the board could be loose or have some lint or something in it,i've just unplugged them and plugged them back in and then it works,also clean out all the lint out of the dryer and vent line,this is the number one cause of most problems in dryers and you won't have to worry about a dryer fire,if it's gas you should do this once a year yours is electric so you can wait like every 18 months with gas you have a flame in there so you don't want lint in or around the flame,clean out the duct that the lint filter slides down into and i use a leaf blower to blow out the vent line just take it off the dryer stick the leaf blower int the line and blow it to the outside when you have the dryer running go back outside and make sure the air is blowing out good
Feb 05, 2018 | Kenmore Dryers
Why does drying cycle end with clothes damp?
The dryness sensor is dirty or has failed
Oct 15, 2015 | Dryers
Kenmore dryer 90 series
Since no model number was given, check to see if you have a setting commonly noted as "wrinkle guard", "wrinkle shield", "press care" or something to that affect. Those settings will run the dryer for as much as 90 min after a completed drying cycle to prevent wrinkles in clothing, allowing you time to remove the cloths after a dry cycle if you are busy. Pleazer Appliance...
Apr 09, 2014 | Dryers
Shuts off during autodry cycle. stays on during timed cycle but clothes are wrinkled ans too hot at end of cycle.
if it works on auto but not on time you have a bad timer,it's not counting down,it's better to use auto anyway,when the clothes dry the dryer shuts off on it's own,this way your not using extra electricity,if your clothes dry in 30 minutes and it's on 60 minutes it will still run after the clothes are dry on auto it doesn't.if you open the door and look around the opening you'll see a tag with the model number,your missing a couple of letters on the model number.
Mar 05, 2011 | Whirlpool LER4634J Electric Dryer
Kenmore Gas Clothes Dryer does not heat sufficiently
Ok, first and foremost, make sure your vent is clean and clear.
If the vent is clean and free of obstructions the most likely culprit is your gas valve coils. When they fail the typical symptom is heat at the beginning of the cycle and no heat about 20 minutes later.
If you can, post the complete model number from the dryer and I will give you step by step tear-down and replacement of parts instructions.
Jun 27, 2010 | Kenmore 63942 Dryer
My son has a Kenmore top load electric dryer. It
Hi, Check the door switch and the fuse. The fuse is the most common cause. You can also let the dryer cool down for an hour and see if it will restart. If it restarts, the motor might be going bad. It is hard to say without model# I'm afraid. I have not heard of a top load dryer but, these are common things to check.
Please let me know if I can assist you further.
Vic
Jun 27, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore 63942 Dryer Logo
236 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
