I need a yamaha powered sub woofer
I have a yamaha ax 596 amplifier. What powered sub woofer would you recommend to use with this unit?
many thanks.
dave
4 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: matching book shelf speakers for yamaha ax 596 amplifier
just click to choose;
NEW iBALL BOOSTER 5.1 SPEAKERS WITH MANUFACTURER WARRANTY
The iBall Booster is a high quality 5.1 speaker system with complete wood encased speakers. Gives... control...
FREE 350 WATT AMPLIFIED SPEAKERS Creative Inspire 5200 5.1 Multimedia Subwoofer Speaker System With 1 Year Warranty
hope this may help;
Regards,
VOTIT
Posted on Jul 29, 2008
johex
  • 75 Answers
SOURCE: I want to connect YST-Sw1500 sub woofer to the
on ur subwoofer u will see HPF output, connect this output to MAIN IN of ur power amp (first remove jumper between pre-out and main in from ur power amp) connect pre-out of ur power amp to input 2 L&R (Left is also for mono input). the HFP selector switch will cut off 80Hz or 100Hz to the main input depending on the position enabling u to have high frequency sound on your main speakers. connect the speakers to the main output terminal of ur power amp. do not connect speakers on the woofer ouput.
make sure u are using the right impedance speakers. do not switch speaker impedance selector while the unit is on.
Posted on Apr 05, 2010
dunnbiker
  • 8546 Answers
SOURCE: hello i was wanting to know if i could hook up my
I assume you want to slave it to the receiver and drive some more speakers with it.
Connect some RCA cables from whichever channel pre-outs you want on the HTR-5860 to any input on the AX-596.
Set the AX volume to something sufficiently high, run through the HTR's speaker level setup and match the AX volume to match the channels on the receiver. Then leave the AX's volume alone.
If you just want the AX to have access to program sources of the HTR, run the RCA cables to it from one of the VCR1 or 2 Out (but DO NOT select whichever one you use via the front panel). These are not affected by the HTR's volume controls.
Posted on May 07, 2010
Yamaha AX-596 bass & treble control panell not working
Make sure there is no tone bypass button if it has one.
Apr 26, 2014 | Yamaha AX-596 Amplifier
When turning the source selector on my AX-596, is sometimes takes a couple turns for it to change source. Is this an easy fix? dirty switch?
remove the front panel and if you have clear alcohol and just few times over the SW and turn it around that's all
just tell me if it work
Aug 03, 2011 | Yamaha AX-596 Amplifier
Yamaha AX-596 Integrated Amplifier only works when using either of the two "Pure Direct" buttons. The Bass, Treble, & Balance controls do not function. It would appear that circuit board or the circuit...
Chances are that the tone control pre-amp circuit is faulty. These days the functions are all done by a single IC. Find that and you will more than likely have found the culprit. If there are any of the controls for bass etc on the front pannel, trace the wiring back from them. If not have a look around on the PC board in area that you suspect (some boards are marked as 'tone' etc). If you see any IC's put the number into google and you might find out what each does. Keep doing it till you find one that deals with tone etc.
Aug 20, 2010 | Yamaha AX-596 Amplifier
Hello i was wanting to know if i could hook up my AX-596 amplifier to my Yamaha HTR-5860 reciver
May 07, 2010 | Yamaha AX-596 Amplifier
I want to connect YST-Sw1500 sub woofer to the AX-596 amplifier .How can I do the connections .
Apr 04, 2010 | Yamaha AX-596 Amplifier
How do I hook up a non powered sub woofer on my htr-5630?
You will need an amplifier or 2 channel receiver. Hook the sub out rca jack to the rca inputs on this new amp or receiver and hook the speaker terminals on sub to speaker terminals on same amp or receiver. Your Yamaha receiver doesn't have any power for a passive sub.Just pick up any old fairly high powered receiver for fifty dollars and you're good to go.I use old dolby pro logic receivers as they are a dime a dozen today. Good luck.
Feb 20, 2010 | Yamaha HTR-5630 Receiver
Yamaha amp ax-597
Happy to help, just need to hear from you mate. Cheers
robotek
Aug 29, 2008 | Yamaha AX-596 Amplifier
Matching book shelf speakers for yamaha ax 596 amplifier
hope this may help;
Regards,
VOTIT
Jul 27, 2008 | Yamaha AX-596 Amplifier
Standby power switch
If you are concerned about humidity and switches, spray them with DeOxit. You can get it at Radio Shack.
Jul 12, 2007 | Yamaha AX-596 Amplifier
43 people viewed this question
 Grubhead
Grubhead
