Question about Dell Dimension 3000 PC Desktop
Power button flashes yellow and will not power up.
We have just set up my son's computer again. It has been turned off for about 3 weeks. It was working perfectly before but now when we press the power button it flashes yellow and will not power up. It is a Dell Dimension.
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    Make sure someone has not changed the power select switch on the back to the wrong setting. US-110 EU- 220 If that is OK, make sure the power connectors are seated securely on the motherboard. If that is OK, consider having the power supply looked at. Do you hear any noise, that is fans, beeps, etc?
  • Dell Master
  • 2,404 Answers
Try a different know good working power supply and only hook up the main power connector to the motherboard as well as the p4 connector. If you get power then you know that the original power supply is bad.
If you try another known good working power supply and you get the same yellow light then the motherboard is bad and would need to be replaced.
Posted on Jun 27, 2009
I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
Jan 23, 2010 | Mitsubishi WD-52628 52" Projection HDTV
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
Broken USB jack, no power.
1) Unplug the computer from power. Open the computer case.
2) TOUCH the metal frame of the computer case. (Not shouting)
This will relieve your body of Static electricity.
3) Unplug the front panel USB cable from the motherboard. (If there are two cables coming from the front panel, unplug them both)
4) Close the computer case.
Press the Power On button in, and hold it in for a count of Five seconds. Let go of the button.
Do this procedure two more times. (Total of three times)
What you are doing is clearing any CMOS Error Codes, and setting BIOS Setup back to the factory default settings.
5) Plug the computer back into power. WAIT 1 minute. Turn the computer on.
If the computer still doesn't start, the motherboard is fried.
(I believe the computer will work okay)
There is no Service Manual available. If you follow the cable/s from the front panel to the motherboard, you'll see where it/they connect.
Jan 17, 2010 | Dell OptiPlex GX520 PC Desktop
Yesterday after playing video games for a couple of hours my son tunrs off the set. He returns 45 minutes later turns the set on as usual the green power light flashes 3 times followed by a red indicator...
Red flashing 6x is a thermal fuse,I have serviced hundreds of these models and have never encountered 7x.If it is flashing 7x try unplugging the power for 2-3 hours and try it again.If that doesn't work you will need probably need a K-board.
Nov 10, 2009 | Sony KDS-R50XBR1 50" HDTV
Moniter went black, power button flashes yellow
it sounds like a capacitor blew from the inverter board.. if u can open it it should be obvious which one the messed up..
May 04, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Acer Aspire One Netbook ZG5 will not turn on
you should be able to press ESC to exit hibernation, or remove the battery, remove the plug, press and hold the power button for 60 sec, and reinsert battery and power and turn on. when restarted, right click on desktop, click properties, and click the screen aver tab, click the power button, click advanced, and remove the check box beside enable hibernation on the "Hibernation" tab. it shouldn't do it again
Apr 20, 2009 | Acer Aspire One Netbook 8.9" Notebook
I have a Beko AA class WMA 520W washing machine and it won't wash, when i put it on a wash cycle it will fill up wash for about 7 mins then drain, neither will it spin unless i actually turn the dial to...
Had the same problem this week. i bought the machine of a mate and was ready for kicking his head in, but thankfully before then i found that this method resets the washer, hope it works for you also
Turn power button off (not at wall)
Select 90 degree wash
Press Start / Cancel button down for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start /Cancel button again for 3 seconds.
Machine should be re-set ready for use
Oct 19, 2008 | Washing Machines
Beko wma 1715 pre wash led keeps flashing manual says contact service engineer
Press Start and Cancel button down at same time for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start and Cancel button together again for 3 seconds.
Machine should be re-set ready for use.
All we need now is for the rain to stop
May 04, 2008 | Washing Machines
Dell Dimension 3000 PC Desktop Logo
252 people viewed this question
Alun Cox
