Question about Garden
Hi, someone has fiddled with the carburetor screws chasing factory settings for high an low screws cheers jd
  • 155 Answers
You start at 1 & a quarter turns out from the closed position sometimes you have to go a bit richer
Posted on Jul 26, 2009
What are the factory settings high and low on husqvarna 128ld ?
Carburetor setting should be done by a dealer and by using a tachometer. However, to get a ballpark setting. Turn the screws in until they lightly seat, then turn the "H" and "L" screws out 1 1/2 turn. Then have your local dealer finish setting the carb.
Apr 05, 2017 | Husqvarna Garden
What is the factory settings on a craftsman 2.3 chainsaw and to adjust carburetor
tighten the two air screws to just tight then slacken them to one and a half turns start the engine and adjust the low screw until tick over then open the throttle to full and adjust the high screw if it cuts out take the high screw to one turn and try that then adjust from there
Oct 28, 2013 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Homelike chainsaw carb settings high/low
Hi, most chainsaws start with carb settings at 1&1/4 turns out( hi+lo) usually once the chainsaw has been run in, the 'hi' screw can be turned in an eighth, tickover set low enough not to cut out but high enough not to engage the clutch, cheers Billy
Feb 15, 2013 | Homelite Garden
Stihl FS 80 carburetor settings for high and low screws
Hi F Del
Before you remove or try to adjust your low and high speed jets you should always count the number of turns it takes to lightly seat the idle mixture screw and high speed needle adjusting screws.
Be sure to write the number of turns down on a piece of paper so you will know how many turns from the seated position to open the jets when you go to reinstall them, or if you remove them for cleaning or replacement.
If you have aready tried to adjust them then the adjustments below should get it running for you for final adjustment when warm.
Normally you will adjust your idle jet to 1/2-3/4 turn open from the bottom seated position.
Then you will re-adjust the low speed of the engine when the engine is warm by turning the idle screw in or out till the engine runs smoothly at idle speed, around 1200 RPM.
The high speed jet is adjusted to 1 1/2- 1 3/4 open from the bottom seated position, after the engine is warm.
Then re-adjusted by turning the High Speed jet adjustment screw in or out till the motor runs smoothly at high speed.
Alway use the "lightly seated" method if you have not changed the screw settings.
Please take time to rate me
Bud
Oct 10, 2012 | Stihl Zama Fs-80 Carburetor C1q-s157...
How do I adjust the carburator on a craftsman blower
All carburetors have 3 screws high and low and idle, then screw high and low all the way in, then turn them back 1 and half that should be factory settings go from there. start with the high idle back it out slow until it sounds good. My blower ran good on two turns out on high idle then three turns on low idle. Good luck...
Sep 15, 2012 | Craftsman Garden
Hi, what are the carburetor settings for kymco stryker 125. what the idle speed should be and how many turns out for the mixture screw. what side for each screw. many thanks
this is down to personal preference, its just playing around with it so that it doesnt stall and isnt so high that you cant accelarate.
i have mine at a lower setting in the summer and a slightly higher setting in the winter its just fiddling around with it till your happy with it.
best of luck and safe riding
Sep 08, 2010 | 2005 Kymco Stryker 125
Hi, I have a Poulan Model 1800 and previous owner has messed with air and gas mixture adjustments. I can fire it up and run it full throttle but it dies out at low speeds - idle adjustment makes no...
The default setting for the H and L carburetor jet is usually to turn them in all the way till they stop and back them out a turn and a half. You need to set the mixtures for the carburetor. You will find a Low and High adjustment screw. turn the low adjustment screw out. You will notice that the rpms should start increasing. keep turning it out until the rpms start to drop then turn it back in a quarter of a turn. You may need to readjust the idle speed so the chain doesn't turn during idle. Do the same for the high adjustment screw.
Nov 28, 2009 | Computers & Internet
Jonsered 2141chainsaw carburetor adjustment.
You need to set the mixtures for the carburetor. You will find a Low and High adjustment screw. At idle turn the screw in or clockwise until the rps starts to decrease. Then start turning it out till you hit max idle rpms. Turn screw back in a quarter to half turn and it should be idling smoothly. Be careful here and get someone to hold saw if necessary but hold in throttle to full speed and do the same with high adjustment screw. turn it in till rpm starts to drop then back it out until you get to max rpm and it won't go any higher then turn it back in a half a turn.
Jul 08, 2009 | Husqvarna Garden
Can't set carb. on Husqvarna chainsaw.
Most chainsaws and small engines are 1.5 turns out.
Jun 20, 2009 | Husqvarna Forest & Garden 125l 18" Gas...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
