Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Cutting grass.heard loud Pop tractor shut Cub Cadet 1210 Hydro
My tractor is a Cub Cadet Hydro 1210 ..I tried changing spark plug, check fuel line to make sure it wasn't clogged...it wants to start but won't after cranking it will backfire.. Someone suggested that it could be the coil. But I don't have a manual and I am not sure where to look...any help would be appreciated..
  • 59 Answers
Just trace the spark plug wire to the coil but you can check the spark by putting a new plug in the wire and make sure it is grounded and turn the engine over if you have spark then you have to pull the fly wheel off and check the fly wheel key
Posted on Jun 27, 2009
After cutting the grass with a Cub Cadet 1050 after it set for hours the engine
check for water in gas espeially if you leave outside in rain try shooting some starting fluid in it see if it starts up drain gas and fuel lines install new gas fresh not same gas
Sep 02, 2014 | Cub Cadet LTX 1050 KW 50" 23HP Kawasaki...
I have a cub cadet 1000, it's approx 4 years old, i was in the middle of cutting the grass and the mower stopped running. Tractor runs mower will not come on. Is there a switch or module that nee
check the clutch on the end of engine drive shaft it is the same as a car air con clutch put power on to it and it should click so most likely the wire from switch to clutch
Apr 22, 2013 | Cub Cadet Garden
Need to know how to change transmission fluid on cub cadet lt 1045 riding mower
Cub Cadet has five models in their new Series 1000 lawn tractors, all powered by Kohler engines. Cub Cadet models -- as several other lawn equipment brands -- are manufactured by MTD Products.
The Cub Cadet LT 1045 has a 20-hp Kohler single-cylinder engine, with an aluminum block and cast-iron sleeve for longer life. It has a full-pressure lubrication system with spin-on oil filter for easier maintenance. This engine is not as powerful or as long lasting as the Kohler V-Twin OHV, which is available in other models in the line, but the LT 1045's engine is still solid enough to provide years of mowing.
The hydrostatic (automatic) transmission is a good match with the engine and provides sufficient grip to cut grass on moderate inclines. Power is transferred from the engine to the transmission by a heavy-duty Kevlar belt rather than a more expensive shaft drive. A Kevlar belt also drives the three cutting blades.
The mowing deck cuts a swath of grass 46 inches wide at one pass, and is removable for service and cleaning. Four anti-scalping wheels help keep the deck from scalping grass on uneven ground. The cutting height is manually adjusted from 1-1/2 to 4 inches. The turning radius is 18 inches, which standard for lawn tractors. This model is intended for use on 1- to 2-acre lawns without many turns or small obstacles.
Jul 28, 2012 | Cub Cadet Garden
I have a Cub Cadet LT 1018 with an 18hp Kohler motor. It was running fine today while cutting the grass it just shut off. It will not restart. The engine will crank over fine but it will not fire. I...
First make sure you have oil in it. Next take off the air cleaner box. Try restarting it if it runs fine clear or replace the air filter. Also check to see if it’s getting spark.
Dec 22, 2017 | Cub Cadet Street Sign- tractor lawn riding...
Cutting grass for 15 minuted,will act like its flooded and shut down
Try this. Next time it begins to stall, loosen the fuel cap. If this helps, clear the vent holes in the cap.
Gary
Apr 28, 2011 | Cub Cadet Garden
Cub cadet zforce
hello
check mower deck is not caked up with grass if it is it will not get enough air movementto force the grass up the chute
also try cutting in 2or3 passes so that you are not forcing too mush grass up the chute
hope this helps
Mar 13, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
733 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
