Question about Hitachi Dv18dl 1/2 18v Hammer Drill/battery/charger
My drillwill work in second gear but makes a noise 1n first gear
  • Hitachi Master
  • 43,501 Answers
!st gear, gears are stripped...
heatman101
Posted on Aug 27, 2010
My honda 400x keeps making a noise in second gear but will still run
second gear primary and secondary coggs are TOAST! its a complete engine teardown and both the 2nd gear primary and secondary need to be relaced. If you dont eventually it will break the shift fork and do a lot of damage and most likely lock up the transmission.
Apr 13, 2014 | Honda 2013 TRX 400X
My yamaha ttr-125 making noise when in 2nd gear but no noise in any other gears
I agree it is a broken tooth on second gear in the trasmission. You will need the trans. rebuilt before riding further or you will jam the transmission, Break more parts, & possibly break the main engine cases. DO NOT RIDE !
Aug 26, 2012 | 2011 Yamaha TTR125
Grind at 19 mph in primary
I would think that if the noise was being made by your transmission, it would start whenever you put the transmission in second gear and continue until you shifted to another gear, not at 19 mph only.
This sounds like a vibration that is specific to the engine rpm at that speed. It may sound like a grind but may actually be a vibration noise. Try to recreate the noise with the bike sitting still in neutral. Be careful not to allow the engine to overheat though.
Try other things to help you narrow down the source of the sound. When it starts, gently touch the brakes while maintaining the speed to try to eliminate the brakes. Does the noise change if you accellerated slightly or back off the throttle slightly.
It's very unusual for a transmission to make a noise in only one gear. I've found that if a transmission is making a noise, it makes the noise all the time but maybe louder at some speeds than others.
Good Luck
Steve
Jun 19, 2010 | 2006 Harley Davidson FXDBI Street Bob
Ive got the same problem with my xs650 1977...
the second gear is piting from rust[so the noise]the stuck is of the gear change ankor or damage spring
Jul 07, 2009 | 1979 Yamaha XS 650 SF
When engine is started, heater door makes clicking noise for 20 seconds and quits. When engine is shut off, heater door makes clicking noise for 20 seconds and quits. Door makes clicking noise when heat is...
Your air temp control blend door actuator is failing, that is the part u call a heater door, it is a gear driven miniature drive, the gears are jumping teeth making the noise, it will stop working very soon.
Apr 24, 2009 | 1998 GMC Blazer
1st, 3rd and 5th Gears all pop out of place + Whining noise
hi my name is nathan .......now...... what it sounds like is #1 (I have to hold it in place til I get to second gear) that can be that your shift linkage is worn or out of adjustment,pilot bushing is Badly worn,shift fork,lever and or shaft is bent or worn,or your bell housing is misaligned or just loose...i have a few more ideas on why it is jumping out but those are the main ones now about your whining gear noise#2( The whining sound starts low pitched in each gear then gets higher pitched as the rev's increase) you may have worn gears maybe or it could be just that your transmission lubricant is incorrect or inadequate.
Dec 26, 2008 | 2000 Volvo S40
Grinding noise
my suggestion is replace the fusing gear and the rachet gear.
Mar 22, 2008 | Sharp AL-1642CS Copier
Grinding noise
Is the noise comming from the right side of the copier? If so you need the upper fusing roller drive gear. It will break sooner then later.
Feb 08, 2008 | Sharp AL-1641CS Laser Digital Copier
Hitachi Dv18dl 1/2 18v Hammer Drill/battery/charger Logo
119 people viewed this question
Top Hitachi Drills Experts
John Trevino
Are you a Hitachi Drill Expert? Answer questions, earn points and help others
