Question about Bose Lifestyle 20 System
6 cd changer will not eject - Bose Lifestyle 20 System
I used this info to fix my bose. I hope it helps you too. Problem: CD changer case will not eject and motor is constantly running.
Resolution: I took the entire case off of my Lifestyle 20 system as the CD Changer Manual Release (found on the bottom of the unit. Open by inserting small jeweler type screwdriver) would not work. Remove all silver covers by carefully prying (glued on). Remove the there phillips head screws in-line from left to right. Use a slot screw driver to pop the tabs under the end silver covers. You now have access to the motor that drives the CD changer. The problem was the plastic gear on the motor had slipped where it was no longer engaging. I pushed the gear back in place. The CD went back in the case and everything functions properly. Of course, the gear could slip again in the future as I did nothing more than push it back in place. Poor design especially considering Bose is supposed to be top of the line. Word of caution - when removing the case four springs used for vibration reduction will fall out. They are not difficult to reinstall - just be aware they are present.
I was able to pry open the top panel that is held in with four plastic "Christmas-Tree" type retainers used to hold car interior panels to the doors. I inserted a small flat blade and little by little I got each side up and off. There was a piece of double sided sticky tape near the front just behind the display panel also holding down the top cover. I removed the four screws holding down the CD mechanism and lifted it out, which was resting on four springs. I found a little delrin gear that had slid to the end of the motor shaft, not meshing with it's mate gear. I slid the gear back down the shaft to mesh with the other gear, but noticed the gear slid very easily. Closer look found the gear had a tiny slpit from one end to the other along the shaft. Since no parts are available, I used some epoxy to not only glue the gear to the shaft, but also put epoxy around the hub of the gear to help hold it together. Delrin is a very sturdy material and I expect this to last for quite a while. I cleaned the rubber rollers and blew out all of the dust. I found the manual magazine release hole just under and to the left of the eject button. I drilled a small hole in the front of the unit housing to allow a paper clip to access the release with the unit assembled. All works great and once again enjoying my Bose Lifestyle 25 system. If the gear comes completely apart, I feel there are ways to find a replacement gear.
Posted on Jul 06, 2009
  • tsz4 Jan 01, 2011
    my unit is 10 years old now and this was its first problem. Like yours, the delrin gear moved to the front of the shaft. I visually inspected the gear and it appeared intact. Slid it back on the shaft, it was very easy, I can't explain how the shaft hold on to the gear, but it appears to work. Tried it out a few times while open and all is good.
    I am a little surprised at the construction of the unit - for a relatively expensive piece of kit, it does appear cheap inside.
    The only other issue I had previously - at no fault of Bose - was a lightning strike, which took out the bass/amp unit. Bose service, albeit expensive, was good.
    The RF remote control is a bit fussy and there are a lot of areas in the room where it doesn't work. I have relayed the cables, but without improvement. Perhaps somebody out there has suggestions.
    For the rest, great system - 10 years and going strong!
  • 2,071 Answers
First you do is to unplug the cord of your CD unit for 5 hours in order to drain the stored current,the purpose is to reset the unit. After the 5 hours plug the CD see to it if it open If not,just try to press down on the stop button and pressing eject button at same time and it will unlock the tray .Then the other option is to open the cover of the CD unit and unplug the unit again to avoid electricshock . When open already look for the disc platter moved it outward while driving the gear or simply push out. The drawer or door of the CD player and you will see a small circular disc which is often called turntable or disc platter.When the disc platter is out push it back and push it out you do this three times so the slider mechanism align it properly.If you do already what i said then plug it again and if works already closed the cover. The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn?t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There?s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also. Hope it may help you; Regards; VOTIT DONT FORGET TO RATE;
Posted on Jun 27, 2009
  • 30 Answers
There are do it yourself instructions available at www.AnyoneCanFixIt.com that steps you through the process to fix this with detailed pictures of each step.
Posted on Aug 26, 2009
  • wkeller24 Aug 26, 2010
    why pay for the information already above.. any links to AnyoneCanFixIt should be remove! they only copy others advise and sell it!
3 Suggested Answers
SOURCE: Bose Lifestyle 30 6-cd changer magazine manual release?
hi, you can release the magazine by inserting a small flat head screwdriver in the slot and pushing the lever towards the back of the unit, this will release the cd but only if ther is not one stuck in the player as it will remain halfway between the mag and the cdplayer. don't force it to comae out. remember to obviously have the dorr to the player open before you try this.
Posted on Aug 12, 2007
  • 88 Answers
SOURCE: can't eject cd from cd changer
hi check and see if there is 12 volt to the cd changer or blown fuse.
Posted on Oct 27, 2008
No power to the disc changer, how do I manually eject the magazine
There is a manual eject slot on the side of the CD changer. You will need a small flat head screwdriver or a pry tool to insert into the slot.
Oct 11, 2012 | Kenwood KDC-C715 10 Disc CD Changer
6 disc, will not eject or play cd's
Try tapping on the changer. Sometimes a gear gets stuck inside the changer and tapping on the changer frees the gear.
Feb 15, 2012 | Alpine CHM-S630 6-Disc CD Changer
Cd player saying reset 2, how do you fix that?
If its allowing you to eject the cd stack eject it unplug the unit and allow a 20 minutes.
Sep 22, 2010 | JVC CH-X350 12-Disc CD Changer
My BMW X5 6 CD Alpine changer is jammed and will not work. How do I fix it and remove the disk?
If the issue is you cannot eject the cartridge this would be simple.
Slide the changer door open as if ejecting the cartridge. Take a credit card/driver license and insert about 2 to 3 inches between cartridge and chassis. You should hear a click and the cartridge should eject.
Once the cartridge is out check to make sure there isnt a stuck CD in the changer. If there is remove the loose CD. If the CD is stuck in the player itself insert the empty cartridge the changer will cycle through the process. Once it stops you can press eject button and the CD should be in the cartridge.
Feb 25, 2010 | Alpine Car Audio & Video
My 04 yukon cd changer won't eject the cd. any advise?
if you push the eject cd magazine button on the changer does it sound like it's trying to eject it? if it doesn't you'll need to replace the changer. if it does, then you've got a stuck cd magazine tray. it sounds weird, but when i was working on land rovers this happened all the time on the full size range rovers. what we did was push the magazine eject button on the changer to eject the cd magazine and sort of slap the changer around a bit. 90% of the time it worked. the other times, we'd go in with a 90 degree pick and try to push the stuck cd tray back into the magazine (while it was still in the changer) while pushing the eject magazine button on the changer. and you'll need to replace the cd magazine. if it happens again, you'll need to replace the entire changer.
Feb 16, 2010 | Car Audio & Video
1995 Explorer 6 cd changer - how to manually eject cartridge
No there is none you have to hook up power to it then press eject.
Jun 27, 2009 | Panasonic CQ-DPX33 CD Changer
Rockford Fosgate cd changer
I have the same problem with the 2006 sentra
May 28, 2009 | 2005 Nissan Sentra
Blaupunkt CD Changer CDC-A08 - Cartridge eject problem
I am waiting for a reply from the Authorised Blaupunkt Service Agent for a solution to this problem &
shall let you know when it is solved. As per my telcon with him it is an alignment problem of the
Cartridge carrier, but he will have to look at the Unit later, when he is free.
Mar 22, 2009 | Blaupunkt CDC-A08 10-Disc CD Changer
Car multi cd changer wont eject
hi
do you have any model numbers on the cd changer?
Nov 23, 2008 | Car Audio & Video
Unable to eject cd magizine. Error 2
power off. open the cd changer unit. look for the motor that, when turning, performs the eject mechanism. now turn this motor by hand in the proper direction until cassette is fully ejected.
Jul 22, 2007 | Clarion DC625 6-Disc CD Changer
Bose Lifestyle 20 System Logo
7,351 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
