Question about SuperMicro SUPER P6 DGH (P6DGH-USA) Motherboard
How do the various power connections on the board work? My AT power supply died.
  • 410 Answers
Replace the Power Supply with one that has the same type connectors. When you plug them in the Mobo you will see a lock clip that faces one certain direction.
Posted on Jun 27, 2009
I have a panasonic TC-P42C1 blinks 10 times no picture no sound What is common to go on this model (which board)?
Check the tv power supply board.That the board where the tv power A/c plug into it.Check the tv power supply board carefully for dying components parts that are called capacitors parts.Bad or dying capacitors parts on the tv power supply board are alway causes this problems to the tv.Bad or dying capacitors parts are very easily to spots,all these capacitors parts are alway bulges up onto it tops.Never have plats round tops as they suppose too.U have all the tools and know basic electronic also can do basic soldering work,u should changes all these dying capacitors parts in the tv power supply board with no problems at all.If u check all over the tv power supply board and it have no dying and leaking capacitors parts to the tv power supply board all.Then the tv Y-Sustain main logic Tuner board it is the causes and the problems.The tv Y-Sustain main logic Tuner signal board that is the board that take in the tv imcomming tv broadcasting signal cable plug into it.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board and or the tv Y-Sustain main logic Tuner signal board for the replacement.
Nov 06, 2011 | Panasonic TCP42C1 Plasma TV
My LG 26LH20 turns itseld off after about 2-3 seconds. TV is a little over 1 yr old. I t happened about 2 months ago and I thought it was the cable. had cable serviced, not the problem. now it's...
Tv turn itself off after 2-3 seconds the tv still audio voices?Yes,than the tv long board that call the LCD inverter board it is dead.Require change the tv long LCD inverter board,this board help the LCD screen panel to have a backlight to produced a picture or 2-3 seconds tv power died completely no power to tv all?Yes,than this problems the tv power supply board it is dying.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board or the tv power supply board for the replacement.
May 09, 2011 | LG 26LH20 LCD TV
I have a 32lc7d tv and i cant get it to turn on all the time. the on light will be green but no sound or picture. the light also blinks about 15 times before going to a solid green color. the tv will...
This problems ur tv are having are only can be causes by two boards,the tv power supply board or the tv Tuner signal board.The tv power supply board that the board where the power a/c cord plug into it.The tv Tuner signal board that the board where the incomming broadcasting signal wire plug into it.This problems very easy to fix.If it is the tv power supply board is the causes,because u can check the tv power supply board carefully u will find dying capacitors parts that will bulging up or puffing up on to it tops.U have all the tools and know basic electronic just replaced all the dying capactors for all new capcitors parts same micro ferit but the capacitors voltages like 5 or 10 voltages higher for better heat resistance for the life of the tv power supply board.If it is the tv Tuner signal board,very hard fix and determine where the dying parts are in this board,because this board is cover with many ICS chips on this board.If the tv the Tuner signal board is the problems best just buy the whole refurbish tv Tuner signal board for the replacement.Or u can tries websites like Shopjimmy.com,Ebay.com to buy the whole refurbish tv power supply board too,if u don't know how to or have all the tools to replaced those dying capacitors parts and also can buy the whole refurbish tv Tuner signal in these two websites too.
Apr 16, 2011 | LG 32LC7D Television
I have a Samsung 52 LCD TV about 2-1/2 years old. Start clicking about 10-12 times then it turns on. today I turn it on and it just keeps clicking and will not turn on? any Ideas.
The power supply board it is dying and most likely causes by weak and dying capacitors parts bulges up or puffing up leaking.The power supply board,that the board where the power a/c cord plug into it.U have all the tools,understanding basic electronic also can do basic soldering work?Yes check the power supply board carefully replaced all dying to be dead capacitors parts or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jan 25, 2011 | Samsung LN55B650 55 in. LCD HDTV
TC-P42C2 Power Indicator Light Flashes 7 times, No video or audio
Power LED light indicator are flashing it is the effect of the power supply board are dying and not giving the tv the wright amount of voltages anymore.That the board,where the power a/c cord plug into it.U have all the tools,u understanding basic electronic also can u do basic soldering?Yes,check all over the power supply board for dying parts call capacitors.These dying capacitors are alway bulges up or puffing up on to it tops.By replacing all these dying capacitors are bulges or puffing up on it tops,will solved this flashing LED power light indication,power supply board will work again.Or try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
Jan 07, 2011 | Panasonic TCP42C2 42 in TV
TV will not turn on. Power on the wall socket is good. Worked one day and died the next. Is there a fuse some where inside which may be blown?
No,power supply board have dying capacitors.That the board,where the power a/c cord plug into it.Power supply board,have dying about to be dead capacitors,these capacitors all way bulges up on it tops or puffing up on it tops.U know basic electronic and have tools?Check the power supply board and replaced these dying capacitors,will solved this problems.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Sep 07, 2010 | Initial DTV-262 26 in. TV/DVD Combo
Works fine until you turn it off wait and then try to turn it on.
Must take the tv aparts.Power supply board have dying parts call capacitors?The board,where the the power a/c cord plug into it.That the power supply board.U know basic electronic's,have tools and know basic soldering?Searches the power supply board for dying parts capacitors,they alway bulges up on it tops or puff up it tops?Replaced,these dying capacitors parts,will solved this problems.No,dying capacitors on the power supply board.The Tuner board,have problems,intermittenly.That,the board where the brocasting signal cable plug into it.Tuner board,have problems alway related to ICS processor's,must change the whole board.Or tries websites like Shopjimmy.com,Ebay.com to buy those 2 refurbishes boards.The power supply board or the Tuner board for the replacement.
Jul 25, 2010 | Philips 32PFL5332D 32 in. LCD Television
Have a Hitachi 53sdx89BA Rear Projection TV. Turn on TV and red power light illuminates. No picture, but have sound. Check PC board in back and red led is flashing and green leds are lit. It was working...
Discharged Flyback Transformer. Removed main pc board from bottom of TV and flipped over, no apparent damaged components or blown board traces were found. Noticed a lot of flux in various areas on the board that seemed unusual (maybe TV was worked on before as I bought a showroom demo at Circuit City). Used a plastic screwdriver to remove all flux between connections on ICs, Transformers, Flyback Transformer, and various other components. Cleaned all debris, dust and crud accumulation (TV is over 10 years old and there was alot around the Flyback Transformer) from both sides of board using a lightweight paint brush.
Used a magnifying glass to check all solder joints for possible cold solders and found none. Did the same for Power Supply Board. Checked various ICs and Power Transistors for opens or shorts (in machine) and they seemed fine. Reinstalled boards, said a few Hail Mary's and fired it up.
The protector Led no longer flashed under power and lo and behold I got picture and sound!
I cleaned the lens on the projectors (again 10 years of dust accumulation) did a magic focus adjustment and it works fine!
After reading other fixes, I fully expected it to die after 10 minutes so I left it on all day and against all odds it still works.
What was the fix......Dirt buildup on and around Flyback and other components,,,,,,Flux conducting electricity between contacts on Flyback and other components.....or oxidation on connectors between Power Supply and Main Board.....I don't know.... all I know is that for the moment I saved around $ 300 - 400 in repair bills by doing it myself.
Feb 01, 2010 | Hitachi 53SDX89B 53" Rear Projection...
Motherboard ABIT KN8
i dont know about the red light, but all main boards these days have a built in protection if the cpu fan quits. check the cpu fan connection, ensure that it and the heat sink are dust free. if still no go. update  your question with exact info..e.g. does absolutely nothing.. how many beeps you hear..how long b 4 it dies.. final note: be careful what you touch.. static can harm more that most think and the oil from touching can retain heat.
Oct 29, 2007 | Abit KN8 Ultra Motherboard
SuperMicro SUPER P6 DGH (P6DGH-USA) Motherboard Logo
53 people viewed this question
Top SuperMicro Computers & Internet Experts
David
David
Victorman
Victorman
Joseph Hoffmann
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
