Question about Whirlpool Washing Machines
I have a Whirlpool AWM 5104/4 front loading washing machine. The conditioner/softenen tray is not dispensing the liquid into the machine at the appropriate time.
3 Suggested Answers
SOURCE: Whirlpool washing machine Model AWM 5104/5
the despencer has a motor on it are a water valve that puts the water into the right despencer at the right time to make it work look under the top if its a water valve type needs new valve
Posted on Feb 25, 2008
  • 141 Answers
SOURCE: AWM5104/1 Front Load Washer: Whirlpool AWM 5104 - The machine turns on and the ...
May be the belt at the back of the machine is loosen or cut off kindly check it and replace the belt
Posted on May 06, 2010
HI I have a whirpool AWM 5145/5 washing machine. The fabric softner is not being taken from the draw. We have removed the draw and flushed with hot water but has made no difference ( it does take the...
I hope you don't mind me saying so but often the softener tray's dispensing siphon tube gets missed when cleaning the dispenser 'cos it's difficult to see!----------->
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this isn't the problem it could be that the water dispensing is not working correctly. It is easy to check by selecting (final?) rinse, pulling the drawer slightly out and seeing and hearing whether water is being fed into the softener tray. If is isn't then it is a call-out ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
May 28, 2011 | Whirlpool AWM5145/2 Front Load Washer
Dispenser - which tray to use for liquid detergent?
Liquid goes straight into the wash before you put it on, you can get a liquid ball that you fill and put in with the wash, dispenser just for powder which goes in 2 or fabric softner.
Mar 01, 2011 | Hotpoint Ultima WF860 Front Load Washer
Water leak from front powder/conditioner drawer.
Completely remove the dispenser unit. look inside the recess you have just taken the dispenser drawer from and look up. You will find this is covered in muck. Clean it with an old toothbrush or something but do not use too mush pressure. This should solve your problem. If not then you will need to replace the dispenser unit completely
May 22, 2010 | Whirlpool AWM5125/1 Front Load Washer
May 06, 2010 | Whirlpool AWM5104/1 Front Load Washer
Whirlpool AWM 1203 Leaks water onto floor about 20 sec into wash cycle. Any solutions ?
It's either a perished door seal/bellow or perished pipe work most likey. Could even be a leak from the dispenser drawer
Mar 24, 2010 | Whirlpool AWM6100 Front Load Washer
Hiya, i have the AWM 5104 and i was wondering how i can clean the filter as our clothes are coming out with gunge on them!
run some affresh through the machine. also make sure you are using HE detergent. run the cleaner at least once a month
Feb 21, 2010 | Whirlpool AWM5104/1 Front Load Washer
Fabric softener dispenser won't drain
Just a thought, It has probably Gummed up, Take out tray if possible and clean with Hot water to disslodge it.
Use Quality wash Liquid that doesnt need conditioner. Thats what I do anyway
Oct 03, 2009 | Kenmore Elite 45986 Front Load Washer
Fabric conditioner stays in the dispenser tray
the holes above the fabric softener tray that shower into it may be blocked. use an upturned washing up brush to scrub them with a little fairy liquid and see if that works, it does for me. also could be a water pressure issue.
Jan 23, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Feb 25, 2008 | Whirlpool AWM5104/1 Front Load Washer
Front Load Washing Machine
Filling laundry detergent and/or additive
dispensers
Dispenser I: (RIGHT SIDE)
Detergent for soaking agent.
Dispenser II: (LEFT SIDE)
Detergent for wash, stain remover.
Dispenser 2: (MIDDLE)
Cleaning product, e.g. fabric softener, fabric
conditioner (do not fill above the lower edge of the
insert 1).
Dec 29, 2007 | Washing Machines
Washing Machines Logo
56 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
