Question about HP Officejet 6310 All-In-One InkJet Printer
Hp officejet 5510 remove and check black cartridge message and i replaced the black to new one.
    Scholar:
  • 24 Answers
Hi Shaharz !
As per the information you have provided, I understand that you are receiving an error "Remove and check black ink cartridge" on the All-In-One display screen. If yes, perform the below steps.
Let me provide you the cause of the issue. The most cause of the issue is that if you are using refilled, re manufacture ink cartridges, cartridge is not fitting properly, wrong cartridge no. However, perform the below steps to resolve the issue.
1. Remove the print cartridges from the printer.
2. Clean the print cartridges using the lint free cloth both the cartridges heads as well as inside the printer.
3.Follow the steps below to power cycle your all-in-one:
a. Verify that the unit is switched on. Disconnect power cable from All-in-One and also from wall outlet.
b. Wait 30 seconds.
c. Plug in the power cable to All-in-One and also to wall outlet.
4. Insert only the black ink cartridge first and check the message on the printer.
If the issue is with the black ink cartridge then the same message will be appears on the printer. If not it will prompt you to insert the color ink cartridge.
Do the same procedure with the color ink cartridge.
If the issue persist, then it shows that the issue is with the black ink cartridge. check the expiry date of the print cartridges and try to replace it.
I believe the issue is with the printer itself. However, the printer using the HP 56 and 57 ink cartridges.
As you have mentioned that you have already replaced the black ink cartridge. Then it confirms that the issue is with the printer. However, you can try resetting of the printer to its default settings and check for the issue.
To reset the printer, perform the below steps.
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
The printer might be turned off after performing the above steps, so no need to worry about that.
Then turn on the printer and check for the result.
Hope this will helps you a lot!!!
With Regards
Mike.
Posted on Jun 27, 2009
HP Photosmart C4140 error message won't go away Remove and check color cartridge. I have done this and unplugged, checked both color and black cartridges...won't go away.
hey, sometimes there are faulty cartridges. i use to got some brand new and original from the shop and not working.. so try it with some old cartridge if you have.. you can also try to remove the cartridge and clean/wipe the contacts on the cartridge side and on the printer side (turn of the printer for safety)
Sep 18, 2011 | HP Officejet 5510 All-In-One Thermal...
How do I change the ink in hp officejet 5510
Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access doorc00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridgec00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tapec00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridgec00034769.jpg
  5. Close the print-carriage access door.
Back to top Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Feb 08, 2011 | HP Officejet 5510 All-In-One Thermal...
Printer # 5510 - How do I open to replace ink cartridge?
If you mean HP OfficeJet 5510 then the following tutorial is for you:
HP OfficeJet 5510 Replace Ink Cartridges
If you do NOT mean HP OfficeJet 5510, please do not fail my solution. Instead, start a new thread with your make, model clearly defined.
Jan 13, 2010 | Office Equipment & Supplies
I have a HP officejet 5510. I just put in a new HP cartridge
Like any other mass-produced parts, there will be some defective printer cartridges and it sounds like you have one. Since the first cartridge worked there's no reason to suspect a printer problem. I would suggest taking the cartridge back to the store where you purchased it and explain the situation. Since dud parts go back to the manufacturer, maybe they will exchange it for you as defective.
Apr 22, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5510 error "Remove & check color cartridge
Re: OfficeJet 6310 Tricolor (93/95) Cartridge Stops Working After Replacing B/W (92) CartridgeOptions
04-26-201210:27 PM
1. Remove all cartridges and turn off printer
2. Unplug printer and wait one minute
3. hold down # and 9 while plugging power cord back in.
4. Wait a few seconds, then press the power button.
5. Display should read "Full Null Reset"
6 Only install color cartridge. Close cover
7. Wait for machine to ask for black cartridge, then open cover and install black cartridge.
8. Close cover
9. Alignment page should be printed automatically.
Mar 16, 2009 | HP Officejet 6310 All-In-One InkJet...
Continue to receive "Remove and check black cartridge" message
I would call hp again. The cartridge you purchased is covered for a one year warranty and they should be able to replace to make sure issue is not with the cartridge itself. Since this is not a computer issue tell them you have a mac and you will get to Canada support instead of India.
Jul 31, 2008 | HP Officejet 5510 All-In-One Thermal...
Printing message problems
its not an ink problem but a mechanism problem many things can lead to this: say bad film, week rollers and etc so loos the nprinter n make sure all the mechanism are in place.
May 15, 2008 | HP Officejet 5510 All-In-One Thermal...
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
REPLACING INK CARTRIDGS
For HP 5510 series for replacing the cartige, you need to lift the door just above the paper tray. Pull out the old cartidge, hold it so you can see the way it is inserted and click in gently in the same way.
Nov 19, 2007 | HP Officejet 5510 All-In-One Thermal...
HP Officejet 6310 All-In-One InkJet Printer Logo
901 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
