Question about IBM NetVista PC Desktop
I cant use my keyboard in BIOS setup - IBM NetVista PC Desktop
  • Raph Quintos
    Raph Quintos May 11, 2010
    are you using a usb keyboard? well if you do, try changing it to a ps2. it probably not recognizing your usb keyboard on bios setup.
    Novelist:
  • 155 Answers
What type of connector have you got on your keyboard. Is it USB or the older PS/2 type (round 6 pin purple thing?)
USB keyboards can be problematic when working with the BIOS. It is usually possible to enable a setting in the BIOS setup pages to enable them to work but, as you've probably guessed!) you need a PS/2 type keyboard to allow you to make the changes in the first place!
The other option is to by a PS/2 to USB adaptor. They should be available from any good computer shop.
Hope this helps!
Posted on Jun 27, 2009
I had change bios setting.but after now i cant go to bios setup when the computer is booting.how i can fix this case
If you want to go to the BIOS setting of your computer its either you press F2 or F10 on your keyboard depending on the type of motherboard you are using. Remember that you watch the screen while doing this, and it will display a message saying "Entering setup" Just a word of caution, do not change settings that you are not sure of in the BIOS settings because this might cause your system to malfunction
Aug 23, 2013 | Toshiba Satellite P105-S6227 Notebook
DELL INSPIRON 1525 HELP
It should be a simple fix. Start your laptop and pay attention to the screen. Press the F12 key (or F11) to enter "SETUP" then find the NUMLOC command and make sure that its DISABLED or OFF. This will turn this option off andyou will only be able to use the number's keys on the top of the keyboard. Be careful when entering SETUP. You don't want to change anything you don't have to.
Dec 26, 2011 | Dell Inspiron 1525 Notebook
Keyboard does not respond
firstly check out the power supply of the keyboard.check the cable and connectors of the keyboard properly.check out your bios setup for ensuring that it detects the keyboard or not. if bios setup detects your keyboard than check your keyboard's circuit.
Jun 01, 2011 | Computers & Internet
My pc is showing "Setup Entry Key Detected" and its not starting when restarted and just showing the bios settings screen. Please help me out for this problem.
Setup entry key could be "DEL / F2 / Enter" depending on BIOS manufacturer. So, the key might have pressed/stuck/short circuited in keyboard. You can try plugging off the keyboard for the start. Some BIOS need keyboard to boot. Anyway, if you're not seeing the BIOS Config after plugging out keyboard, the keyboard key is the problem here. Try swapping with another one or hit those keys for few times. Good luck.
Aug 27, 2010 | Computers & Internet
No repeat rate for keys. How to fix it when control panel doesn't?
Seems to me that if i remember right you do this in the bios. The keyboard is the one device that has to be setup from the bios or else needs drivers setup for it. Reboot your computer and then go into the bios, hunt in there and you should find the keyboard setting to change it. Hope this helps
Jun 11, 2010 | Micro Innovations Internet Pro Keyboard...
Can't access BIOS
Eject and re-insert the bios battery.
Aug 30, 2009 | Intel Motherboard
Mouse and keyboard freeze.
its a very common hardware fault with these laptops, can you open setup or bios? that is opened right when the power is turned on the and screen says press F2 to enter bios or setup, if you can't enter bios then you have a faulty motherboard, usb ports don't work either? (usb keyboard and mouse don't work?)
May 13, 2009 | Acer Aspire 3100-1405 Notebook
This mb will not accept keyboards
if the keyboard is working fine with other pc's except this motherboard i suggest you to enter the Bios setup by pressing the F2 or Del key before the system boots and set the option Halt On in the Bios setup to----> All error ,but Keyboard
May 08, 2009 | Computers & Internet
Which key to enter to bios to format pc IBM pentium III
del.. button on your keyboard old models may require F6
Nov 19, 2008 | IBM ThinkPad T23 Notebook
Bios does not find PS2 keyboard/mouse
Did you go into the BIOS and set it to recognize the USB Keyboard after you reset the BIOS? Is windows not noticing it or the BIOS. You stated that it recognized the USB keyboard and then said that it did not.
What does all of this mean? USB keyboard does not activate "del" setup.
If it does not work, it is because you reset the BIOS and did not change the settings back for the USB keyboard.
I hope that I fixed your problem.
Jun 04, 2008 | AOpen AX4BS (91.32Q10.002) Motherboard
IBM NetVista PC Desktop Logo
222 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
