Question about Black & Decker BDBS100 9-Inch 3.5-Amp Band Saw
MAX thickness of wood that this band saw can handle
What's the max thickness of wood that can go through this band saw? the height between the platform and the top of the saw
    President:
  • 1,996 Answers
Generally that's the limit. But to feed a piece that thick, you'd have to have a sharp blade, well adjusted guides and a pretty slow feed rate, depending on the species of wood. I'm guessing the saw will bog down and refuse to cut long before you reach that thickness, unless you have the patience of a saint and don't mind standing there feeding the board through a cm at a time.
Well- tuned it will definitely cut better, but these little portable saws are generally underpowered in my experience..and work best for 3/4" or less thick boards.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 08, 2009
Can I use my metal chop saw to cut wood if I replace the blade with a wood saw blade?
Its conversely sometimes possible if you was asking about a wood saw with a steel saw blade but i cannot advice that in both application its not safe because not only of the difference of power but most it is the much higher RPM by diameter, just beware always on the max rpm you can read on your saw blades!!, it can give strange accidents with objects it can grab and swinging outbroken parts away.
Sep 28, 2016 | Makita "2414NB 14"" Chop Saw"
What wood and year ?
Neck Material: Mahogany- Neck Type: Artcore set-in- Body: Maple top/back/sides- Frets: Large frets- Fingerboard: Bound Rosewood- Inlay: Pearl dot inlay- Bridge: ART1 bridge- NeckPU: ACH-ST- BridgePU: ACH-ST- HW Color: CH- Width: Max width at lower bout: 15 3/4"- BodyThickness: Max body thickness: 3 5/8"
Your guitar was made at the
Sejan Plant, Korea
September 2014
Production Number: 120
Feb 24, 2015 | Guitar Research Music
How can I cut wood 3.5 inches thick with Dewalt Scroll saw?
nope... throat on scroll saw is of fixed height... beside, all scrollsaw blades are of fixed length, i would suggest use of bandsaw with very narrow blade with minimal kerf. do not use pressure on the blade! you will then have same cut through the thickness of the wood! setup bandsaw correctly, do not overtension it - see my other instructables pertaining to the bandsaw and regulation/setup of it
if you find my solution helpful - do not me shy... give some points... :-)
Jan 23, 2014 | Dewalt DW788 20" Variable-Speed Scroll Saw
Can anyone help please ive just got hold of a black and decker DN339 band saw and want to cut max 50mm soft wood with the grain using the fence to slide against, only the blade is tilting towards the fence...
That is usually an indication that the blade is blunt and one side has lost its edge more than the other. The blade will wander towards the sharper side. You will have to replace the blade. For soft wood you need about 4-6 tpi. and a cutting speed of about 1000 - 1500 ft/min.
Mar 28, 2011 | Saws
My bandsaw don't work right, I go to cut wood ,the blade turn all difference way, I where out the block on the guide , It just don't work right
A couple options. 1. New blade. A dull blade will swivel around like that. Especially with a tight grained wood. 2. All the guides need to be properly adjusted including the height, both lateral guides, and the back guide.
Dec 19, 2010 | Delta 28 276 14" Band Saw W/ 3/4 Hp Motor...
I have a ryobi bs901 band saw... the cheap latex(?) rubber tires disintegrate in a single summer season due to the heat in my Georgia shop. I need real rubber tires built to last a while. Any suggestions?...
I had to take mine back. Some of these saws come with a small gap in the rubber wheel. This causes the rubber to deteriorate over time, kind of like a pot hole. I've had the replacement band saw for 5 years and it still works perfectly.
Apr 01, 2010 | Ryobi 9 in. Benchtop Band Saw
In the Market for a better Band Saw
Everybody wants to resaw, but the only saw I've seen that will do it is a resaw, they are big, powerful machines. I have an old delta 14, with an aftermarket 1 hp motor, trying to resaw is a nightmare. I don't try anymore. Jet makes a big resaw, so does grizzly, both Taiwan machines, what isn't>? But they work. If you are lucky enough to find an old bandsaw with 36 inch wheels and a ten HP motor, that would be nice, you could resaw whole cars in that thing.!I The $300 special might be worth getting and customizing to work, You would need a big blade, about 1 inch min, and a bigger motor, say 2HP min, Then hope that the tracking system will take the heavy cuts. When I have to slice something , I do it first on the table saw, cut both sides, then run it through the band saw at its max cut, 6 1/2 inches, then plow it through the planer. Always a way around this stuff. Hope this helps.
Mar 01, 2010 | Ridgid 14" Band Saw with Stand
When cutting wood with band saw saw will cease up
This could have many causes...depending on the model of saw, the wood being cut, the blade you're using, etc. etc.
Check that the blade is correctly installed, up to tension, and sharp. Make sure the wheels run smoothly on their on, and under power. Check the horsepower of the motor, and make sure to keep the feed rate down within the motor's capacity. Finally, don't twist the work being cut to a smaller radius than the size blade will handle, or you will bind the blade in the cut.
If you are cutting wood with pitch or grain that is likely to be under tension, perhaps you need to insert a wedge into the cut to prevent the work from pinching the blade as it continues the cut.
I hope that leads to a solution. Sometimes all you can do is feed slowly and be patient...
Jan 25, 2010 | Saws
Motor power question
Horsepower is the maximum power produced by the motor. Saws with high horsepower ratings are good for pattern cutting and cutting down thick stock. Higher horsepower also allows the saw to cut through thick stock without bogging down or burning the wood.
Aug 27, 2008 | Ridgid 14" Band Saw with Stand
Black & Decker BDBS100 9-Inch 3.5-Amp Band Saw Logo
232 people viewed this question
Top Black & Decker Saws Experts
Craig Butler
Craig Butler
Ruben Bustamante
Are you a Black & Decker Saw Expert? Answer questions, earn points and help others
