Question about HP DeskJet F4280 All In One Printer InkJet
Have an E message does not print also the color cartridge is flashing
  • 21 Answers
See error code section of user manual which you can get here: http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
Posted on Jul 06, 2009
Caution lite flashing over cartridge of hp deskjet 940c. error message says that there is not color ink cartridge in printer. There is and the interface says the tank is full. It won't print...
Even though the interface says the cartridge is full, if the printer detects it being empty, odds are you will have to replace the color cartridge, even though you are only printing black.
You can try taking the cartridge out and cleaning the contacts with a pencil eraser and reseat the color cartridge. If no change, replace the cartridge.
Jun 30, 2011 | Computers & Internet
Have an HP PSC 1510 printer. I put in a new genuine HP Tri-Color (93) printer cartridge as I usually do and the "Check Printer" cartridge started flashing. Also flashing on the printer is the...
Problem After you install a print cartridge, one of the following messages appears on the color graphics display:
  • Incorrect Print Cartridge
  • Incompatible Print Cartridge
  • Problem with the Print Cartridge
  • Remove and Check [color / black or photo] Cartridge
  • [Tri-color / Black or Photo] Print Cartridge Inserted Now is Not Intended for Use in This Printer
NOTE: In the procedures below, the "problem" cartridge is the one identified by the message on the color graphics display. If the message does not specify a cartridge, perform the procedures on both cartridges. Step 1: Remove, inspect, and reseat the problem cartridge The print cartridge may not have full electrical contact with the printer. Removing and reinstalling the cartridge may help.
NOTE: HP cannot guarantee the quality of remanufactured or refilled cartridges.
  1. Make sure the printer is on. Press the Power button if it is not lit.
  2. Open the printer cover, then wait until the print cartridge carriage is idle and silent.
  3. Press down lightly on the end of the problem cartridge to release it. Figure 1: Removing the tri-color cartridge
  4. Slide the cartridge out and inspect it:
    CAUTION: Do not touch the copper electrical contacts or the ink nozzles. Figure 2: Electrical contacts and nozzlesc00211537.gif 1 - Copper electrical contacts 2 - Nozzles
    • Check the electrical contacts for debris.
    • Make sure all the clear nozzle protective tape has been removed.
      CAUTION: Do not attempt to remove the copper electrical strip! Figure 3: Removing the clear nozzle protective tape
    • Look at the number on the print cartridge label and make sure it is compatible with your printer. Compatible print cartridges are listed in the Printer Reference Guide supplied with your printer.
  5. If the cartridge is compatible, reinstall it in the printer:
    • Cartridges marked with a triangle go into the left carriage slot.
    • Cartridges marked with a square or pentagon go into the right carriage slot.
Step 2: Clean the problem cartridge contacts
  1. Gather the following items to clean the cartridge and carriage:
    • Clean distilled water. Use bottled or filtered water if distilled water is not available. Tap water can contain contaminants that damage the cartridge.
    • Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well).
    • Sheets of paper or a paper towel to rest the cartridge on during cleaning.
  2. Open the product cover and wait until the carriage is idle and silent.
  3. Remove the cartridge and place it on a piece of paper with the nozzle plate facing up.
    NOTE: Clean the contacts quickly so that the cartridge is not outside of the product for more than 30 minutes. If the cartridge is outside of the product for too long, the ink can dry and clog the nozzles.
  4. Unplug the product from the electrical outlet.
  5. Dip a swab in the clean water and squeeze it to remove most of the moisture. The swab should be only slightly damp.
  6. Clean the cartridge contacts.
    CAUTION: Do not touch the ink nozzles.
  7. Clean the contacts in the carriage, inside the product.
  8. Either let the cartridge sit for 10 minutes to allow the cleaned area to dry, or use a new swab to dry it.
  9. Reinstall the cartridge.
  10. Reconnect the product to the electrical outlet.
  11. Close the product cover.
Step 3: Repeat reseating and cleaning steps If the problem is not solved, repeat the reseating and cleaning procedures above.
Call HP if the cartridge is covered under warranty to replace the cartridge
or its time for a new printer
Apr 04, 2011 | HP PSC 1510 All-In-One InkJet Printer
Message says problem with tri color cartridge
I don't think the date on the cartridge is the problem. It might be the electronic on your color cartridge. If there is an orange light flashing and the printer won't pull the paper to print, in 99%, the problem is one of the cartridges. Try removing the color cartridge and gently wipe out the electronic with a dry cloth. Put it back in and try to print. If that doesn't help, try removing the color cartridge and print (I am not sure if that will work, because all in one printers usually need both cartridges in order to print, but you can try that too). You can also try scanning something and see what the message on the printers display tells you. If there is an E an the color button is blinking, I think you should replace your color cartridge.
Apr 04, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Incompatible print cartridge - tri color
Here's two possible solutions...you can replace the cartridge as some times they can be prone to electric/electronic problem which renders them useless. You may be able to return the defect cartridge.
Option two is to reset the printer by following these steps:
1)Make sure your cartridges are installed.
2)Unplug the power to the printer and wait about 20 seconds
3)Press and hold the # and 3 keys (while unplugged)
4)Plug the power back in (you should see a reset message on the machine)
5)Release the # and 3 keys and follow the prompts
Mar 02, 2010 | HP OfficeJet J4580 All-In-One Laser...
Printer light keeps flashing and will not print
Use ONLY GENUINE HP ink cartidges. This will fix it.
Jan 04, 2010 | Dymo LabelWriter 310 Printer
Printer wont print
Turn the printer on. Remove the cartridges. Gently clean the electric contacts on the cartridges and the cartridge carrier. Put the cartridges back in. If the light is still flashing, and your printer won't print, one of your cartridges is faulty. I suggest you go to the refill shop and consult them which cartridges needs a replacement.
Does any message appears on your monitor when you try to print something? Usually, a message saying "problem with black/color cartridge" or something similar, that's why I am asking.
Dec 22, 2009 | HP DeskJet 930c InkJet Printer
Cartridge Error 50C consult user guide. I
Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Nov 10, 2009 | Lexmark X6170 All-In-One InkJet Printer
Color Cartridge Has Stopped Working...Lexmark Z45 Printer
i think this a firmware issue of the printer..
try to flash a new compatible firmware .
May 12, 2009 | Lexmark Color Z45 InkJet
In canon pixma ip1700 Alarm light orange flashes 15 times
Fifteen Flashes: The FINE Cartridge cannot be recognized.
Possible causes are as follows:
- The FINE Cartridge may not be installed properly.
- The FINE Cartridge may not be compatible with this printer.
Install the appropriate FINE Cartridge. If lines are misaligned or the resulting output is not satisfactory, carry out the Print Head Alignment.
Apr 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
HP DeskJet F4280 All In One Printer InkJet Logo
266 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
