Question about U-Line Icemaker
U-line water level too full
Cam i adjust ice cube size or height with the side - or+ adjustment
  • 286 Answers
If you have a icemaker then remove the cover. You will see a screw with a spring around it. Turn that clockwise like your tightening it this will reduce the size of the cube. Also make sure it is leveled. And make sure no corrosion is around the gears on that same plate. This could make the motor run slower and more water comes into it.
Posted on Jun 28, 2009
My PT Model IM-600 US ice maker makes cubes but continues to freeze on the ouside of the cube tray blo th cubes from falling into the bucketwhat is wrong.
cubes set too large
Adjusting the Ice Cube Size: 1. Press and hold the "Adjust" button for approximately 3 seconds until the Green Indicator starts blinking, release the button. The unit is now in Ice Adjustment mode. 2a. Press the "CLEAN" button to decrease ice cube size. The Red Indicator will flash as you lower in size and will blink when you have reached the smallest possible setting. 2b. Press the "MODE" button to increase ice cube size. The Yellow Indicator will flash as you increase the size and will blink when you reached the largest possible setting. After 10 seconds without any operation, the unit will return to the previous mode. NOTE: • During the ice adjustment mode, if the "ICE FULL", "ICE MAKING" and "ICE HARVEST" LED's all blink simultaneously, this means setting is at the regular (middle) size. • When the machine is in the cleaning stage or ice full stage, the ice size cannot be adjusted.
Dec 04, 2017 | Refrigerators
I have a Kenmore Elite side-by-sr ide refrigerator Model 106. The ice making system is putting too much water in the ice tray, making the cubes too big. These large cubes are clogging up the dispenser. ...
With out the full model number it is hard to say. Most 106 model referigators have a modular ice maker. If you take the cover off of the front of the ice maker and look on the right hand side of the motor module you will notice a small plastic adjustment screw. If you turn this screw you can adjust your water fill time to the ice maker.
Sep 01, 2011 | Kenmore Refrigerators
English instructions for saivod fhs186 ice maker
DO THE BASICS:
Change the water filter
Add ice machine cleaner and go by the directions.
What should be kept clean?
There are 5 things to keep clean:
1. The outside cabinet & door.
2. The ice storage bin.
3. The condenser.
4. The ice making system.
5. The ice scoop.
The ice storage bin should be sanitized
occasionally. It is usually convenient to sanitize the
bin after the ice making system has been cleaned,
and the storage bin is empty.
A sanitizing solution can be made of 1 ounce of
household bleach and two gallons of hot (950F. -
1150F.) water. Use a clean cloth and wipe the
interior of the ice storage bin with the sanitizing
solution, pour some of the solution down the drain.
Allow to air dry.
How to clean the condenser.
The condenser is like the radiator on a car, it has
fins and tubes that can become clogged. To clean:
1. Remove the kickplate.
2. Locate the condenser surface.
3. Vacuum the surface, removing all dust and lint.
Caution: Do not dent the fins.
4. Replace the kickplate.
Winterizing
1. Clean the machine as explained on the next
page.
2. Turn off the water supply.
3. Drain the water reservoir. See page 24, Spray
Pump Repair and follow the instructions to remove
the pump hose (step 2, bottom hose only).
4. Disconnect the incoming water line at the inlet
water valve.
5Remove control box cover and turn the timer
into the harvest cycle.
6. With the machine operating, blow air through
the inlet water valve; a tire pump could do the job.
7. Drain pump models should have about 1¤2 gallon
of RV antifreeze (propylene glycol) poured into the
ice storage bin drain.
Note: Automotive antifreeze must NOT be used.
8. Replace control box cover. Switch off and
unplug the machine.
CUBE ADJUSTMENTS
There are three items that may be adjusted: Cube
Size, Harvest Time, and Bin Level. Note: Cube
Size and Harvest Time adjustments should only be
done by a qualified service person.
Cube size control.
The cube size control should only be adjusted to
bring the cubes to the correct shape, the overall
size cannot be adjusted. Try to adjust the cube
size control when the ice machine is in the harvest
cycle, or in the first 10 minutes of the freeze cycle.
1. Open the door and remove the control box
cover.
2. Locate the cube size adjustment screw, and to
make fuller cubes, turn the screw clockwise about
1/4 turn. This will make the freezing cycle longer.
3. To shorten the freezing cycle and make cubes
that are not as full, turn the adjustment screw 1/4
turn counterclockwise.
4. After the next freezing cycle, the cubes should
have responded to the adjustment, if another
adjustment is required, do it early in the freeze
cycle.
Diagnostic Codes
Code Description
F - - - - - - - Freeze Cycle
F flashes- - - - Freeze Cycle is Pending
H - - - - - - - Harvest Cycle
H flashes- - - - Manual Harvest
b - - - - - - - Bin is Full
C - - - - - - - Clean Cycle
L - - - - - - - Board Locked
d - - - - - - - Test Mode
O - - - - - - - Off
E - - - - - - - Self Test Failed
1 flashes- - - - Max Freeze - Retrying
1 - - - - - - - Max Freeze Time Shut Down
2 flashes- - - - Max Harvest - Retrying
2 - - - - - - - Max Harvest Time Shut Down
3 - - - - - - - Slow Water Fill
4 - - - - - - - High Discharge Temp
5 - - - - - - - Sump Temp Sensor Failure
7 - - - - - - - Discharge Temp Sensor Failure
8 flashes - - - Short Freeze - Retrying
8 - - - - - - - Short Freeze - Thin ice
All 4 Upper Lights Flashing - Unit Remotely Locked Out
Jul 14, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
My scotman model sce170a1a.goes into harvest to
That has to be a faulty control wouldn't you think?
cover.
cycle.
Feb 04, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Our ice machine does not make full ice cubes. they are small and not complete, they are full of holes.
The icemaker requires a water pressure of 1.5 - 8.5kgf/cm2. It is acceptable if the water supply fills a cup of 180cc with water in 3 seconds. The icemaker produces small cubes if the water fed into it is not enough and lumped together if too much water is supplied. In order to obtain the desired size of ice cubes, the amount of water supplied to the ice maker needs to be adjusted. Adjust the valve supplying water to the icemaker or the unit in general in such a way that right amount of water fills the ice tray.
Nov 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My GE Profile refrig ice maker makes hollow ice cubes. Why would this happen?
Not enough water is being pumped into the icemaker. The water pressure in the water line coming into the refrigerator may be too low, perhaps due to a blockage somewhere.
Move the refrigerator enough to get behind it. Turn off the water at the small valve which connects the water line from the house plumbing to the tube going into the refrigerator. Get a bucket. Remove the refrigerator water line from the on-off valve (there should be a compresson nut holding it on). Point the incoming water line into the bucket and open the valve. Do you have a good flow of water? If so, either there is a blockage in the tubing within the refrigerator or the water valve at the bottom of the back of the refrigerator is malfunctioning.
Oct 12, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice cube shape
hoshizakis make ice cubes depending on the amount of water in the sump. if you are starving for water the sump only partially fills in the fill time allowed . then it makes ice until the water is used up and the float switch drops and the cubes are little slices. you can adjust the size of cubes you want by raising or lowering the float assembley in the sump. if its to low the water rises and the float rises and tells the machine you happy with little slices. if you raise it up to max height you can max fill before float satisfies and max ice cubes. But if you are starving for water the time to fill will run out before the sump fills and cubes will be small no matter where you set the floats assembly. water starving can be due to crud in the water line, to small a water line, most hoshizes take a half inch line ,or a clogged water filter. if you suspect a filter take it out . if fill is drastically improved you need a new filter. be aware that starving for water on a hoshizaki will eventually lead to broken evap plates. big time expensive.good luck. i put in a new machine ruined by starving water and the new one made little chips of ice real quick. i finally pulled the filter out and voila! big cubes and great production.
Oct 28, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Ice maker is making ice but the ice is becoming solid in the tray and jamming the blades and not comimg out in cubes
THE POSSIBLE CAUSES MAY BE FROM THE CUBE SIZE CONTROL
ADJUST THE CUBE SIZE CONTROL
INSPECT THE WATER SUPPLY LINE
TEST THE WATER INLET SWITCH
TEST THE WATER INLET VALVE
Sep 01, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaks into storage bin
open the machine control panel side and cube adjustable thermostat available in side,adjusted in the thermostat screw
Jun 22, 2008 | U-Line Icemaker
Small ice cubes The ice maker is not supplying enough water. The result is very small ice cubes. The water supply pressure is on max, can there be a way to adjust the water level? The tray is not even...
The ice maker is time filled, it only has a certain time in which to fill. There is no way to adjust the water level. Check the pressure limiting valve which is in the water line before the filter. Have you replaced the filter? Remove the filter and pressure limiting valve and see if the ice maker receives more water. If it does, then replace the filter and check again. If it is still good, the pressure limiting valve is faulty.
Oct 27, 2007 | Samsung RS2630SH Side by Side Refrigerator
U-Line Icemaker Logo
134 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
